How to set clock
To set time on TEAC CD Receiver LT1
Press Memory/Clock Adjust button until numbers flash.
First display is 24/12 for choice. Change with >>> button.
Press Memory/Clock Adjust button again and Hours digit
flashes. Set with >>> or <<<.
Press Memory/Clock Adjust button again and Minute digit
In 12 hour mode "PM" will be displayed
SOURCE: TEAC SRL100 Set clock
The "set time" button on my SR-L100 is located inside the CD compartment. To set the time the unit needs to be in the standby mode. Press and hold the set time button until the time blinks, then use the tuning/clock adj. dial to set it. Hope this helps! Ted
If the unit is on, press the STANDBY/ON switch to turn it standby
2 Press and hold the TIME SET button for more than 3 seconds and release it when "12H" or "24H" appears on the display. "12" or "24" blinks. If you want to change the hour mode, press the .or/ button.
< If you leave the unit idle for 7 seconds, the time setting mode will be cancelled.
3 Press the TIME SET button once more. The "hour" value blinks.
4 Press the SKIP button (.//) to set the current hour.
5 Press the TIME SET button. The "minute" value blinks.
6 Press the SKIP button (.//) to set the current minute.
7 Press the TIME SET button. The clock starts.
