Question about Dell Inspiron 1501 Notebook
Laptop will not play games now after factory reset.
I did a factory restore on my laptop, a Dell Inspiron 1501. Now it will not play quite a few of the games it used to play. I updated the drivers to the best of my ability , I also get an "error 17" when I try to start "Air Strike 2"
I have an ATI Radeon xpress 1150 video card.
What else is there that I could fix or update? Or what else is the problem.
I have a dell involve laptop while i was trying to set back to factory specks i got locked out and it wont let me access any thing with out my administrator password and i don't no it what can i do to save...
No laptop is trashed when a password is lost. It just takes a little time to find out how to get into the system. I'll assume it is running XP Home that was originally installed on it from the specs I saw when researching. I'll also assume the password is not the one necessary to get into the BIOS CMOS setup- that one can normally be cleared by removing the CMOS battery and letting it set for a few hours or longer so the information is lost. The OS password can be cleared by making a bootable disk for that purpose. I have a Unix CD program that I made from information I downloaded from the Internet. You can do the same if you have access to a CD burner on another computer, say a friend's or one at work. I can get you the program's name if that's the route you want to take.
Dec 23, 2014 | Dell Inspiron 1501 Notebook
How do I reset to factory settings without the disk
In order to reset your computer to Factory default settings without the disc, you can follow the instructions below.
1. Turn on your computer. Once you see the DeLL Logo Press and Hold the CTRL button then while holding CTRL button, press F11
2. You should see the Dell PC Restore by Symantec application.
3. You can click Restore and Confirm the restoration.
4. It will take 10-15 minutes. Once your computer rebooted, it should already be in the default settings
Apr 04, 2011 | Dell Inspiron 1501 Notebook
Reset a inspiron 1501 how ?
really hate when people start talking bs without knowing all the facts.. there IS a 5 min factory reset magic button or buttons
restart your computer when you see the dell screen press CTRL+F11 follow the steps mine too about 3 minutes
if your computer is older then 4 years I think its F8
Jan 02, 2010 | Dell Inspiron 1501 Notebook
Hi, when i start a new game in couple of games my display crashes, and shows paralell vertical lines and some brownish background... but the windows is still running in the background, but i can only turn...
Cardinal Rule 1
NEVER PLAY GAMES ON YOU MACHINE....
Cardinal Rule 2
If you insist to play games....go to a galeria and use the games video machine there.....
a few $ spent there will save your laptop....
Laptops are not ment for playing heavy games that require strong graphic card and heavy RAMs...
Dec 10, 2009 | Dell Inspiron 1501 Notebook
How do you reset factory default on dell inspiron 1501
restart your computer when you see the dell screen press CTRL+F11 follow the steps.
Oct 30, 2009 | Dell Inspiron 1501 Notebook
I need to resore my computer to the factory settings but i don't have the disc
Restore discs for Dell and XP are OS with Dell help gui, Mostly online links to their site...look under support.Dell to find any and all drivers and patches. A Dell XP disc does not require you to enter a COA, so get one!!
Oct 11, 2009 | Dell Inspiron 1501 Notebook
I am trying to restore my computer to original state. Was told to use Ctrl F11. This doesn't to anthing. Help
don't hit ctrl f11 instead hit F8 and then go into Dell Factory Image Restore, that will wipe, format and reinstall all the factory software that's stored on the Recovery Drive.
or reformat your laptop using your cd
Sep 29, 2009 | Dell Inspiron 1501 Notebook
Reset to factory settings
If the system has the original Dell image, then just after the Dell Bios splash screen should be a black screen with w blue bar at the top with www.dell.com at the top.
At that screen press CTRL + F11 to initiate the PC Restore program.
Apr 16, 2009 | Dell Inspiron 1501 Notebook
How to get factory settings for my Dell Inspiron 1505
If you have Windows Vista you can press F8 while booting to access the Windows Startup Repair and then select the Factory Image Restor.
Dec 09, 2008 | Dell Inspiron 1501 Notebook
Restoring factory settings on Dell 1501
You can run a system repair with the recovery or operating system disc to get it back to the factory settings. A repair will reset the system, and leave any of your files, pics, and programs that you've put into the machine. If you want to clear everything, and go back to the factory settings, then reformat the hard drive and install a new operating system.
Aug 03, 2008 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 Notebook Logo
97 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
