Question about Bose Lifestyle SA-3 System
Unable to get SA-3 to connect
I am trying to setup my SA-3 through the AL1 wireless receiver. My receiver sees the signal. However, I am having trouble trying to get my amp to be recognized by my PMC II remote. I get a blinking light (green) and have tried many different room codes. Note: I have an AL8/1 setup on my Lifestyle 48 bose link output which works fine. Any ideas?
2 Suggested Answers
SOURCE: Bose link AL8 connection problems
I had a similar problem, though intermittent, using my 48 with the AL8 and room-mate speakers. I kept getting a "no signal received from media centre" message on the remote in the second room.
Assuming that the batteries are ok and you don't have a hardware problem, the problem might be that the 48 is not picking up the signal from your remote control in your second room. The signal from your remote control is a radio signal that goes directly to the 48 - it doesn't communicate via the AL8 receiver. I think the orange light will only turn green once a signal is being transmitted from the transmitter unit plugged into your 48 media centre, and this won't start transmitting until the media centre gets a signal from the remote telling it to switch on.
The aerial for all the remote controls is contained in the power cable that links the 48 lifestyle unit to your VS-2 unit. Make sure that this is uncoiled and oriented vertically, as far away from other cables as possible.
If this doesn't work, you can get an antenna extender that plugs into the RC socket on the back of the lifestyle system. Again, orient this vertically. You can get these from Bose.
Is there anything in the wall that might be blocking the radio signal? Lots of metalwork for example?
If orienting the power cable from the VS-2 doesn't do the trick, I suggest that you go to a local Bose shop. (An actual Bose shop, not just an electrical or hifi store stocking Bose products). I explained my problem and the tech guy gave me an extender gratis (its basically just an FM aerial wire by the look of it). I installed it this morning and, so far, its seems to be working ok. As my unit is fairly new, he also offered to have the kit back in the shop to check it all out and, if that didn't work gave me Bose technical support number. He even offered, if all else failed, to send a guy out to my home to get it working - and I didn't even buy it from there!
Hope this helps.
Posted on May 03, 2009
Netflix does not launch on my tv message is unable t connect what do i do?
Connection depends on the communication being used. Generally, you are using the wireless modem to transmit the audio/video signal from the internet to the wireless receiver in or plugged into the TV. If is a Smart TV the wireless connection is built-in and needs to be set up. If it is an older TV , you need the USB style receiver. You may be connected ok, but if you do not have a setup feature for the TV, it will not communicate.
Feb 09, 2018 | Computers & Internet
NHT sa-2 amplifier won't go into standby mode after 10 Minutes of no signal
Does the NHT sa-2 have it's own pre-amp? Because I'm wondering if the power off only works when it's own pre-amp is used? So when your receiver is connected it's shut off.
You could try something connected to it's own pre-amp (if it has one) and see if it goes off when there's no signal from that.
Jan 30, 2015 | Audio Players & Recorders
Lexmark X4550 3 in 1. Although the wireless capacity has been loaded and activated it has ceased working and will not allow access.ie the flashing wireless connection light does not turn green just...
Try to reset the printer's wireless network settings. On the printer operator panel, press Setup button > Network Setup > Wireless Setup > Reset Network Adapter > press check to confirm.
Re-launch the Lexmark Wireless Setup Utility to connect the printer to your network. If you have a firewall enabled, make sure to allow full access to all Lexmark software and printer communication processes in the program rules/permissions for your firewall. Also, place your printer where it receives excellent wireless signal quality and away from other electronic devices which can cause wireless interferences (e.g. cordless phones, microwave ovens, baby monitors, garage door openers, and other wireless electronics).
Jun 27, 2011 | Lexmark X4550 InkJet Printer
I have just got in broadband but my xbox aint picking up my wireless signal upstairs,ive got the wireless adapter for the xbox,its picking up a few neighbours network connections,surely my xbox should be...
It is possible that the Xbox will be unable to pick up the wireless signal being transmitted by your gateway because the signal is too weak.
The connection speed of your internet has nothing to do with the strength of the signal. The best way to test this would be to try to connect to your wireless internet on a laptop while sitting near the xbox. If you cannot, you will know that the signal isn't powerful enough to reach that location.
There are three common options to amplifying your signal if necessary.
1) Purchase a High-gain antenna for your wireless gateway
2) Purchase a wireless repeater
3) Purchase a new router/gateway with a longer range capability. A "Wireless N" enabled router would be optimal for this application.
Apr 12, 2011 | Microsoft Xbox 360 Console
Receiving wireless signal but unable to connect to the Internet
you have to set your router into mixed.....and set your gateway into LAN & WIRELESS...
Jul 08, 2010 | Linksys Cable Modem
Installing my wireless router
Setup by cable, Use Ethernet, then save.
Feb 28, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
Unable to use the wireless setup wizard - I am trying to connect my pc with my wireless printer. When I try to use the setup wizard on the pc it says depending on the wireless software installed on this pc...
The Wireless Network Setup Wizard and the View Available Wireless Networks feature both rely on the Wireless Zero Configuration service to provide their functionality to Microsoft Windows XP Service Pack 2 (SP2) and Microsoft Windows XP Table PC Edition 2005. If the Wireless Zero Configuration service is not available, you receive an error message that directs you to this article. This behavior occurs for several reasons. Some computer and hardware manufacturers provide their own configuration software that replaces the Wireless Zero Configuration service that is provided in Windows. In that case, you must use the software that is provided by the manufacturer to configure your wireless network. If you want to use the Wireless Network Setup Wizard or the View Available Wireless Networks feature to configure your wireless device, see the documentation that came with your computer or with your wireless network card. Use this documentation to determine whether you can use the Wireless Zero Configuration service to configure your wireless network. Sometimes, you cannot use the Windows functionality.
If your computer or your wireless network adapter did not come with its own wireless network software, follow these steps:
  1. Click Start, click Run, type ncpa.cpl, and then click OK.
  2. Click Network Connections.
  3. In Network Connections, click to select your wireless connection, and then clickChange settings of this connection.
  4. On the Wireless Networks tab, click to select the Use Windows to configure my wireless network settings check box.
To start the Wireless Zero Configuration service, follow these steps:
  1. Click Start, click Run, type %SystemRoot%\system32\services.msc /s, and then click OK.
  2. Double-click Wireless Zero Configuration.
  3. In the Startup type list, click Automatic, and then click Apply.
  4. In the Service status area, click Start, and then click OK.
If you receive an error message when you try to start the service, see the "References" section for more troubleshooting information.For more information, click the following article numbers to view the articles in the Microsoft Knowledge Base: 815485 Overview of the Wi-Fi Protected Access (WPA) security update in Windows XP 313242 How to troubleshoot wireless network connections in Windows XP
Feb 26, 2010 | Acer Aspire One PC Notebook
HP compaq nc 6000
jdawg01,
the signal that receives by ur adapter is not that much strong so it was unable to connect properly..u might have receive a low signal..
Apr 06, 2008 | Computers & Internet
Bose Lifestyle SA-3 System Logo
69 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Steve Allison
Steve Allison
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
