Question about Sony ICDP620 Digital Voice Recorder
I have a Sony ICD-620 recorder, and Dragon Naturally Speaking 10
I can't get my recorder to work w/ this program, and it didn't specify which Dragon Naturally Speaking I had to use, is it not compatiable w/ my recorder or am I doing something wrong?
  • lalynn May 04, 2009
    I have Dragon preferred 10 and I can't get it to work with the Digital Voice Editor of my ICDP620. The Voice Recognition icon is greyed out. I tried it out on my desk top and my laptop and can't the programs to connect on either of my computers.
3 Suggested Answers
DDMaster
  • 10 Answers
SOURCE: Recently I purchased the Dragon
There are several "flavours" of DNS 10, and only the Preferred and Professional versions will allow you to submit a pre-recorded sound for recognition (from the Sound menu). If you have a lower version such as the Standard, you will need to upgrade to at least Preferred.
I hope this helps
Posted on Jul 16, 2009
SOURCE: syncing Sony ICD-MX20 with Dragon Naturally Speaking 10 on Vista
the workaround seems to be
buy an Olympus recorder (supposedly they issued a patch for DNS 10 in a couple of days)
or
tell DNS that the source is a PDA generating WAV, MP3, etc.
havn't tried this myself yet. some say it it isn't that awful. But I too am very dissappointed.
Posted on Mar 21, 2010
Dragon Naturally Speaking Playback is not working with Word document.
This link would better explain your issue and has the best solution.
Ihope that will fix the issue...
Dragon Naturally Speaking Playback is not working in Word document
Jan 19, 2018 | Dragon Computers & Internet
Lookup serial number
The key might be on the manual or the box if its not on the cd.
Dragon Naturally Speaking is a software program designed by Nuance Communications that enables a user to speak instead of type to both transcribe information and control his computer. This is beneficial if you don't like typing or physically cannot do it.
The software requires a headset microphone to work and some configuration to get started. To continue using Dragon Naturally Speaking, you must register it or it disables itself.
Activation is done online and requires a product serial number.
The location of the serial number varies depending on the software version, but it should be located on the box, CD case or manual.
Start Dragon Naturally Speaking.
When it completes the loading process, click "Activate Now" when prompted and then click "Activate Automatically."
Enter the serial number in the space provided and click "Generate Activation Key."
Copy the activation key into the activation text box and click "OK" to activate Dragon Naturally Speaking.
How to activate Dragon NaturallySpeaking without an Internet connection
http://www.spectronicsinoz.com/article/how-to-activate-dragon-naturallyspeaking-without-an-internet-connection
Apr 25, 2013 | Nuance Dragon Naturally Speaking 11 Home
I'm using a Sony ICD-BM1 w. 32Meg memory stick. When I connect it to the computer (Win 7 PC) & start the Sony Digital Voice Editor 3.3.01, the recorded file disappears from the memory stick. The...
Welcome to Fixya
As part of the test. Try to copy files (pictures) to the device and see if the device were able to save the file. If not then try to format the device. Please take note that formatting the device will delete everything. see procedure below:
1. press menu 2. using the jog lever, select format 3. press enter 4. use jog lever and select yes 5. press enter -> Ok? -> press enter 6. formatting will be displayed on the screen. press menu after formatting the device and test the issue.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Jun 08, 2011 | Sony ICD-BM1 Handheld Digital Voice...
MY DRAGON NATURALLY SPEAKING 10-PROFESSIONAL DOES NOT WORK IN AOL EMAIL. IT WORKS WITH EVERY OTHER PROGRAM. BUT, WHEN I TRY TO DICTATE IN AOL EMAIL, NOTHING HAPPENS. ANYONE KNOW OF A SOLUTION?
Dragon Naturally Speaking 10 has not been tested to work with web based e-mail. It's also the same thing with Dragon Naturally Speaking 11 regardless of any version. As a work around and fix for this, if you want to use it through on any web based e-mail is to use the Dictation box.
Here are the simple steps to access the Dictation box:
1.Make sure you have successfully loaded a working user profile. 2.On the dragon bar, go to tools and then go to "Dictation Box" 3.Here, you can start dictating e-mail messages and use the "Transfer" button to transfer text in AOL E-mail.
I hope this solves your current problem.
Jun 05, 2010 | NRS Nuance Dragon Naturally Speaking 10...
Voice recognition using Sony ICD-P320 and Naturally Speaking
I would run compatibility check. It sounds like not compatible with Vista.
May 16, 2010 | Sony ICDP620 Digital Voice Recorder
Syncing Sony ICD-MX20 with Dragon Naturally Speaking 10 on Vista
or
Mar 14, 2010 | Sony ICD-MX20 Digital Voice Recorder
Recently I purchased the Dragon Naturally Speaking 10. It works very well on straight dictation. However, I cannot seem to load my recordings from the Olympus VN-3100 PC unto the Dragon Speaking. Any...
I hope this helps
Jun 26, 2009 | Olympus VN-3100PC Digital Voice Recorder
Setup Problems/Can't Downolad Files
did u find a solution? it has been 6 months since u posted..... does anyone know the solution as i have the same problem....
May 02, 2007 | Sony ICD-MX20 Digital Voice Recorder
Sony ICDP620  Digital Voice Recorder Logo
395 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
