Question about Whirlpool Washing Machines
How do I replace the drive coupler on a Whirlpool washing machine
My husband took the front and top off of the washer but now we can't figure out how to get the coupler off
  • 640 Answers
He took the cabnit off???...ok now kneal or stoop straight down,,always unplug unit..now your looking at the pump ,,theres 2 clips holding pump on 1 upper and 1 lower take a small screw driver and pry them off twist just a touch ,let pump hang dont remove ,,now your looking at the motor ,,it also have to clips but there longer and they have to screws holding them through front...take your 1/4 nut drive and remove,,if you dont have nut driver pliers will do just take your time..now reach to your right side of motor and disconnect motor ,,put a little pressure with your hand and pull straight out...take the motor clips off the same way you took the pump clips off,,now you should have 2 plastic couper and 1 rubber grommet...remove broken pieces than put 1 half the plastic coupling all the way on the transmission line it up straight then knock t in with he back of your screw driver use another tool to knock with..now put the other coupling on the back of the motor the same way..take the rubber grommet and put it on the transmission side,,you must look and line teeth up with hole since the grommet is on 1 coupling you only need to line up motor have,,,now take 1 motor clip and put the bottom 1 back before you put motor back let it lay on floor,,put the top clip close ,,now left motor and push to the tranny coupler now put back top clip...reverse to put together..
any question fell free to contact me
Posted on Dec 28, 2008
How do you get to the washer belt? I think it is not spinning. I think it came off the pulley.
Is your machine a front,or top loader, if top loader the most typical problem will be the motor coupler,Is it makes a clunking noise that makes a think the belt has come off? if yes noisy watch this youtube video and it will show how to get to and replace coupler.
http://www.youtube.com/user/RepairClinic?v=9K1KHEogf3c&feature=pyv&ad=5453897861&kw=washing%20machine%20coupler
i hope my answer helps you to figure out what is wrong with your washer,
Gene
Aug 05, 2011 | Whirlpool Washing Machines
Will spin empty but with a load will not spin.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Nov 16, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My husband says plastic cluprit is broken underneath the machine
Plastic culprit is the motor coupler. Here is a link for properly replacing
Motor coupler video
Oct 14, 2010 | Whirlpool LSQ8000 Top Load Washer
My husband replaced the coupling on our kenmore
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
I'd verify that the Motor Coupler is installed correctly first.
I'd also verify that the Lid Switch was re-connected after replacing the coupler. (A common oops that I've done myself)
If it was, I'd test the Lid Switch by jumping the two outermost contacts with a short piece of insulated wire.
See the Whirlpool Service manual for their top load, direct drive washers for how to bypass the switch.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Apr 27, 2010 | Kenmore Washing Machines
My washer will fill with water and do nothing else what could be wrong
It doesn't agitate If your washer doesn't agitate, check these: Lid switch Motor coupler Belts Clutch Drive motor Drive pulleys Transmission Agitator Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. Drive pulleys
Jan 17, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
I need to replace the coupler on my direct drive whirlpool washer
Access to the motor is better from the bottom. Lay the washer on its side.
Mar 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
I have an older model Kenmore washer - stopped spinning and aggitating - I took the control panel off, how do I reach the belt?
Your problem may not be a belt some Whirlpool built Kenmore washers are direct drive and have a coupler instead of a belt. The coupler is located on top of the motor. It consists of three parts two with prongs and one with holes for each of the prongs. If this is broken or badly worn the washer will not agitate or spin. Good luck. Oh the drive coupler part number is 285753A.
Jan 08, 2009 | Washing Machines
Kenmore 80 series washer 4yrs old
suspect gearcase problem or broken brake release on bottom side of basket drive
May 20, 2008 | Kenmore 22422 Top Load Washer
How to replace coupler
Edward You can find complete instructions here: http://www.askgene.com/2007/02/07/whirlpool-washer-direct-drive/how-to-replace-the-motor-drive-coupling-on-whirlpool-direct-drive-washer/ Gendos...post back
Feb 06, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
76 people viewed this question
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
