Question about Yamaha HTR-6130 Receiver
No Audio Coming Through On HDMI DTV/Cable INPUT
I am trying to get the best possible audio from my HD cable box to my receiver, and a rep from the store had told me to plug my cable box into the receiver using an HDMI cable. Then run another HDMI from the receiver to the TV. I followed all the directions, and have audio & video on my tv but no audio is coming through my stereo system. Makes no sense to me, and is racking my brain.
  • Anonymous Dec 31, 2008
    I have the same problem, and think it's because the HTR-6130 cannot decode the audio from the HDMI inputs. It only acts as a pass-through. Can someone confirm or deny this?
  • Anonymous Apr 09, 2009
    That's stupid. You think as a new system, it would be able to do that. My old Samsung worked just fine.
  • 3 Answers
The HTR-6130 cannot decode HDMI audio. It can only act as an HDMI switch. To get the audio from the cable box to be output from the HTR-6130, you will need a separate audio connection (e.g. RCA cable).
Posted on Jan 02, 2009
I want to connect my cable box to my newly bought toshiba plasma
Is your cable box HD? It would be best for your tv. You can hook up a couple of ways depending on your receiver and tv in/out capabilities. You will always get best picture if you go directly from your cable box out to tv in. You should have capabilty to go HDMI out and perhaps Component out on your cable box. If you can't get hd receiver from cable company. Anyway, if you use HDMI, hook to HDMI out on receiver to HDMI in on tv. HDMI provides audio and video. You can also go componenet(red, blue, green) out from recevier to in on tv. I personally feel component gives you better picture but , doesn't carry audio. For that you need to get audio using either digital optical or, composite cables. You may have to set your HD on receiver through cable boxes menu. The last option is using composite cables(last choice, poorest picture and sound) yellow(video) and red, white(audio)
Apr 04, 2011 | Audio Players & Recorders
I have a new Samsung 47 in LCD and Kenwood DVD purchased in 2005. I am trying to hook both up to get surround sound from my Kenwood VR-606. My signal is coming from a HD cable box. I'm using HDMI from the...
Without additional equipment it can't be done. As i see your VR-606 pure analog device, and you trying to somehow use 5.1 sound from HD STB that is on HDMI put on RCA connectors of your VR-606. It is impossible without converter from HDMI to Analog audio or something likethis, best way to buy new receiver with HDMI input and TV neither Receiver with HDMI out oportunity. Then you will have your home cinema. In your current setup probably you can play only with stereo from your stb.
Apr 19, 2010 | Kenwood VR-606 Receiver
I'm trying to hook up my reciever up to my new flat screen any help as far as what cables I need, I will also be putting a dvd player on as well. I have comcast cable also, I've been told I need to get a...
This is posted under the Sony STR-DE685 heading, so I assume that's what you have. (If not, your receiver may have other hookup options available.) It might help if you download the manual if you need a copy from Sony's site here. It details all the rear panel connections.
This receiver doesn't have HDMI connections, so you'll need to make your connections using RCA cables It doesn't pay you to get an HD cable box if you're planning on connecting it through the receiver.
Output to the TV is very simple. Use a component video cable to go from the component monitor output on the receiver to the TV's component input. Then switch the TV to that input, turn off its speakers and listen to the sound through the receiver. Only one cable going to the TV that way.
Inputs will need separate audio and video connections since there are no HDMI connectors. Use the component video connection for your DVD player for the best video quality. The DVD/LD input offers those jacks. You can connect your cable box to the VIDEO 2 input using component video connections (if the box has those outputs) or composite video. Then the video and audio from the box will run through the receiver as well.
If you want to get a new HD cable box, you'll need to run a cable from its HDMI output to an input on the TV, and switch the TV to that input to watch the box. You can still run the audio signal through the receiver though. That will add one more cable to your hookup, and you'll have to remember to switch inputs.
Hope this helps. Thanks for using Fixya!
Jan 26, 2010 | Sony STR-DE685 Receiver
Yamaha rx-v365 plugged in the hdmi from cable box
You have to configure your DTV input to use optical audio instead of analog dtv audio (red/white plugs). Input assignment should be described in the manual. Come back to me if you have still problems with it.
Dec 26, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
I plugged in my cable HDMI into my RX - V365 Yamaha reciever. and HDMI into my TV. I get video, but cannot get my attached (to reciever) speakers to play. Help
RX-V365 doesn't support HDMI audio. You need to connect the cable box also via spdif cable for audio to work. Look at the box if it uses optical spdif or coax spdif. If optical, you see that optical input on receiver is named DTV/CATV, so use also DTV HDMI for video. Coax spdif is named DVD, so in this case you will need to use DVD HDMI input.
Also you need to configure the inputs accordingly.
Nov 14, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
Motorola DCT 6200/1000 seems to only have one audio output?
There are three options:
1) Connect the Tivo using the coax output of the cable box into the cable input of the Tivo
2) Exchange cable boxes with your cable provider for one with composite output jacks. It may require you to use a Motorola box that isn't High def depending on what your provider has. I know Comcast has a Motorola HD tuner that has composite outputs as well as component.
3) Upgrade to a Series 3 Tivo. Those units are designed for High Def. Use HDMI cable hookup.
Jan 17, 2009 | Arris DCT6200 DTV Receiver
How to Hook up HDMI from Comcast Motarola Cable Box
Connect the HDMI outputs on your various components to the HDMI inputs on your receiver. Connect the HDMI output on the receiver to the input on your TV. HDMI incorporates digital audio, so no need to buy optical audio cables. If your receiver does not have HDMI inputs for all your components, you will need to make a choice. HDMI = Best, component video + optical audio = second best, S-video+ optical audio = third best
Jan 01, 2009 | Onkyo TX-SR606 Receiver
Denon Avr-588 setup
dojran,
nice gear. Without further information, i am going to describe the best setup possible with your equipment.
1. make sure the speakers are connected to the receiver and you can hear sound out of it
2. connect cable box to receiver via hdmi to receiver.Choose cable on the receiver or video1 etc. (if you are not using hdmi cables post annd i will walk uthruogh a non hdmi process)
3. connect a hdmi cable from thee receiver monitor output area to the tv hdmi input
4. connect the dvd player hdmi to the input of the receiver
to watch select the tv av mode to line up with the receiver and choose video1 for tv and dvd to watch dvds on the receiver.
good luck
smeags
Jan 03, 2008 | Denon AVR588 Receiver
HDMI f/ dvd, dvr, receiver and tv
best set up if you have all hdmi is to have all your components go into the receiver ie. hd cable box, dvd etc. by using the hdmi output from the player(s) to the hdmi input to the receiver. next use one hdmi cable from the receiver to the tv then your laughing.
good luck
smeags
Dec 31, 2007 | Onkyo TX-SR605 Receiver
Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Dec 30, 2007 | Yamaha HTR-6130 Receiver
Yamaha HTR-6130 Receiver Logo
536 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
