Frigidaire frontload washer
Looking to buy spider arm/shaft separate from drum for frigidaire frontload washer, drum is fine, do you know where we can purchase just the parts? model number fwt445ges2
  • 318 Answers
You dont need to buy the shaft, "spider".it has a lifetime warranty on the inner tub and should be replaced by frig. what you need is the entire tub as the shaft is not available seperately. if you cant get this under warranty then i would suggest buying a new unit as the outertub and bearings are what is worn causing your noise in spin. you may have to pay a warranty dealer to get the tub covered, but the whole job is very labor intensive and most people cant do it, even if you are good with tools. call frigidaire and see if they will cover the repairs first.
Posted on Dec 28, 2008
SEARCHING FOR SPIDER ARM FOR FRIGIDAIRE WASHER MODEL # BLTF1040DS0
Fixya is not a buying service. Check with a local appliance parts supplier.
Nov 09, 2016 | Frigidaire Washing Machines
The drum on my kenmore elite 45862 frontloader seems to have seperated from the outside ring. can it be fixed or do i need a new washer
the spider trunnion has broken apart that connects the inner basket to the rear shaft where power connects from the drive motor to turn the drum,most brands you must replace the inner basket and spider trunnion as a unit, as they are not sold separately it will cost you about $350.00 plus oversize shipping
Oct 27, 2012 | Washing Machines
I have a LG wm2277hw washing machine. the drum will spin a little and then make a scaping sound like friction. The drum has a lot of play in it. Is there a hard plastic washer or shim that wears out. The...
The symptoms that you describe sound like the spider or support arms of your washer has failed. It the part that holds the wash drum true in the plastic tub. It's a rather difficult job to replace the spider since the washer has to be taken apart to get to the spider. Fortunately, LG does sell the spider, instead of making you buy a new spider and drum. You may need to also replace the plastic tub parts if they are too damaged to be reused. Get a few estimates before deciding whether to repair or replace.
Mar 21, 2011 | LG WM-2277HW Front Load Washer
My frigidaire gltr1670a washer is making a banging noise when on the spin cycle. I took the bottom cover off and watched the drum it doesn't seem to be from the outside of the drum cover it sounds like its...
It sounds like the spider arm supports in your washer has failed. The spider arms hold the stainless steel wash drum to the axle. You need to stop using the machine immediately since the wash drum is flopping around the plastic tub. It is an expensive fix. The replacement drum/spider can cost over $300 with shipping. Get a few estimates before deciding whether to repair or replace. Sorry.
Dec 09, 2010 | Frigidaire GLTR1670A Front Load Washer
During the spin cycle there is a very loud knocking noise,
Could be the spider arms are broken. You can confirm this by turning the tub by hand, if you hear any kind of thumping sound as you turn the tub, then the spider is broken. The spider is the support arms that hold the wash tub to the drive shaft. It's very expensive to repair.
If there is no thumping sound when you turn the drum, it could be that one of the supports or spring is broken. Hope this helps.
Jul 23, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
Hard bang on spin with my frigidaire gallery frontload washer
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 15, 2010 | Frigidaire GLTF1040A Front Load Washer
Front load washer loud noise and drum loose but not dropped
Spider arms attached to stainless steel drum inside of tub have probably broken. This is a known problem with Frigidaire front loading washing machines. The stainless steel drum has a 25 year warranty but this does not include the spider arms. You cannot buy the spider arms separately, you have to buy the unit as one. The drum cost about $250.00 and probably about $300.00 in labor to install. You can do it yourself but it is pretty involved. Good Luck!
Jan 02, 2009 | Frigidaire GLTR1670A Front Load Washer
Drum/frigidaire washer
wow thats a long hard job ,,overhaul....the part your looking for is the spin tube surport,,you have to take the hold drum out than seperate the front tub from the back bearing tub,,and pull wash basket out though front..,,also if you had a leak or surport broke and is making noise.. change back bearing tub too.i recommend a professional technician...but if you want to do it your self ..post question how to change wash basket,,glad to help
Dec 27, 2008 | Frigidaire ATF6000ES Front Load Washer
Terrible noise on spin cycle, stainless drum is loose inside plastic tub, wore the front half of the plastic tub down due to friction. Took washer completely apart, found the spider arms cracked. It...
Just had the same problem 1 month ago. My Whirlpool Duet front load made that terrible noise. 2 of the 3 spider arms were cracked. I hade a new hole tub with the spider arm and the shaft , because it is 10 years limited waranty . But if it is not under waranty it costs about 270$ for that tub you can buy it from many appliance parts web sites on the net. Good luck, huge job to all remove that thing
Dec 03, 2008 | Washing Machines
During spin cycle started making loud noise now drum feels loose DURING SPIN CYCLE DRUM SOUNDS AS IF IT'S HITTING SIDE.. FEELS LOOSE WHEN I PUSH IT AROUND FRIGIDARE GLTF1040ASO
ckd your warranty papers sounds like rear drum support(spider) has broken will require new basket and rear drum half est cost 400-600 spider is not a separate part and rear bearing is probably damaged that too is not a separate part and require rear tub replacement
May 20, 2008 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
510 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
