Question about Olympus Stylus 850SW Digital Camera
Don't want to lose photos.. not sure of the next step ??
850sw camera.. after you turn it on says clean card or format. If we format don't we lose all the phots on there? We have cleaned the card as instructed , with a dry cloth. What else can we do. My daughter wants to put all her photos on the compter. :) Jacqui
  • 3 Answers
Hi, Jacqui.
You are correct, if you format you loose all your pictures. When itsays "clean" I think it means to delete some pictures, the phrasechanges from camera maker to camera maker so unless it says it does not have a card or it can't read the card when there is one in there, it's probably not that the card is dirty.
For the official Olympus manual instructions...
Just in case you did not get the manual, you can download it from here, and for the photo download look in page 46 - 49
http://akamaipix.crutchfield.com/Manuals/279/279850SWS.PDF
My version of it...
What you have to do is connect the camera to a computer using the USB cable that came with the camera (one that fits to the side of the camera and has a square connector on the other side) with Windows 2000 or newer or a Mac. You can use the software (already installed on the computer) to download (copy) to the computer the photos, or you can do it without installing it. When you plug it in the first time it will take about 30 seconds to a minute for it to recognize the camera, a little pop-up will tell you when it's ready. Maybe even a window will come up asking you what to do, if you have XP or vista it will even ask you if you want to copy the photos it found to your computer... pick that one. After you do that and it shows it copying, you should better make sure it copied them to your computer... disconnect the camera (use the little icon on the bottom taskbar that says "safely Remove Hardware" or "Stop USB Mass Storage Dev" when you are top of it), and look for the pictures; the most likely place to find them is on your "user"'s documents, and in pictures. If you used the software, then look where ever you picked for when you installed.
I still recommend taking a stab at the manual so you get all the details and pictures.
I hope this helps you out. And remember, make sure you have the pictures before deleting or formating...and Always make a CD backup... I lost a lot of pics once when my Laptop got stolen, and did not have any backup of them... grrrr! :-)
Gabe
Posted on Dec 28, 2008
Card locked
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here. If these don't help, and you do end up having to format your card, see the recovery software, along with the corrupted card procedures in this blog article.
Nov 18, 2011 | Canon PowerShot SX130 IS Digital Camera
Tip
After each photo shoot, prepare for the next one
After each photo shoot:
1) transfer all photos to computer
2) format memory cards in the camera that they are used in.
3) charge all batteries
4) check lenses for dust and such. Clean as necessary. Use air if possible. If not, use something designed for the purpose.
The next time that you go on a photo shoot, you will be prepared with freshly formatted cards, and fresh batteries.
There is nothing more bothersome than not having enough memory cards for photos.
Another tip.
Use smaller capacity memory cards, this way when, not if, they fail, you will not lose all of your precious shots. Keep cards numbered, and have a pad and pen in your camera bag, with the subject of photos for each card. Also, keep your camera's manual in the bag, for a quick reference when you are out in the field.
on Dec 17, 2009 | Cameras
I was taking pictures today with no problems, then for no reason the camera started to beep and the screen displayed "FORMAT ERROR". Help, I don't want to lose my pictures. What can I do?
The card has become corrupted. You may need to use recovery software to get the photos back. Fortunately, there's plenty of good freeware. But you may also need to purchase a portable USB memory stick card reader to use with the software if you don't have one already (they're very inexpensive on Amazon). Please see this link. If the card reader also fails to recognize the card, then payparticular attention to the corrupted card procedures contained in the same link.
Aug 18, 2011 | Sony Cyber-shot DSC-S730 Digital Camera
I have a new EOS T3i. It's my first digital camera. I took out the battery to preserve it. When I reloaded it, the camera wouldn't let me take any pictures. The message said the card wasn't...
That sounds like an issue with the memory card. Yes you will lose all current photos on it when you format the memory card. It's also safe to leave the battery in the camera as DSLRs don't drain power when the camera isn't in use.
Jul 23, 2011 | Canon Cameras
My canon A480 powershot has hundreds of pics on it. I went to look at them this morning and now only 14 remain .. how can i get them back .. ??
Jessica, this occurred because you didn't intitially format the card in the camera when you first got it. It will work fine at first, but eventually what you experienced will happen. But you don't want to format your card just yet as it will erase it.
Instead, to recover your photos, you'll need to use a card reader with your computer to see if the files can be copied directly and saved to your computer. If you don't already have a reader, don't fret as they are very inexpensive. For example, here's one that I use that is very good. You may also purchase card readers at your local store, such as W or K mart, but they may be a bit more expensive at brick and mortar stores. With the card reader, you insert the card into the reader, then insert the reader into your USB port. The card then shows up as a hard drive, that you can copy and paste the missing photos from onto your computer. Also recommend using the reader in the future to download your photos from your camera, as it is very fast and relatively error free.
Now if by chance your photos still don't show up with the reader, don't fret as they're still there on the card. You'll just need to use recovery software with your reader to get them. It's very easy, here's a listing of very good freeware for that purpose.
Finally AFTER you've recovered your photos, format the card IN YOUR CAMERA using the camera's format feature. This will rejuvenate the card so it will be good as new, but it will also erase it. So again, only do this AFTER you've recovered the photos.
Good Luck!
Jun 26, 2011 | Canon PowerShot A480 Digital Camera
How do you initialise a memory card without losing the photos
You can't. Initializing (formatting) your memory card will erase the card. But formatting the card with your camera is a necessary step to either rejuvenate the card, or minimize later file error problems that will crop up if you don't do such. Backup/download the photos that are on the card to your computer before initializing.
Jun 05, 2011 | Cameras
I'm taking photos with my Samsung D860, and when I want to view the pictures taken, it says 'no image', 'file error' or 'card error'. Sometimes it also says 'card...
Actually the camera is fine and the cause of problem is memory card, Mostly cheaper cards do this but the original cards don't. And as far as concern that you have lost many precious pics, No need to worry about it. Just install any recovery software on your PC and with the help of the software you can get back your pics, Secondly, shift all your pics on memory card in your PC and then format the card through camera, this will solve your problem.(Remember that run recovery software before you format the card if you need to get back your data from memory card)
Thanks
May 13, 2011 | Cameras
XD card asking to be formatted
get a xdcard recovery program off the internet some of these programs you can get for free. This correct this issue alot of the times.
May 27, 2009 | Olympus Stylus 850SW Digital Camera
Konica Minolta Dimage Z2 camera will not read any SD card
hi there
you don't say how big the card is, my guess is its bigger than 2 gig which is the maximum allowable size for that camera.
hope this helps
beergut707
Oct 20, 2008 | Konica Minolta DiMAGE Z2 Digital Camera
Olympus Stylus 850SW Digital Camera Logo
122 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
