Question about Dell Inspiron E1505 Notebook
2-3 inch swath of green from top to bottom of screen, in center
Dell Inspiron E1505 PC Notebook Green lines from top to bottom of screen in center about an area two inches across. Seems like some sort of leakage. Is the video card replaceable?
  • Anonymous Apr 09, 2009
    I have fat pale green line. in the middle of my screen, top to bottom. I find a bulldog clip attached on the top of the monitor above the line makes it go away,
    Scholar:
  • 177 Answers
Might be a problem with your memory,your video driver,or the screens inverter board.
If you have more than 1 bank of memory,try removing one bank at a time and see if this corrects the problem. If so ,replace the bank that was removed when your screen works properly.
Also ,try updating the driver through the "Windows Update" service. If neither of those works, you may have a faulty inverter board.
Posted on Jul 22, 2009
Dell inspiron laptop grey dotted line across
You could try removing the display device in device manager then rebooting. At boot up windows will reinstall the drivers.
Check for new display drivers at Dell's support site.
Mar 13, 2014 | Dell Inspiron E1505 Notebook
Dell inspiron e1505 laptop has a thin light green line on far left of screen and a thin pink line approx an inch to the right of it. Both lines run from top to the bottom of the screen. I'm assisting in...
If you were to plug it into an external display, that will tell you whether it is a VGA uProcessor fault or a screen fault. If it is a screen fault, checkout ebay for a replacement screen.
Hope that helps.
Jan 25, 2011 | Dell Inspiron E1505 Notebook
Bluish green colour vertical line is coming in my
Your laptop screen has been faulty. you can checked it from service center.
Nov 13, 2009 | Dell E173FP 17" LCD Monitor
I have a red line in the same notebook, dell insp 1501
It's a faulty screen.
Here is how to remove old screen.
Then order new screen by DELL PART NUMBER (green), which is on the back of the screen and looks something like that:
If you will replace screen with any other (not with dell part number), then you risking, that screen will be dark and adjustment of brightness will not work.
Aug 02, 2009 | Dell Inspiron 1501 Notebook
Dell laptop inspiron e1505 no boot green light comes on for about 5 seconds, plugged into a working monitor and still no screen, reset ram, and I dont hear any fans or hard drive running.
could be a case of overheating.
for starters clean the fans with a mild vaccum...
If this doesn't help, the laptop needs to be opened and cleaned up internally, also apply fresh heat release compund to the processor.
That will solve it.
Don't forget to rate this answer if it helps
Jul 21, 2009 | Dell Inspiron E1505 Notebook
Can I use WXGA 15.4" lcd panel instead of WXGA+ 15.4" for E1505?
Seeing that the upgraded version was your previous version, go ahead with the screen change' it should be fine.
Hope I helped
- donman92
Jun 10, 2009 | Dell Inspiron E1505 Notebook
Dell Inspiron E1505 shows green pixels instead of black
the color pixels are different sections in the screen and the green section might be cracked
Apr 24, 2009 | Dell Inspiron E1505 Notebook
Dropped laptop. Everything seems to work, but screen messed up
Screen cracked, you will need to order a new screen and replace it.
Here is how to replace screen on Dell Inspiron E1505.
Mar 29, 2009 | Dell Inspiron E1505 Notebook
Black dotted line on monitor
Hi , Do not panic ,It is to do with the display driver which you need to reinstall.
Jan 11, 2009 | Dell Inspiron E1505 Notebook
Dell Inspiron E1505 Notebook Logo
145 people viewed this question
Alun Cox
