Question about Linksys Wireless-G WRT54GS Router (e125894)
Connecting a linksys wrt54g to a netopia modem
The netopia only has a phone line , ethernet, usb, plug on back
how do you connect to linksys wrt 54g wireless router
    President:
  • 623 Answers
Is this an ISDN modem?
Generally: Netopia Ethernet out -> Linksys WAN port with a standard ethernet cable.
(Not the yellow LAN ports! - They are for your computers/printers.)
Posted on Dec 28, 2008
I have the linksy WRT 54G. My modem went out so I bought another AT&T modem and now the router will not work and I know not what to do. Help Thanks, Vickie
You might have to call ATT, they will have to register the new modem for you. Without this step, you won't have Internet access. Good luck.
Jun 26, 2011 | Linksys Wireless-G WRT54G Router
My wrt 54g ver. 7 cannot connect to siemens modem what is the configuration for this
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Nov 13, 2010 | Linksys Wireless-G WRT54G Router
Cannot connect to internet via router WRT 54GS
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
then you need to connect the computer to the router and the modem to the router.
May 08, 2010 | Linksys Wireless-G WRT54G Router
Need to add Linksys WRT54G-TM wireless router with Linksys SPA 2102 phone adapter
your SPA2102-R seems to have one ethernet connection and one internet connection.
your WRT54G-TM seems to have one internet connection and 4 ethernet connections.
What you are trying to achive is; plug a ethernet cable into the ethernet connection on your SPA2102-R then plug the other end into the internet port of the WRT54G-TM
hope this helps, I have assumed that you intend to use a DSL broadband supplier not ADSL.
if you are changing service from DSL to ADSL then your WRT54G-TM needs to be first in line configured and working. then plug the internet port from the SPA2102-R into any of the WRT54G-TM ethernet ports.
Nov 06, 2008 | Linksys Wireless-G WRT54G Router
Wireless router installation
Please see my response to this question. Your university's connection is most probably a LAN connection, so you'd need to follow the instructions as if you had a cable internet connection (unlike DSL, a LAN connection and cable internet connection don't require authentication with the ISP).
Jan 07, 2008 | Linksys Wireless-G Broadband Router
Dificulty in configuring wrtg4g
There are three major steps to setting up a wireless router.
First set up WAN side access to the internet. For this you need information about your internet service provider. Please respond with your internet service provider's name or better yet a link to their help/support website.
I assume you already have access to configure the router at 192.168.1.1 if not please do the following. Open Internet explorer and enter 192.168.1.1 where you would enter fixya.com and press enter -- do web pages appear in your screen from the wired computer. If so we have manual access to configure the router. If not let me know.
Please reply with a response to this message.
Second we will test wireless connections to the router
Third we will secure the tested wireless connections to the router.
This process will require interaction and several iterations of instructions to complete. Please add a comment to this request with the necessary information if you with to proceed in this fashion.
Jan 01, 2008 | Linksys Wireless-G WRT54G Router
Setting up linksys adsl2 modem
The ADSL, Ethernet, and USB ports are located at the back of a Linksys modem. These ports are where the phone cable and computer will be connected. The ADSL Line should be connected to the ADSL port and the computer either be connected to Ethernet or the USB port., If u r using a ethernet cable no need to run the setup cd just connect the ethernet cable and contact ur isp..
do not worry about ur sagem modem, let it be inside.. just connect ethernet cables alone..
To setup a Linksys ADSL Modem with usb cable you need to perform two steps:
  1. Connecting the Devices Together
  2. Installing the USB Driver
Step 1:
Connect the phone cable to the wall jack with ADSL service and then connect the other end to the ADSL port of the modem.
Step 2:
Make sure the power adapter is plugged to an available power outlet.
Step 3:
Connect the USB to the USB port on the back of the modem and then connect the other end top the USB port of the computer.
Step 4:
Power on the modem. After connecting the device together, install the USB driver. For instructions, follow the steps below.
Step 1:
Power on the computer.
Step 2:
When the Hardware Update Wizard window appears. Click Install the software automatically (Recommended).
NOTE: Windows XP has pre-installed drivers for the ADSL2MUE and will automatically install the USB driver for the modem.
Step 3:
Click Finish.
Nov 06, 2007 | Computers & Internet
ROUTER CONNECTIVITY
Ok, do a troubleshooting session.
Unplug the router from the internet modem.
Try at first to connect using a Network cable from you PC to one of the LAN sockets.
Can you access http://192.168.1.1  with your web browser?  (the configuration page)
     If yes it is possible that the router has the same address as your adsl modem.
    change the router address to something 192.168.0.1 instead of 192.168.1.1
     Save your changes. Plug your WRT to the adsl modem and try again.
     Does the internet work now with a wired connection ?
If the above does not work can you "ping" the machine ?
      ping 192.168.1.1
if none of that works try doing a hard reset... heres a little guide (off the DD-WRT wiki)
http://www.dd-wrt.com/wiki/index.php/Reset_And_Reboot
Oct 09, 2007 | Linksys Wireless-G WRT54G Router
Cannot access router webpage
Make sure your firewall and anti-virus are switched of then try and connect to the webpage
Jun 13, 2007 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54GS Router (e125894) Logo
157 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
