Question about HP LaserJet 6L Printer
Laserjet 6L This printer shows all 3 lights, and won't run. If I press the front-panel button, the middle light goes out (I read somewhere that this indicates a fuser problem; can anyone confirm this?) When the printer is first powered on, the scanner motor runs up and then stops. Very occasionally, the transport motor also runs, and the printer goes to the ready state. However, if I then press the button for a test-print, after the data has been prepared, the scanner motor runs briefly, (and sometimes the transport, too); but then I get the three-lights error. I have measured the resistance of the fuser element, and I get about 105 ohms (the manual says it should be 30 ohms). There appears to be 12V AC across the element, which doesn't seem to be anywhere enough to me. Would someone kindly enlighten me as whether the fuser is the real cause, or whether it could be a power-supply problem? Thank you.
  • John Howard Apr 24, 2007
    Thank you, dodgecharger. The 12 volts turns out to be stray pickup on a high-impedance voltmeter (as confirmed by a low-impedance meter). I don't see a real voltage at any stage, and I'm beginning to suspect the control circuit. Incidentally, I traced out part of the power supply, and the fuser is driven from 230V AC, via a triac. The quoted 30 ohms could be for 110V mains, in which case 105 ohms would be about right for 230V. I shall have to probe further.
    Scholar:
  • 77 Answers
Check the thermistor that measures whethter the fuser is getting hot enough. May have crud built up on it or defective. I concur with dodgecharger that the fuser is the problem. As long as your going to have it apart, invest in a separation/feed assembly kit. I'm sure you're having problems with mulitple paper feed problems by now. It's still a tank of printer. Always liked them. Hope it helps Ed
Posted on May 26, 2007
    Novelist:
    Champion:
  • 254 Answers
The way-off ohms reading would suggest the fuser element is bad. If the fuser is not heating, a sensor will tell the logic circuitry so, and thus your error, and no-print condition. I'm reasonably certain the self check at power on checks for fuser heating. Guessing here, but a heating check is likely done prior to a printjob being completed too. If you can check the voltage at the fuser during the self check or as it readys to print, this would tell you if full voltage is applied. The 12 volts you are seeing probably is a standby voltage. The HP laserjets I've worked with all have higher heating voltages than this. You might be able to find some more accurate info elsewhere on the 'net.
Posted on Apr 24, 2007
SOURCE:
Drum light on HL2030 won´t go off!
Open the front door, and press the go button until the lights flash, after closing, press the go button 3 times for a printout showing the drum as full again. The instructions come with the new drum...
Jul 30, 2009 | Brother HL-2030 Laser Printer
Display reads "card slot not initialized"
Turn the printer on.
2 As the printer performs its power-on sequence, press and hold the PAUSE/RESUME (HP Color
LaserJet 4600 models) or MENU (HP Color LaserJet 4610n and 4650 models) button until all
three lights on the control panel are lit.
3 Press . The message INITIALIZE DISK appears on the control-panel display.
4 Press The printer initializes the hard disk and continues its power-on sequence.
Feb 26, 2009 | HP LaserJet 4650n Printer
LASERJET6L IS NOT WORKING PROPERLY
it would depend if its a problem with the paper transport, or a fuser problem.
we dont have a crystal ball, you need to tell us if it jams or doesnt print at all, or tell us the light combination at the front, press the front button and you get a second set of combination if it all 3 lights are lit.
Nov 19, 2008 | HP LaserJet 6L: HP 6L Monochrome Laserjet...
Laserjet 2015n powers up for 2-3 seconds - but no lights come on - and then it powers down.
Please perform the following.
Super NVRAM initialization Turn off the printer.
  1. Press and hold the Go button.
  2. Turn on the printer and continue to hold the Go button for at least 50 seconds. During this process, the Attention , Ready , Go lights turn on. Then the Attention and Ready lights turn off, leaving only the Go light illuminated.
  3. Release the Go button. The Go , Ready and Attention lights turn on.
  4. Press and hold the Go button. All lights turn off. During the next three seconds, the Go , Ready and Attention lights turn on in that order, one per second.
  5. Release the Go button to perform the initialization. The control panel lights begin cycling from front to back. After the Super NVRAM initialization process is complete, the printer returns to the ready state.
Sep 19, 2008 | HP LaserJet P2015dn Printer
LaserJet 6L Prints Outlook content too light
You can run into these problems when using non OEM toner cartridges. It sounds like anything that is printed in a light gray is not printing correctly.
Apr 28, 2008 | HP LaserJet 6L Printer
Hp laserjet 6l. i neeed heeeelp
Look at cleaning the glass panel over the laser lens. It is quite likely that toner, dust or other muck has fallen onto the lens. The other item to replace is the PCU/Drum unit as there may be damage on it. Clean the lens first though.
Aug 13, 2007 | HP LaserJet 6L Printer
HP laserjet 6L
Get it cleaned in paper sensor area and check up the drivers as well as data cable which connects, the pc and printer. Change the data cable if necessary. Give me feedback so that may be some more help can be provided.
Mar 12, 2007 | HP LaserJet 6L Printer
HP LaserJet 6L Printer Logo
133 people viewed this question
Clive
Clive
Thomas F. Schneider
