Question about Jensen VM9020TS Car DVD Player
Think I'm Missing some wire(s)
Bought a player.Missing the ground wire is it located to the left of the positive wire?
  • kuntry_a66in Dec 28, 2008
    does it go into the slot directly beside the red wire?And where does the yellow wire go?
    Champion:
  • 227 Answers
Try to find a similar harness and cut out the black wire with the connector intact by using a razor blade or box cutter and insert it into the one that you need. You can also solder the black lead to a wire from the inside and tab it onto the metal case then ground the the case to the vehicle frame if you are technically capable. Good luck.
Posted on Dec 28, 2008
  • hogan doan
    hogan doan Dec 29, 2008
    The yellow wire is usually on top of the black wire, and they both usually at the beginning of the connector with the bigger slots for bigger wires. Best bet is to browse around pawnshop for a similar deck with the same brand name or at a local stereo shop to make sure. You dont want to guess on it, bad resolve can happen.
I own a 1998 2.0 dodge neon. I trying to figure out why my trunk light won't work, when I bought the car it was obvious that the trunk was replaced. When I look on the trunk lock mechanism there is a...
Locate the trunk light bulb.Trace the wires from it and see if a wire goes to the hanging one you talk about.If so then ground that wire and see if the light comes on.If not check the bulb and a positive feed to it.If no positive feed check the fuses.If the light does come on then you have a missing switch which is what it sounds like.Good luck!
May 05, 2013 | Cars & Trucks
I bought a DVD player for my 2006 Mitsubishi Lancer. Thr new unit came with wiring diagram, however there is no information on the original Mitsubishi harness to match wires. The unit has a Fujitsy sticker...
Hi, please check the colors below for a match. If these are not your colors, please get back to me.
2006 Mitsubishi Lancer Car Stereo Installation Diagram
Car Radio Battery Constant 12v+ Wire: Red/Black
Car Radio Accessory Switched 12v+ Wire: Blue/Yellow
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Green/White
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Red/White
Left Front Speaker Negative Wire (-): Red/Blue
Right Front Speaker Positive Wire (+): Red
Right Front Speaker Negative Wire (-): Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Blue
Left Rear Speaker Negative Wire (-): Yellow/Red
Right Rear Speaker Positive Wire (+): Light Green
Right Rear Speaker Negative Wire (-): Yellow/Green
Mar 20, 2011 | Mitsubishi Raider 2006-2007 Car Radio...
I bought a cd player for my 94 grand cherokee and bought a wiring harness for the speakers. And. I want to kno which colors are the speaker wires
1994 Jeep Grand Cherokee Car Radio Stereo Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Violet/White
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Orange/Black
Car Stereo Dimmer Wire: Green/Red
Car Stereo Antenna Trigger: N/A
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Blue/Red
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Blue
Right Rear Speaker Positive Wire (+): Blue/White
Right Rear Speaker Negative Wire (-): Blue/Orange
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Dec 11, 2010 | Cherokee Jeep Grand 1994-1995 Radio...
I've bought an adapter thing, but I don't understand how to wire these wires.
  • Yellow - To the car battery of continuous +12VDC
  • Red - To ACC Power, +12VDC
  • Black - Ground, to bare metal or clean part of the car
  • Dark Blue - Motor Relay control lead for Antenna
  • Dark Blue / White Strip - Amp Relay Control lead
  • White - Front/Left Positive Speaker
  • White / Black Strip - Front/Left Ground Speaker
  • Gray - Front/Right Positive Speaker
  • Gray / Black Strip - Front/Right Ground Speaker
  • Green - Rear/Left Ground Speaker
  • Green / Black Strip - Rear/Left Ground Speaker
  • Violet - Rear/Right Positive Speaker
  • Violet / Black Strip - Rear/Right Ground Speaker
Nov 11, 2010 | Panasonic CQ-DP133U CD Player
Need wiring diagram for 2002 dodge ram radio/cassette player What color is hot and ground wire
2002 Dodge Ram 1500 Car Stereo Wiring Diagram
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Left Front Speaker Positive Wire (+): Dark Green
Right Front Speaker Negative Wire (-): Dark Blue/Red
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Jan 03, 2010 | Car Audio & Video
Need a wiring diagram
HI,
1999 GMC Sierra Truck Radio Wiring Guide
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger Wire: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Right Rear Speaker Negative Wire (-): Light Blue
please rate my suggestion....
May 22, 2009 | Car Audio & Video
Need a stereo wire color code for 2000 subaru outback limited
The sell a nifty little invention at Wally-World. Its called a wire harness...look for it in the auto parts section. it will wire directly to your stereo wires and then just plug & go... if your subaru wires are missing the harness on the end, its a whole different ballgame, and its gonna be fun...try this...
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Red
Left Front Speaker Positive Wire (+): Brown/White
Left Front Speaker Negative Wire (-): Green/Black
Right Front Speaker Positive Wire (+): Red/Yellow
Right Front Speaker Negative Wire (-): White/Black
Left Rear Speaker Positive Wire (+): White/Red
Left Rear Speaker Negative Wire (-): Red/Green
Right Rear Speaker Positive Wire (+): Blue/Green
Right Rear Speaker Negative Wire (-): Red
Let me know how it goes!
May 17, 2009 | 2000 Subaru Outback
I need to hook up cd player
something i found today on google. hope it helps.
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Illumination Wire: Blue/Red
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
May 09, 2009 | Sony CDX-CA400 CD Player
Stereo wiring diagram
Apr 15, 2009 | 1999 GMC Sierra
1996 eagle vision radio wiring
1996 Eagle Vision Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Black/Yellow
Car Radio Ground Wire: Black/Light Blue
Car Stereo Dimmer Wire: Pink
Car Stereo Antenna Trigger Wire: Orange/Red
Car Audio Front Speakers Size: 3 1/2′
Car Audio Front Speakers Location: Dash
Right Front Speaker Positive Wire (+): Purple
Feb 23, 2009 | 1996 Eagle Talon
Jensen VM9020TS Car DVD Player Logo
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
