Question about Xante PLATEMAKER 4 Laser Printer
Screens Picking off on press
133/1200 screens look great on the plate, but soon disappear once on press. Doesn't take long, either, 30-50 sheets. Have done everything Xante told me to do, all settings adjusted. Tried several fountain solutions. Any ideas?
  • rbell Aug 08, 2008
    Got new Fuser because plates were not hold up on Press, Still not holding up, What next.......
It definitely is a fuser problem. Plate is not getting enough heat to bond. We had same problem--put printed plate in oven at 250 degrees for 2 minutes--and like magic the plate was perfect. Not a permanent solution but sure works in a pinch.
Posted on Jun 09, 2010
The problem is due to the fuser not to anything else seems that the fuser do not heat up the toner enough, what i did is to run the plate twice , as blank of course . it did the trick for my press.
Posted on Apr 03, 2008
If the blank s not dry and stil has pre wsh on it it will break down he plate
Posted on Dec 29, 2007
What is the best saltwater spinning reels?
I purchased a Daiwa BG Saltwater BG8000, only have been able to used it once. Landed three Yellow Tail 30,50 and 72 lbs. with no problem, great reel. Only issue was getting used to the bell arm being manual, other than that I recommend this reel.
Daiwa BG Reel:
SmoothHard and tough anodized bodyStrong and stable pulling abilityA beauty to look at
Apr 08, 2018 | Fishing
Tip
Field Test
The test mode display is activated through the test mode command: <b>*3001#12345#</b>. Once you enter this command, you are given a list of options, including 'Field Test'. Select Field Test and then hit 'Enabled'. You must power down the phone and power it up again to get out of the test mode menu. The test mode screens may vary somewhat between different firmware versions and providers.<br /> Once you power up the phone you are given a new menu choice at location 10 called 'Field Test'. There are several different test mode screens. Type in a test number to get the screen listed below. Alternatively you may use the arrow buttons to move between the 199 different field test screens. Entering test number '0' will disable the test mode, but will still allow you to access the test menu.<br /> If you are using the field test mode and are unsure what the screens mean then hold down the # key for about four seconds to get a brief description of the screen. Repeat holding the # key to return to the test mode values. <b>Thanks to L. Tee for this tip</b><br /> If you would like to see what is behind the test mode screen then keyguard the phone, wait until the 'press unlock and then *' screen disappears, and then press one of the numeric keys to see the regular screen. <b>Thanks to L. Tee for this tip</b><br /> Note: If you make or receive calls while in test mode, you may not be able to change the speaker volume. To turn off the field test mode you can select field test '0' or enter a few digits and then clear these digits.
on Jun 19, 2011 | Cell Phones
USED SCREEN
you can buy the screen from a tv company repairs and service place. or you can find a dead tv. all the screens on projector tv's are made from the same stuff. what you have to decide is if you want glass or perspex. you can even make your own screen if you wanted a large sheet of perspex and a plastic coating off one way light sheet. the sheets can cost a bit though. most company's just throw away the screens. so you may be luck if you find one in the skip. you can find a 56inch etc just cut it to size of yours.
Apr 24, 2013 | Toshiba 52HM95 52" HDTV Projection...
Remote back light are staying on. An remote will not work
Is there a button that is pressed in and blocking the next remote function? Was the remote dropped or anything that would could cause the metal under a button to come in constant contact with the plate below? Check the buttons by picking at them with your finger nail or something that won't hurt the remote. If this still doesn't help try popping the front off the remote gently to get at the insides. The buttons will be connected in sheets. There may even be a small foreign object between the button and plate.
Nov 28, 2012 | Televison & Video
How do i get rid of the square message that appears in the middle of screen?
It sounds that, closed caption function to your TV is ON. Press the 'CC' button on the remote control once to make it OFF.
Aug 27, 2012 | Sony KV-36FS100 36" TV
I have a CQ56 compaq and do not know which type of screen to order a matte or a glossy screen.
The Two Kinds of LCD Monitors lens1946174_1208282041macbook-matte-screen1.jpg There are two kinds of modern LCD screens: matte (anti-glare) and glossy. Both have their pros and cons and are a subject of many discussions.
Matte screens don't get glare or reflections on them; however, the same rough surface (polarizer) that reduces the intensity of reflected light results in less contrast and brightness since the light from the LCD screen passes through it. Matte screens diffuse light instead of reflecting it so they might be easier to read outdoors, if the backlight provides enough brightness. You don't have to worry as much about reflections as with a glossy screen.
Glossy screens have vibrant colors and the highest contrast and brightness because they have a smooth, high-gloss surface. As a result, it is often the choice for movies or gaming. However, strong lighting causes glare on these screens which is very annoying and may tire your eyes if you have to stare at it all the time. You can also see reflections on the screen. Some graphics designers may also find the colors inaccurate. Glossy will work great for you if the lighting in your room doesn't create any glare on the screen.
http://www.squidoo.com/matte-vs-glossy-screens
Jun 28, 2011 | Compaq Presario CQ56-115DX Laptop
I'm stuck in the annoying progressive scan mode. How do I turn it off? I looked at the other peoples questions, but there's no answer following them so I'll have to ask myself. I'd be a great help if you...
The one I have was already broken besides the progressive scan. Unlike the other solutions, for mine I had to open, then close the tray and while the screen displays read, I pressed the Stop button and held it down until the progressive blue screen disappeared.
Jan 12, 2010 | Zenith XBV442 DVD Player/VCR
Cant connect laptop to tv
you still have to press the fn+f8 key or that key to switch screens for your laptop once you are in windows.
May 16, 2009 | Dell Latitude CPX Notebook
Directory name changed by Virus
try to login safe mode by restarting pc and holding down the f8 key as soon as the power comes on ..way before the windows screens appears and then select safe mode without network. Once in safe mode run your virus scan. Then go to start>run> type in cmd and press ok> then type chkdsk /f
please note a space between the k and slash (/)
press enter and then press then press the Y button and restart again once virus scan is done and see if that helps.
Dec 05, 2008 | Computers & Internet
Open Questions:
See all Xante PLATEMAKER 4 Laser Printer Questions
410 people viewed this question
Top Xante Office Equipment & Supplies Experts
Marvin
Marvin
Jose Pino
Dudeman321
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
