Question about RCA RT2500 System
RCA rt2500 "CHK SPKR" comes on when i turn it on.
I KNOW THIS is some kind of code, but how do i correct the problem. I have checked all of the fuses and am @ a dead end. Please help!! or email me @ cajamiso@nmu.edu thanks for your time. CASEY
  • 336 Answers
"CHK SPKR" Check Speakers. Remove all speaker wires and turn on receiver. If it still says check speakers, you have an amp that needs output transistors or possibly just soldering of an emitter resistor but thats rare.
Posted on Jan 14, 2009
  • kevin77493
    kevin77493 Feb 02, 2012
    I had this problem. How do I fix it though? I removed all of the speaker wires and it still says check speakers. Is there a way to replace this in home or am I sol?
What does it mean when u push the power button and the words ''chk spkr'' flashes on the display and still wont turn on??
The system connects to speakers with a certain impedance, i.e., 8 ohms, 4 ohms, etc. If you have connected the RCA speakers there may be a bad connection or the speaker(s) may be defective
Dec 08, 2012 | RCA RT2250 System
It says chk spkr when i try to turn it on how do i get it to work agaiun?
You probably have a blown channel. but check for a shorted speaker wire or bad speaker. Remove all speaker wires from the rear of the receiver if it still says check speakers when turned on, then one of the output channels is bad.
Feb 12, 2011 | RCA RT2500 System
The display says "CHK SPKR"
It's telling you it thinks tghere's a short on the speaker outputs. With NO speakers, that is bad.
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Jan 24, 2011 | RCA RT2500 System
I urgently need a Clarion cd1500r installation manual or wirng color codes
Hello, here is Clarions wire codes.
FRONT Right SPKR: +Gray -Gray/Blk,
FRONT Left SPKR: +White -White/Blk,
REAR Right SPKR: +Purple -Purple/Blk,
REAR Left SPKR: +Green -Green/Blk
Brown Wire = Phone Mute Lead (If applicable)
Yellow Wire = 12V battery lead in (Connect directly to battery)
Red Wire = 12V Ignition wire (Connect to Acc switch)
Blue/White Wire = Amp turn on lead
Black Wire = Chassis Ground
Orange/White Wire = Illumination Lead (Connect to dimmer switch)
Blue Wire = Auto Antenna Lead (lowers power antenna Do not use for Amp Turn on! Use the Blue/White Wire for Amp,EQ, Ect.. turn on wire only
RCA Connectors if applicable:
Black RCA Harness:
White RCA = Rear Audio Left Sub Output 1
Red RCA = Rear Audio Right Sub Output 2
Gray RCA Harness:
White RCA = Front Left Audio Out to amp
Red RCA = Front Right Audio Out to amp
Oct 19, 2010 | Clarion Car Audio & Video
CHK SPKR appears an turns off the system
It means to check your speaker connections for shorts.
Feb 19, 2010 | RCA RT2280 System
RCA RT2500 will not turn on
press and hold power button while unplugging and plugging power supply cord may take a few tries worked for me
Aug 16, 2009 | RCA RT2500 System
F61
To my knowledge, an F61 error is a blown fuse. A workaround is to replace the fuse with the same value but specify slow blow.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 09, 2008 | Panasonic SC-AK24 CD Shelf System
Chk spkr
That message means that you have a bad speaker or you have a bad amplifier IC most of the time. The amp circuit could have some other problem, but more times than not it is the amp IC.
How to check if it is the speakers or the amp circuit:
Unplug the speakers and turn it on. if you do not get the error message you have a bad speaker. If you do get the error message you have an internal amp problem. Then start plugging in speakers one at a time. If the unit turns on and stays on for a few minutes, turn it off and then plug in one more speaker. Keep doing this unit the unit gets the error message and when it gets that message you know that the last speaker you plugged in is the bad one.
Now the bad news
RCA no longer sells parts for their audio equipment. When the supply they have on hand right now is gone, thats it, no more RCA parts.
Now the good news.
The amp IC they use is a generic type that you may be able to get from another source.
But that is only good news if the amp IC is bad. It is the likely suspect, but without troubleshooting it on a test bench with the proper equipment, that can only be a good guess.
If you have found this help to you a good rating would be really appreciated.
Feb 17, 2008 | RCA RT2280 System
Chk spkr error message
Your problem is the output IC's The case where you say the speakers buzz tells you theres a short in the audio outputs. If your unit didnt shut off, the speakers would fry and the unit would also smoke. These are solid state devices and are soldered in, and are not concidered user serviceable parts, unless you know how to solder and trouble shoot Stereo systems. This is a job for the pro if you want it fixed. Good Luck
Jun 22, 2006 | RCA RT2280 System
RCA RT2280/RT2250 RECEIVER
If you have speaker wires that have strands, you may be getting a short if one small strand is shorting across the terminals, or a poor connection. Check carefully, perhaps even by disconnecting and reconnecting the wires. Also check for proper polarity - positive to positive, negative to negative. (unlikely since it just started). You can also get a new set of wires and check speakers one at a time to see if it goes away. or get another speaker that works and then replace each one with that speaker in turn to see if it resolves it. Good luck
Mar 23, 2006 | RCA RT2500 System
RCA RT2500 System Logo
952 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
