Question about JVC XL-MC334 200-Disc CD Changer
Disc changer not working correctly
I packed this disc changer away for a couple years. Now, I unpacked it and hooked it up and it doesn't work correctly. The problem is the disc carosel(sp) doesn't match up with the number the machine indicates. for example, the machine has the readout as disc 132, and when you look at the physical carosel, it shows 63. bottom line, it won't play any CD's in this condition. help?
5 Suggested Answers
SOURCE:
kibbs
  • 234 Answers
SOURCE: JVC XL-SV22 Video CD
if cracks having in disc mean some times header does read disc! clean your header with disc cleaner!
Posted on Jul 01, 2008
localwonder
  • 6784 Answers
SOURCE: CD player will cycle through all 5 discs and then show "No Disc"
HI. the main board is ok. this is the actions of a malfunctioning optical lens assembly. the lens is unable to read, due to the damage to its structure or, the laser has burned out.
The main board is programed to issue the (no disk) alert if the lens doesn't relay audio data. simply replacing the failed optical lens assembly will fix this issue.
Posted on Jun 17, 2009
  • 10 Answers
SOURCE: CD player will not play burned Cd's anymore after 5 years of work
If it has been playing CD's for over 5 years (really reliable CD player.) then I'd think it's had it's life, it needs to rest now. Meaning it's dead so you either get a replacement or a get a new CD player.
This is what happened to my mum by the way. ;)
Posted on Sep 03, 2009
  • 382 Answers
SOURCE: jvc xl-f254 cd changer for home. 5 disc
Take the cover off and inspect for a jammed disc.
If there are no jammed discs you either have a broken belt or stripped gear.
You will have to take the unit apart and inspect, belts are commercially available from electronic stores and are a cheap easy fix!
Let me know if you need more details or guidance.
Cheers!
Kevin
Posted on Jan 29, 2010
PLEASE HELP!! Sony CDX T69 CD Changer not recognised by my car.
I would inspect the harness to your unit and see if any wires are not connected..A fully connected harness ensures all functions are working as intended and if any wire that is supposed to be hooked up and isn't then there would be your issue..
Aug 21, 2017 | Sony CDX-T69 6-Disc CD Changer
Keeps saying 'no disc'
it has a fault ,throw it away is the only solution and renew witha new radio that plays USB and sd card formats,cds are old outdated technology now anyway just like a VHS video or a four track tape player
Nov 28, 2011 | JVC CH-X350 12-Disc CD Changer
Six to eight years ago I purchased this system that included a cd exchange system. The cd exchange system stopped working and I threw it away last year. Now my cd played states it can not read the disc...
The Bose Wave System was very expensive, and should be at least checked with someone that can give an honest assessment. It is possible the Laser Pickup Assembly may need a good cleaning, if it works you can enjoy more time with it. If it fails then it is a matter of choice.
Jan 07, 2011 | Bose Wave music system Multi-CD Changer...
I have a Lexus LX470 year 2000 and my audio system Nakamichi is not playing CDs. How do I fix it?
The only thing you can try is to use a "CD/DVD Player Lense Cleaner" preferrably one that uses fluid. you can find them just about anywhere for 15 to 20 $. Run it thru a couple times then put in a disc and try. If your discs are scratched or dirty, use liquid car polish, just a couple drops, spread around the disc, wait for it to haze then buff off with a micro fiber towel, it works wonders. Beyond that, the player would be pulled for service and the transport replaced. Average cost for a single disc is between 100-150, for a changer, up to 180 or so. Hope this helps
Aug 16, 2009 | Car Audio & Video
I can not hear any audio
If you have the correct head unit, and assuming the cable is in good condition, the it should work. Although I do remember some Pioneers needed Permanent 12V+ and ground hooked up in order to work. If this is one of those, on the changer side there should be another white plug next to the changer cable with two or three wires in it. This should be the power feed wirs for the changer. I need more info to confirm.
Jun 14, 2009 | Pioneer CDXP1280 Multi-Disc CD Player...
97 ford escort 6 disc changer
check for something maybe jammed in the system and also try a cleaner disc to see if this helps the eye to read the disc and is this an after market changer or a standard accessory on the car when bought and if it is an aftermarket check to make sure it is hooked up correctly
Dec 26, 2008 | 2004 Ford Taurus
Re: Kenwood DV 605 CD Player... Power On: Reads "Loading." All 5 CD lights are lit up but the CD changer does not turn. CD #1 appears on screen with two green lights appearing.
ace71cf.jpg We repaired this problem by taking the advice of another member of FixYa! The component had recently been packed to be shipped. After unpacking the unit when we powered up the read out only displayed "LOADING" and the CD changer door would not open. We removed the exterior cover and gently moved the CD changer one position. When it locked back into position we powered up and the unit works fine now. FixYa sure help me save perhaps a $100. or more by not sending it to the manufacturer or another shop. And it was working within minutes so we could enjoy using it right away. Thanks guys I very much will recommend this sevice to others... this was the 2nd problem we fixed that day by logging onto FixYa!!!
Z-Dawg
Dec 06, 2008 | Kenwood DV-605 Multi-disc DVD Player
JVC XL-MC334 200-Disc CD Changer Logo
74 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
