Question about Hitachi C29-R30SP 29" TV
Aerial plug what do i need in order to connect the aerial plug to my standard cable cord?
0 characters
1 Points
No snow just says to scan chanels . I have over and over
The TV signal is no good if it cannot find any channels. You will have to check the signal cable and its connections right back to the aerial. You may even need a better aerial or a signal booster. Digital TV needs the very best of all these or the picture just goes to porridge.
Apr 30, 2016 | Insignia NS-24 TV TV
The aerial port does not work.
It is possible the tuner or antenna connection is bad---If you can call up the menu with the remote set needs to be switched from cable etc to air or antenna and channels programed------not on the rear input connection but for the tuner in the set (presume it has a tuner if antenna connection of any type is there.
Oct 29, 2012 | Standard (CRT) Televisions
Hi, I have a digital tv plugged into an extension cable in an upstairs (Toshiba) bedroom; it works perfectly - receiving all channels. I have a digital tv downstairs (Samsung) where it seems the wall...
Hi Fiona
Somewhere along the line from the aerial there must be a signal splitter that feeds the upstair and downstair terminals.
Try to find that splitter and switch the output to see if the problem goes from up to downstair.
If it does switch then you know the problem is with the splitter block, and if it stays the same then the problem is with the cable and/or the connectors that run downstairs.
Also the reason you get a pixellated(snowy) picture is because of signal loss during the length of the cable you ran downstair.
If running a cable downstair becomes the best option to fix your problem , then you could buy a cheap 10db signal booster/r.f amplifier to correct the signal loss and a cable splitter to feed both tv`s
That booster would be installed upstair in your case(near the source of the signal to be amplified).
I could send you a small diagram if need be. Hope this will help and Merry Chrismas
Dec 14, 2009 | Standard (CRT) Televisions
Tv with built-in digital tuner not receiving any channels
Is your outdoor aerial a proper freeview aerial and are you in a strong or weak signal area.You can check here:
Also check your connections as the coax may be shorting with the braid or a bad connection.once checked try ordinary channels on upstairs tv and if ok retune all your digital channels.
This can be due to a few problems.Firstly make sure your aerial is pointing in the right direction as beam aerials attenuate(disregard) signals which are not pointing directly at the aerial.
make sure you are using good quality 75ohm cable i.e rg6 and connections are good and not shorting out.
The length of run of the cable will also affect the signal as will any splitters or joins in the cable.
If you know the signal is good in your area then it will be down to the aerial,cable terminations ,aerial position or a combination of these.
If the signal is poor you can either...Buy a high db gain arial which will amplify the signal and or a masthead preamp which will again boost the signal.
please note that if your aerial is not pointing in the correct direction then any boosting of a bad signal i.e ghosting...will only make it worse.
try starting from aerial direction then connections then a high gain aerial and or booster.
Oct 14, 2009 | Standard (CRT) Televisions
Freeview - No transmitter found
The signal from the communal aerial might be weak, since other people are using it, or it is experiencing interference with a power cable or something.
Try a signal booster from **** Smith or Harvey Norman, RadioShack, Tandy, Walmart etc ( I assume you are Australian - Freeview :) )
Get your own aerial, if you don't live in a concrete shoebox....
Oct 12, 2009 | Standard (CRT) Televisions
What plugs in where at the back of model 32AV633D Does single scart go to ext 1 or ext 2 Where does outside aerial plug in, there are so many ? Sorry but I'm a complete technophobe who is hopeless at...
If you have a cable box or freeview box, your main aerial lead plugs into the box. Then you connect a scart lead from your cable box/freeview box/ or dvr box to ext 1 on the tv. Where the aerial lead plugs into your cable/freeview/dvr box, there may be an aerial out socket too. You could connect a patch lead from the box to your tv as well so you have UHF direcy from your cable/freeview/dvr box to the TV as well as scart
Aug 06, 2009 | Standard (CRT) Televisions
Since digital switchover yesturday loss of digital channels
It may well be your aerial despite the success with your DVD recorder.
