DSiXL
SOURCE: nintendo dsi error everywhere
Contact Nintendo for this problem,
it looks like the firmware went corrupted,
maybe some one has used a bad flash
adapter to play backuped games.
Don't tell them the part of maybe some one
used a bad flash adapter, becouse they then won't help you anymore or will cost you alot
of mony to get it fixed.
Also try to reset the dsi to the standard settings, this can wipe everything on the dsi,
making backups is recomended.
A factory reset on the DSi can be performed by holding down every button minus those of the d-pad and turning the system on.
SOURCE: when i insert my R4i for DSi card, it start to say
You're not going to find manual support for a flash card like the R4.
Your best bet is to just reformat the SD card and start over again.
There's a great tutorial to set it up on http://www.dscardworld.com with pictures and links to all the official software on their support page.
If you suspect that you have unstable fake clone version you can get a genuine card there too. I managed to find this site after I got burned at a few others. Loved having my emails responded to because I had loads of questions, and they were quick to ship it.
Best of luck!
SOURCE: my dsi wont let me upgrade it.
You won't believe this answer but it works!
The same thing happened to me, I kept waiting and waiting and then it would say error. But, all you need to do is close the top of the dsi ( NOT THE POWER! ) and wait a few seconds. Then, when you open it up it almost always has one bar loaded! Keep doing this till loaded.
NOTE: You must open the top and then close it again, even if you wait an hour before opening it will have on bar more loaded!
Good luck!! :)
SOURCE: error code 051110-1 nintendo dsi
the dsi is trying to connect to connection file 2 ?? usually your home wireless connection is file 1 ? edit connection 2 with the same details that are in connection file 1 , or tell the dsi to use connection file 1 instead hope this helps ?? let me know
