Question about Uniden Cordless Phone
Uniden phone will not call out
We have cable service for phones, TV and computer through Comcast.
Today we unplugged several things in order to move the computer system. Now everything is plugged in and everything is working. The phone has digital light, but when I try to call out, the handset says it is calling, but does not ring out. Instead it goes dead. What to do? I don't think it is Comcast because everything else is working. Is there a reset or something on the base that we need to tweak?
  • turnerlee Jan 29, 2009
    I have the same problem. Sometimes it calls out, but not always.
SOURCE: Uniden handset TCX905 with base unit TRU8866-if compatible?
Forget what I said before, the TCX905 does NOT fit into the TRU 8866 base unit with the battery cover on.
REMOVE THE BATTERY COVER TO REGISTER THE TCX905 WITH THE TRU8866 and everything works fine....
Posted on Oct 21, 2007
SOURCE: Uniden DCT648 register phone problem
On the Base Station select HS Registration then on the Handset hold # for 2 sec
Posted on Apr 13, 2008
  • 3 Answers
SOURCE: Resetting the Handset
YOU might need to deregister the hand set first by holding down the red end (hang up key) and keep it down while holding the # key. If deregister wont work use base unavailable and yes, you are sure twice.
List the handset numbers of those working handsets
Using a WORKING handset follow these directions
Resetting Handsets
If you want to register the handset to a different base or
replace a handset with another one, you must first clear the
registration information from the base and the handset.
1. Press and hold [ ] and [#] for
at least 5 seconds, until the
SYSTEM RESET menu
appears.
2. Select the DEREGISTER HS
submenu. WHICH HANDSET?
appears in the display.
3. Move the cursor to select the handset ID to be de-registered
from the list, and then press the OK soft key. DEREGISTER HS
appears. CHOSE A NUMBER THAT IS NOT ONE OF YOUR WORKING HANDSETS
4. Move the cursor to select YES, and then press the OK soft key.
When ARE YOU SURE? appears, select YES. You will hear a
confirmation tone.
PUT THE HANDSET IN THE BASE CHARGER AND IT SHOULD REGISTER
Hope This Helps - It worked for me
Posted on Oct 02, 2008
  • 3 Answers
SOURCE: Phone won't hang up
I solved this exactly problem by doing this:
1) unplug base station from phone line
2) unplug base station from power cube
3) open each phone and disconnect battery (do not replace phone in charger; just let it sit)
4) wait 30 minutes (per instructions from Uniden)
5) reconnect batteries in phone sets
6) reconnect power cube to base station
7) reconnect base station to phone line
8) test: make a call. Hang up. Wait one minute. Pick up line and see if you get a dial tone.
(Basically you're "rebooting" the system. You don't know where the fault lies, so you power down every component to make sure you get it. The '30 minutes' is longer than I'm used to, but after being on hold with Uniden tech support for 20 minutes and finally getting through, the instructions from them were very clear: AT LEAST 30 minutes. OK! I did it - and it worked!)
Posted on Jan 21, 2009
SOURCE: Register additional handsets on a Uniden phone
On most models you can find an option in the menu for De-register? In that case you would select that option and select to deregister the handset.
TRU88 models you go to the main menu and go to De-register HS select yes to deregister the Handset.
DCT5 and DCT6 models: Press menu on the handset. Go to System Reset and Press select. Go to Deregister HS and press select. Arrow up to yes and press select. Then go back into the menu. Go to system reset and press select. Arrow down to Replacing the base and press select. Arrow up to yes and press select.
DCT7 models: Press and hold "end" and "#" until the system reset menu appears on the display. Then follow the instructions from above for the DCT5 and DCT6 deregister procedures once your into the menu.
TRU4 and TRU5 models: Press and hold xfer/del and end until "de-register?" appears. Use the plus+ button to go up to yes and press select.
To register any of the following phones please see you owners manual under either:
•Register handset or
•Register the digital security code.
Posted on Mar 05, 2009
Cannot get menu for A/V mode to shut off Closed Caption
Try first disconnecting cable from tv and unplugging power cord from power for ten minutes
Jul 24, 2008 | Hitachi 42HDF52 Television
I have received calls from CALLPRO 730-330-0318 22 times in the last 2 weeks. After checking on them online, I find they are bogus. How can I block that number?
You can do several things, the easiest is to answer the phone and tell them you're not interested and not to call you again. According to 188Notes, it's Comcast. Probably trying to sell you or upgrade your cable TV service. Here's the thread and what number you can call to stop it http://800notes.com/Phone.aspx/1-703-330-0318/2
Carl
Jul 03, 2011 | Lands Phones
Using home phone causes comcast wireless internet to disconnect
Wireless internet runs at 2.4ghz. Your portable phone is probably also 2.4ghz and is knocking out your internet connection when in use. Look for an 800mhz or 5.8ghz phone as a replacement.
Oct 09, 2009 | Panasonic KX-TG2357 Cordless Phone
No dial tone on Uniden Dect 6.0 land line and portable phone
We've had the same problem with our new Uniden phone. Sounds like someone's on the other line - no dial tone and answering machine doesn't work. The telephone line works though because we plugged our old phone in and it works fine. Any solutions anyone?
Jul 17, 2009 | Uniden Lands Phones
GE DECT 6.0 Phone Light Blinks
First thing to try is to pick up handset or place on speaker. On the answer machine itself without trying to call your cable providers voice mail service...press the message button to ensure all messages have been heard or erased.
Second, unplug your phone power from the wall and wait two minutes before powering on the phone.
Last replace batteries in the phone if you have batteries in the phone now...may be low battery signal.
May 29, 2009 | Uniden Cordless Phone
Changing phone channel frequency
Easiest way take off back plate un hook battery wait a couple of minutes hook battery back up phone should find reciever on diff. channel
Aug 30, 2008 | Uniden 5.8GHz Expandable Cordless Phone...
Uniden PowerMax5.8 GHz
Yes, it will automatically let you know when you have a voicemail. If it does not work, contact Comcast.
Aug 22, 2008 | Uniden TRU8885 Digital Answering Machine
Uniden Cordless Phone Logo
89 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
