Question about Belkin (F5D5231-4) Router
Multiple Xbox 360 consoles
I am having problems connecting two Xbox consoles to one reouter and playing Xbox Live simotaniously. I think I have it narrowed down to my router not being able to support both consoles. I have heard of people doing this so I know it is possible, what do I need to do to make it work? My router is a Belkin N1 Model #F5D8231-4 Version 5000
  • 1 more comment
  • Anonymous Jan 03, 2009
    cannot run 2 xbox360's on my speedstream router.
  • Anonymous Feb 17, 2009
    same here can someone help...
  • Anonymous Mar 24, 2009
    Me too. Upgraded firmware and still no good.
Dionnow
  • 61 Answers
SOURCE: XBOX Live problems with Belkin N1 router
I suggest setting this up with a WPA encryption rather than WEP encryption. This should get ya setup without a problem. Also, I've noticed live to be a bit buggy since Christmas. If you continue to have troubles after trying this call 800-4my-xbox. The recording will tell you if they are having network issues.
I bet this helps!
Posted on Dec 31, 2007
SOURCE: Belkin N1 Vision
DHCP Host name is what your looking for.
you need to name each item ie. psp as psp and ps3 as ps3 when you setup each item for connection. so when you setup or edit the settings for your ps3 on your ps3 you need to look for DHCP Host name and name it ps3. etc
do the same for all.
Posted on May 25, 2008
  • 9 Answers
SOURCE: Xbox 360 router wont work with Belkin N1 Vision.
make sure u are looking for the right connection when the box opens for the connections on the left hand side u will c a small box click it u will get wireless /dialup/vpn just make sure you look for the right one also go onto ur computer into windows media into library options into sharing and search have your xbox on it will appear click on it to allow it to share with your pc i would appreciate it if you could rate this solution
Posted on Jan 11, 2009
Rumburak
  • 31 Answers
SOURCE: Belkin N1 F5D8231-4 V3000
are you running the Cisco VPN client from home, where this Belkin is your gateway and connecting to say your work?
If so, have a look in the settings of the Belkin to see if you can enable VPN Pass-through.
Try disabling some of the firewall functions on the belkin to isolate the issue and turn the rest back on.
If for some reason this model doesn't work even after the above, try changing the VPN client's connection settings,there are only two to choose from... (click modify on your connection entry, go to the Transport tab > then choose from:
IPSec over TCP and IPSec over UDP (port 10000)
Posted on Feb 23, 2010
I try to play movies and music off flashdrive and it says i have to do a media update how do i do that ihave a new Xbox slim 250gb
The easiest way to update your console software is to connect to Xbox LIVE. To update your console by using Xbox LIVE, all you need is an Internet connection.
  1. Connect your Xbox 360 console to the Internet.
  2. On the console, go to My Xbox, and then select System Settings.
  3. Select Network Settings.
  4. Select Wired Network or the name of your wireless network, if you are prompted to do so.
  5. Select Test Xbox LIVE Connection.
  6. Select Yes if you are prompted to update the console software.
Sep 26, 2011 | Microsoft Xbox 360 Console
Can't connect to Xbox Live
i cant play online, i have x box live, and i get signed in, but when i try to play a match of call of duty it tells me(the current profile is not allowed to play on xbox live) how do i salve this problem
Jan 27, 2011 | Microsoft Xbox 360 Console
Not connecting to internet
I am not that much clear whether you can change your Ip adress, but any queries regarding Ip-detais can be solved here, http://www.ip-details.com/
Jun 07, 2010 | Video Game Consoles & Games
Could you tell me in steps how to conect to xbox live
Step 1 Form your Xbox 360 you need to be connected to the Internet by a straight LAN line or wirelessly. You can test you connection by going to the setting screen on your Xbox 360.
  • Step 2 Once connected to the Internet for your Xbox 360 go to your main account screen and find the tab that says "Join Xbox LIVE" click on that link then follow the simple instructions that the Xbox LIVE will provide. At this point you should have a name in mind for your gamer tag.
  • Step 3 Xbox 360 LIVE has several different options available for memberships. They are a monthly, 3-month and 12-month membership accounts. I would recommend a simple one month account if you just wanted to check out the features offered on XBOX 360 LIVE. If your an avid gamer and love to play games online with friends, the 12-month Gold membership is the way to go.
  • Step 4 Once you've completed the process of joining Xbox 360 LIVE, they will send you a confirmation email confirming your membership. Now you can log on to Xbox 360 LIVE and start doing this like customizing your avatar and playing online multi-player games.
  • May 26, 2010 | Microsoft Xbox 360 Elite Console - Black
    Can not play disc since i down loaded xbox live?
    I don't think that is an xbox live related problem. to check if is an xbox 360 problem or the xbox live, or maybe the hard drive. Remove the hard drive and try to play a game like this. if it doesn't play is the xbox 360 since all the info for xbox live will be in the hard drive.
    If you have a newer arcade xbox 360 they come with an internal memory, so the xbox live info could be there. If that's the case delete the gamer tag that has the xbox live capabilities and try it again.
    You can always recover a gamer tag from any xbox.
    Note: you don't really download anything when you connect to xbox live, it's just like connecting to the internet. All they need is your info to be able to connect.
    May 18, 2010 | Video Game Consoles & Games
    Y wont my x box 360 connect to xbox live
    Tray to play withe the console withe out the hard drive and if the issue occure sorry to say that but u have to send it to the repair center
    Jul 22, 2008 | Microsoft Xbox 360 Console
    Xbox 360 chip and xbox live
    I think you are asking if you can play a modded xbox on xbox live. The answer is yes but eventually xbox will determine that you are playing on a modded system and ban you from live. After you are banned you will have to buy another membership and a new name.
    May 12, 2008 | Microsoft Xbox 360 Console
    Do u have to pay to go online on the xbox 360
    Hello there.
    On the Xbox 360, you'll have two choices of service level: Xbox Live Silver and Xbox Live Gold. Xbox Live Silver will offer limited Xbox Live functionality at no cost, while the Gold package will be a fully functional pay service.
    The Xbox Live Silver service means you can connect your Xbox 360 console to a broadband Internet connection and get functionality right out of the box without having to pay any amount of money.
    With Xbox Live Silver you can:
    • Create an online Gamer Profile
    • Access the Xbox Live Marketplace
    • Engage in voice and text messaging
    • Talk to a single friend at a time using voice chat
    • Receive video messages from Gold level members
    • Access massively multiplayer online games (additional fees may apply)
    The Xbox Live Gold is similar to the current paid Xbox Live service. The Xbox Live Gold service delivers the complete online connection package. With Xbox Live Gold you have all the features of Silver level, and additionally:
    • Play multiplayer games online
    • Video chat
    • Multiplayer online tournaments
    • Participate in Xbox Live online programming, such as Game with Fame, Play and Win, and Prime Time activities.
    Hope this clarifies things for you.
    Apr 13, 2008 | Microsoft Xbox 360 Console
    Xbox live
    I would suggest that if you are xbox live unless you have fast internet dont use the internet for other things like your computer. Its most likely that there is not enough bandwidth for everything. If that doesnt work call you internet service provider and explain the problem to them and if they are a legitamate company they will help you out.
    Apr 10, 2008 | Microsoft Xbox 360 Console
    Conecting to xboxlive
    Wait a couple of hours. The other day it was doing that to me so I waited a while and it worked. (Halo 3)
    Nov 30, 2007 | Microsoft Xbox 360 Console
    Belkin (F5D5231-4) Router Logo
    188 people viewed this question
    Top Belkin Computers & Internet Experts
    Prashant M
    Prashant M
    jason
    Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
