Question about RCA L37WD12 37 in. LCD HDTV
RCA 46" LCD TV - HDMI Stopped working overnight
HDMI port was fine when we turned the TV off and then did not work the next morning. All three ports say "Signal unuseable or undetected." We replaced the HDMI cable but still had the same problem. The component cable and regular RCA ports seem to work fine. We are running it with a DirecTV HD receiver that is ~1 month old, as is the TV. Any ideas?
  • mrshade81 Feb 04, 2009
    I have the same problem with my 42" RCA. The HDMI ports worked for a few weeks then they just stopped. For a while the BluRay HDMI worked while the one hooked up to my Time Warner box didn't. I tried switching them around and getting new cables and getting a new box and still I have nothing. At this point I want to drop-kick it into the ocean.
3 Suggested Answers
SOURCE: vizio and the directv dvr
try Goldstar and LG codes
Posted on Jan 27, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: rca 46 inch lcd tv, no sound
Go into the menu and change the HDMI Audio settings - the manual will give you a breakdown on this. HDMI is a little glitchy - if you were using red/gree/blue cables before switching to HDMI, you might want to consider going back to them - just an opinion.
Posted on Jan 03, 2009
All four HDMI ports on my LCD TV failed all of a sudden, but VGA port still works. Why?
Corrupted firmware. A firmware update might be necessary. Contact the authorized service center.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 09, 2014 | Sceptre Televison & Video
Samsung LN-T4671F HDMI PC hookup and Audio Problems
Pls bear with me, have you tried not using the HDMI/DVI cable but simple straight connection PC > Standard 15 pin VGA cable and audio cable that has "stereo mini-plug" on both ends to the PC IN of the Samsung?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 09, 2008 | Samsung LN-T4671F 46 in. LCD Television
46" Samsung LNT4661FX /XAA LCD TV volume problem.
If sound on one HDMI and not the others---all three should go to the same board--either something is not connected inside or the replacement board is the issue---Samsung is known for making boards with the same part number on them that from week to week have different features or do not have certain features.
Try to trace where the working input goes and if to same board as other two you know what to suspect.
Jun 15, 2012 | Samsung Televison & Video
Both HDMI ports are bad due to lightening strikes. What do I need to do to fix this? Can you suggest part numbers?
The main tv Tuner signal board have problems and all those HDMI insert ports are shorted dead,those HDMI insert ports are put on by wave soldering machine and fused by iron core solders joints to the main tv Tuner board itself.These HDMI insert ports are not replaceable by hand soldering equipments or can buy those HDMI insert ports individually anyway.Tv still work wright?Yes? Why don't u just skips the used of those HDMI insert ports all together and tries used those RCA component cable connections like AV1 and AV2 on the tv.Or u must have some mechanicals skills and like take things aparts and putting back together again?Yes?Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv main Tuner signal board for the replacement to able to used those HDMI insert ports again.I have the same problems with my Samasung 46" all my HDMI insert ports are dead too,but the tv still functions.That what i did used RCA cable components connections for my cable box and blu Ray player.
Aug 03, 2011 | Sceptre X42BV 42 in. LCD TV
Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Jun 16, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
46" LCQ VIZIO WON'T TURN ON ALL OF A SUDDED
IT SHOULD BE UNDER WARRANTY. TAKE IT TO AN AUTHORIZED VIZIO SERVICER.
Jan 30, 2009 | Vizio L32 32 in. LCD HDTV
I don't mean to sound ignorant, but can I assume you have already checked your Source Selection just incase someone hit a different button on shutdown ?
Sometimes when I just set the remote down can sometimes change a setting on the TV, I thought maybe the same may have happened to you too.
Jun 03, 2017 | Televison & Video
RCA L37WD12 37 in. LCD HDTV Logo
740 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
