Try restarting it. the process should be in your paper menu thing that you got with your zune(for future reference). press hold and the back button. http://support.microsoft.com/kb/946064 that is the website if you need a diagram of which buttons. good luck! please rate! =]
If it's not doing anything else, so you should probably let the zune software do the restore. Usually doing a restore will fix any software related issues.
I had a similar problem with my 30GB Zune. The first normal solution is to make sure that the USB port is providing enough power to the Zune to charge it by trying a different port or computer, but since your other Zune charges it is likely not the problem.
Other possibly solutions are performing a hard reset on the Zune (hold back and up until it resets), or allowing the zone to completely discharge and try again. In my case, none of these solutions worked and I was forced to send my Zune in for a new battery, which Microsoft was willing to replace for free.
First you have a bad port on computer you probably need to plug your cable in the back of the computer. If you keep letting your ipod freeze like that your going to seriously mess it up. I'm going to teach you a way to fix your problem with freezing. the next time your ipod freezes hold the "MENU" and "CENTER" button at the same time. After that you need to take your ipod and restore it through iTunes. Please rate this response I would like to know if I helped.
uhm i think i may have found your solution, that is if your using limewire or some client of the sort, i synced my zune while the program (limewire) was on and downloading music and i had the same problelm you did so i simply deleted all my music and put it back on the zune while limewire was off and now it works fine, i have an 80 gig btw if that matters
