Question about Hitachi 51F510 51" Rear Projection HDTV-Ready Television
Hitachi 51f510 Color problem
Hello my Hitachi 51f10 has absolutly no red. When I push the magic color button to display the color options nothing happens. I have the the other colors just no red. How should I go about fixing this issue. Is there anywhere I can purchase a manual to try to fix this myself?
  • 108 Answers
For testing, place the green crt board on the red crt and see if the red crt lights up and the green does not. If the green does not light up then check for 200+ volts on the collector or the output transistor. if you have that kind of voltage thee then check for an open resistor. If not then make sure the transistor is not shorted
Posted on Jan 08, 2009
Faces are too red
Welcome to FixYa.
The color setting is probably too high. Access the color setting and lower it.
  • Press MENU on the remote
  • Select VIDEO
  • Then select COLOR
  • Lower the color adjustment
Thank you for using FixYa.
Have a great day. Jas247
Aug 25, 2011 | Hitachi 51F510 51" Rear Projection...
My Hitachi 51f510 projection tv just started to have a problem with the color. It appears that the tint is red/pink and I have no control over it.
For me to help you (I think I know what is wrong and it is fairly simple to correct) I need to ASK you something.
If you turn the color all the way to zero and go to a channel that is in black and white, what color is the screen?
If it is red or redish a simple adjustment will correct this problem.
Is the picture with color down to zero on a black and white channel (old movies) red looking?
Before you rate this information, let me know what you find. I am in California and will be available for a while.
SD TECH
Jul 15, 2011 | Hitachi 51F510 51" Rear Projection...
Picture is starting to get greenish, yellowish colored
hitachi model 51f510 projection tv has horizontal lines & has greenish tint,do i need to chang the bulbs??i alredy tryd the magic focus button & manual focus,but unsuccesfl,any ideas????
Nov 27, 2009 | Hitachi 51F510 51" Rear Projection...
I have 46ux13k hitachi tv and i need to know if there is atrick to adjusting the convergence.
Manual Convergence for the Hitachi. YOU WILL NEED ORIGINAL HITACHI REMOTE. NONE ELSE WILL DO
1. Receive an NTSC signal.
2. Press Magic Focus to begin magic focus
3. Press magic focus again during the magic focus process to get the “stop” screen.
4. While stop screen is up, press STATUS or INFO on the remote control (R/C) to bring you to DCAM mode and the service grid (64 point grid).
5. When you first get in here? I believe red is the selected color by default (it is flashing).
6. To choose other colors to converge, use the following buttons on the R/C:
· “STATUS” - Green
· “0” - Red
· “ANT” – Blue
ONE COLOR WILL NOT MOVE. YOU WILL NEED TO MOVE OTHER COLORS TO ALIGN TO IT.
7. Start from the center of the screen and work your way out on one color at a time. I adjusted red across the whole screen to match green. Then I switched to blue, and adjusted that to green as well. After you adjust blue, you
may want to go back and adjust some red again? etc. until the convergence looks good.
· Use 4, 6, 2, and 5 on the R/C to move the cursor position (dotted lines).
· Use thumb stick to move the convergence point color.
Then going along the lines and adjusting, you may run into the problem of getting an ‘S’ curve on the line. You’ll know if you get there. Basically, no matter what you do to adjust the line to be converged, the middle of the line between the points will not straighten out (it bends between the points). To fix this, the manual recommends going to the (7x5) mode which gives you less points to adjust. I had this problem, and the solution worked. There is also another mode (3x3) which gives you even less points. Basically, if the set looks good, you only fine tune it in (13x9) mode (64 point). If you have serious problems, the grids work as:
3x3 – ‘coarse’
7x5 – ‘medium’
13x9 – ‘fine’
10) To get to each of these patterns use the following on the R/C: (only if you need to)
1. (3x3) Press “STATUS” 5 times (only works when DCU is in uncorrected state)
2. (7x5) Press “0” 5 times
3. (13x9) Press “ANT” 5 times
11) If you adjust the 3x3, then you should go to the 7x5, and then the 13x9. You get the point… depending on where you start, work your way up, and always finish on the 13x9
12) When finishing up the 13x9 mode, to get additional ‘grids’ on the edges of the screen, press the PIP CH button on the remote control while in the digital convergence adjustment mode (DCAM). Fine tune the edge convergence as necessary. To exit, press PIP CH again.
13) When convergence is acceptable, press PIP MODE to write data to ROM memory. ROM WRITE? is displayed to alarm system that ROM will be overwritten with new data. Press the PIP MODE button again to write displayed data to ROM.
14) DATA WRITE TO ROM will take approximately 4 seconds and no picture will be displayed.
15) Green dots will be displayed when operation is completed.
16) Press MUTE to return to convergence pattern, then confirm again convergence is acceptable.
17) Turn power OFF.
18) Wait a few seconds. Turn the TV on, and you should have your normal signal. Press Magic Focus button just to make sure the magic focus still works (and that you did the last few steps properly)
Mar 21, 2009 | Hitachi 43FDX01B TV
Will not show red color in picture, magic focus shows red though
You have a projection light element out. I had the green element go on mine. I had a service agreement so a repair tech changed it.
Feb 07, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Color problems with Hitachi 57in rear projection
One or more of the projectors lights( my guess is the green one) are either blown or in the process of going bad. Have them repaired or replqaced by an authorized tech.
Dec 28, 2008 | Hitachi 57F500 57" Rear Projection...
1993 Hitachi Projection Screen TV
Hi Dennis!
Your HItachi has an automatic color convergence (color beam alignment) feature called "Magic Focus" which can be accessed from the set-up menu. When selected, you will be prompted to push the front panel "Magic Focus" button... do so only one time and do not hold the button in more than three seconds to enter this mode. The process takes about 90 seconds to complete, but a second push of the button will stop the process with no change.
If the convergence is still bad after the auto-correction process, then the guns are misaligned beyond its corrective capabilities, and would require manual convergence.
A service manual detailing how to do this is available for a nominal charge at http://www.how2files.com/bykey.php/hitachi.
If you don't have one, a free download of the user's manual is available at https://merchant.satisfusion.com/sf/WarrantyCenter/registration/secure/Hitachi/Manuals/ModelNumberManualLinks.jsp?masterModelOID=SF-990486114-595&random=1213688278588.
Hope this is helpful, let us know if you have any other questions, and good luck!
Thanks!
-WildBill
Jun 17, 2008 | Hitachi 53SBX01B 53" Rear Projection...
Hitachi TV Problems
convergence ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 23, 2007 | Hitachi 43F300 43" Rear Projection...
Hitachi 61SDX picture got dim shows Code 3
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Nov 17, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Hitachi 51F510 screen wont turn on
lighting can effect anything and everything, call insurance and get replacement value for set.
Nov 16, 2007 | Hitachi 51F500 51" Rear Projection...
Hitachi 51F510 51" Rear Projection HDTV-Ready Television Logo
288 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
