Question about Samsung SyncMaster 17" TFT LCD Monitor
I lost my remote for my samsung syncmaster 170
I'm a real novice and i can't figure out from your post how to change anything. Do you think you could take the time to post or email me at WindiSoriano@comcast.net excatly how to use the menu with no remote? i am totally clueless as to what to push. i push menu but don't know what keys to use to get to the options i want to change :)
  • 225 Answers
SOURCE: i cant unlock osd of my samsung monitor , sync master 551v
Please try again to turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu. regards
Posted on May 28, 2009
FixinFax
  • 3085 Answers
SOURCE: Samsung 191T Blank
You need a fluorescent back light and inverter kit. Available on eBay.
Posted on Jun 11, 2009
  • 1684 Answers
SOURCE: Samsung Syncmaster 214T flickering
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should workfine. We just posted a repair guide showing how to remove the case ans replace the parts. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 25, 2009
prashanthcl
  • 460 Answers
SOURCE: samsung syncmaster 245bw menu buttons don't work
It is a hardware problem. you can repaired it from service center.
Posted on Nov 13, 2009
dhecom
  • 233 Answers
SOURCE: I have a Samsung Syncmaster 510n lcd monitor.
Look at this tip for more details. <<< Low cost Solution :)
good luck.
Posted on Feb 23, 2010
2333 sw modeline
Samsung SyncMaster
Part Number: LS23CMZKFV/ZA
Product Line
Samsung SyncMaster
  • Native Resolution Full HD (1080p) 1920 x 1080
  • Contrast Ratio
    1000:1 / 20000:1 (dynamic)
  • Color Support
    16.7 million colors
  • Horizontal Viewing Angle
    170
  • Vertical Viewing Angle
    160
  • Brightness
    300 cd/m²
  • Horizontal Refresh Rate
    75 kHz
  • Vertical Refresh Rate
    61 Hz
  • Max H-Sync Rate
    75 Hz
  • Max V-Sync Rate
    61 Hz
Dec 18, 2017 | Samsung SyncMaster 2333SW 23" LCD Monitor
I am using a new computer and I have lost the disc for my monitor to use on this computer. Is there a Samsung site that I can go to do download the drivers I need for this computer. it is SyncMaster...
There are no drivers on the Samsung site that I could find.
That said, you don't need drivers for your monitor. If your monitor isn't displaying anything with your new computer, try turning your computer completely off, make sure your monitor is turned on and plugged in to the computer, then turning the computer back on. Windows should automatically detect what resolutions the monitor supports and your monitor should start working.
Mar 07, 2011 | Samsung SyncMaster 512N 15" Flat Panel LCD...
Syncmaster 170, got sound but no pic, is there a reset button?
this has no reset button, there is an electronic component that failed inside, bring the unit to a qualified monitor repair center near you..
May 09, 2010 | Samsung SyncMaster 17" TFT LCD Monitor
Cant turn on lost remote
Good day sir/maam, there are really few manufacturers of TVs that adopted to use a remote to turn on the TV. so if the remote is lost, you cant power it on, check out your dealer if they have a spare remote, or visit any electronics depot for any universal remote that your TV is compatible with, ask the dealer if it would work on your Samsung TV.
Note: browse your user manual, if it has a secret button or a combination of buttons to power on your TV. that may help.
Aug 07, 2009 | Samsung SyncMaster 940MW 19" LCD Monitor
Samsung 191T Blank
Jun 10, 2009 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Samsung syncmaster 910mp TV connection
I believe you are describing this connector adapter.
http://www.thesource.ca/estore/ catalog number 2780265
Jan 16, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
SAMSUNG 170 MP LOCEKD-UP
On the front panel press the Menu button for about 5 seconds. Once you press it the OSD will pop up. Keep holding the button until the OSD disappears. The setup should be unlocked now.
Jun 21, 2008 | Samsung SyncMaster 17 in. LCD Television
Would an inverter from a Samsung Syncmaster 910MP work in a Samsung Syncmaster 940MW?
The Samsung SyncMaster 940MW monitor has an issue with the power supply # IP-46135T going out. The flashing power light or not turning on are the classic symptoms of this issue. Check out our web site at: www.ccl-la.com We have a step by step repair guide posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping. If you have any additional questions just let us know at: tech@ccl-la.com
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Mar 09, 2008 | Samsung SyncMaster 940MW 19 in. LCD...
Computers & Internet Logo
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
