Question about Fuji MX-2900 Zoom Digital Camera
Lost cable for downloading pictures from camera
I have misplaced the cable ( mini phono to pc serial connector) that came with the camera, so am unable to download any pictures.
I may possibly still be able to get another one (as the camera is now discontinued), but can l purchase a cable that plugs from the camera (mini phono socket) into a usb port instead?
  • 198 Answers
SOURCE: can't download pictures from camera
perhaps your Fuji download program is corrupted, or your cable has been broken. Most computers now have a direct plug-in for your memory card, as well as plenty of built-in programs to download your pictures. I like the Vista Photo Gallery (come to think of it, it is the ONLY thing I like about Vista. At any rate, unplug your xD chip from the battery compartment (you can just pull it out, or push it and it pops up), (and close the battery compartment, or you will have to reset the date and time), plug it into your computer, and wait for a bunch of programs to pop up eager to download your photos. If that doesn't work, you may have a bad chip--but if you had a bad chip, you couldn't view your pictures on your camera. If you have XP, you should be able to see the xD as a new drive if you plug it in--not sure which programs will pop up, but you may be able to move the pix just like any files from one drive to another. Good luck. Incidentally, if you need a new cable, internet charges range from 3 to $25.
Posted on Jan 21, 2008
Steve5
  • 423 Answers
SOURCE: cannot upload pics from camera to PC
Hi Ray;
Try uninstalling the Fuji software completely, through the Windows control panel. Don't use the supplied software at all. Make sure the camera is unplugged from the computer. Open "my computer" and note which drives are present. Now plug in the camera (still turned off) to the USB port. Turn the camera power switch on. Wait and see if a new drive icon shows up. It may take a minute or so. If you get a new icon (probably Fuji DSC or similar), you should be able to open the new drive and access the images through the various folders. If not, can you see images on the camera screen (when not connected to computer)? If yes, maybe a bad cable. If no, could be corrupted images on card.
Posted on Feb 05, 2008
SOURCE: trying to download pictures; can only see usb icon on camera
unable to delete picture that is causing the read error message. not able to upload any pictures that were taken after the picture that is causing the read error message
Posted on Jun 14, 2009
  • 11967 Answers
SOURCE: camera won't download to pc
Use a card reader to download your pictures to a folder you create on your desktop. Is your camera still able to take new pictures?
Posted on Oct 10, 2009
  • 8 Answers
SOURCE: When I plug the camera into my PC nothing happens.
usb port might be blown.. try another port first, then try manually up loading.. go to start-my computer- it should be under removable storage.
Posted on Nov 09, 2009
Need USB cord
It could be a mini USB connector, but on Wikipedia, you can find all USB connectors with name and picture.
Mar 21, 2014 | Hello Kitty Sanrio - KT7002 - Compact...
What is the cable not supplied with the rt151 that i need to install ,the cable plugs in the front of amp then the out audio of the tv of th
Typically, the cable would be a mini phone jack cable. The connectors would be called either 3.5 millimeter or 1/8" phone plugs. Some cables have the 1/8" jack on one end and the other end might have 2 RCA connectors. The RCA connectors are also called phono plugs. According to the specs I have found, the system has both phono jack and a mini phone jack. The cheapest solution is a 1/8" stereo male to 1/8" stereo male mini phone cable. Here is a link to a place that several types to choose from, as well as pictures:
http://www.cablesforless.com/Sub-Mini-35mm-Stereo-Phono-Cables-C13.aspx?gclid=CMX96M_aq7MCFaOaPAodC1QAyQ
Oct 31, 2012 | Audio Players & Recorders
Epson Photo PC Mini Cable
you can use the same serial cable for the model photopc 500 600 700 it is 8pin NOT 5pin
you can see the specs here for your camera
http://files.support.epson.com/pdf/phpc__/phpc__sl.pdf
and it it at ebay just type the right name
EPSON PHOTOPC SERIAL CABLE 8 PIN
Oct 08, 2009 | Epson PhotoPC 650 Digital Camera
Missing CD-ROM & cables for Curtis Digital Camera Model# DCD5159
Well it appears that Curtis has discontinued all support for this camera. You might be able to obtain a USB connector that fits the camera online. Most use the standard/micro USB connector. As far as drivers if Curtis does not have it on their site then they might be tough to find. If you are using Vista the it might recoqnize the camera and install drivers automatically. If the camera has removable memory card you could remove the card after taking the pictures and put in the SD port of the computer and transfer the pictures onto it.
Sep 19, 2009 | Cameras
Misplaced USB Cable for Toshiba PDR-3330
The USB cable for cameras is easily availalbe at most computer or camera stores. You can take your camera along just to make sure one end fits properly to your camera.
The USB cable would have mini connector on one side and a standard male connector on the other side. (cost around $7~10)
Please rate our solution and thanks for using FixYa!
Mar 05, 2009 | Toshiba PDR-3330 Digital Camera
I need to locate a usb adapter that I can upload pictures 2 PC.
Hello Charlotte,
This camera takes a standard USB cable that has a "4 pin mini B" end on it. You can buy this cable at most camera and computer stores. There is another type of "mini" USB connector so make sure you get the 4-pin mini B type. For best results, take the camera with you and make sure the cable fits into the slot on the camera before you purchase the cable - that way there is no way to get the wrong cable. Good luck
Dec 28, 2008 | Fuji FinePix A303 Digital Camera
Downloading pictures from my panasonic DMC-LZ2 to my HP Pavilion dv5020us notebook pc
There is a guy in South Carolina that has good used parts for your LZ2. I think his email is gerald.ray@aa-ark.com
Mar 02, 2008 | Panasonic Lumix DMC-LZ2 Digital Camera
Lost software
You can download what you need from Fujifilm, here.
Dec 29, 2007 | Fuji FinePix A350 Digital Camera
Lost Cable
These are generally a standard mini to Firewire cable, available at many retailers, take your camera with you and look at the available cables. Panasonic has them for sale as well.
http://www2.panasonic.com/consumer-electronics/support/Supplies-Accessories/Cameras-Camcorders/Digital-Camcorder-Accessories/Cables/model.PV-DDC9
Nov 18, 2007 | Panasonic PV-DV103 Mini DV Digital...
Fuji MX-2900 Zoom Digital Camera Logo
49 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