Digital signals are very much weaker than analogue ones, and when multiple devices share a single aerial you can get this kind of problem. You also lose about 60% of the signal at each point in your aerial cable where there are signal splitters.
There are a number of possible solutions:-
First, look at every bit of coaxial cable you have between the aerial and each appliance. Check especially at the aerial end for corrosion or poor shielding/installation and especially for evidence of rain water penetration. If the aerial is on the roof then it will cost almost as much to get the aerial inspected as it will to have it replaced, so skip to the next option. But otherwise, check along every bit of the cable for any cuts or splits in the insulation and properly remake every junction or joint if there are any doubts about them. If the cable is in poor condition then consider option three instead.
The second is to try to see if you get a better digital signal from another transmitter, this will involve trying different aerial positions so is impractical if your aerial is roof mounted but is worth trying if it's in the loft instead. It doesn't always follow that your best digital signal will be from the transmitter which you used for analogue transmissions.
Thirdly, if you're still using the same aerial as you have done for years then it's worth upgrading to one optimised for digital reception. When doing this it's foolish not to replace the cabling as well as you need it to be as good as possible. With analogue, many installers got away with using cheaper cable intended only for very short cable runs from the wall socket to the tv.
The fourth option is the budget option but can work as well as the third option: fit an additional analogue style aerials and run a separate cable down to each appliance. If these are fitted in the loft and you have the space, then there's no aesthetic or planning concerns. Normally the extra cables can run partway down through the house alongside existing cables, but for best signal quality keep them separate and ensure that the cable runs as as short as possible.
One further thing which you may want to try before all else: connect your digital box directly to the aerial cable which currently feeds your dvd recorder. Leave all other tv devices disconnected from the aerial. If the box retunes correctly then it's definitely a supply of signal issue as outlined above and if not then you should add the exact make and model of your digibox as a comment to this answer as there are a large number of earlier digibox models which cannot retune correctly due to evolving standards.
Jul 02, 2009 | Sanyo Standard (CRT) Televisions
Coaxle cable (from aerial on roof to TV)
Go purchase a coax male f connector, and the crimpers. Cut off 1/2 inch of rubber sleeving and fold the metal shielding back. Now cut the with part a quarter from the end but not all the way. You want the center piece to poke out. Now slide the f connector on and crimp.
Mar 05, 2008 | Philips Magnavox 27MS343S 27" TV
By an aerial do you mean a converter?
For the neew TV's you don't need one. Just plug it in using A/V cable (yellow is video, red and white are audio). Be sure you take note of which input you are plugging it into on the TV, and then use your TV's remote to change the video input (usually will be labeled video or TV/Video on the remote) to the one you plugged the PS2 into.
Jan 06, 2008 | Standard (CRT) Televisions
No colour on television
Hi, It is possible that the reason for the black & white as well as lines across the screen is weak, defective or wrong oriented antenna. If you are hooked up to cable, then it should not be a problem as you can call for service; if on the other hand you are using aerial antenna, you can try to: reorient or adjust the direction to where the antenna is pointed until the reception improves, check the lead in wire (cable or flat) for any breaks or shorts or loose connection, check/clean the connection of the antenna elements to the cable/flat wire, replace your aerial/cable as may be deemed fit and needed. A couple of questions pls if the above does not solve your problem: when receiving from aerial, is the picture full vertically? are you also having problem with sound? If yes, where was the TV bought and where is it being used now? If no, is the image snowy and some channels/stations are better than the others? Good luck and pls post back how things turn up or further information. kind regards.
Aug 12, 2007 | Zenith B25A11Z 25" TV
Hitachi C29-R30SP 29" TV Logo
Top Hitachi Standard (CRT) Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Standard (CRT) Television Expert? Answer questions, earn points and help others
