Question about Dell E173FP 17" LCD Monitor
E173FP flat monitor
Hi I have a problem with my monitor every time I turn my computer on, the main menu appears on my screen (the one that changes the settings for your monitor)and them this lock appears and flashes, but the thing is I havent touched anything and if I push the buttons on my monitor they dont work. I would greatly appreciate any help
    Scholar:
  • 38 Answers
Great help. Thanks
Posted on Sep 03, 2008
    Novelist:
    Scholar:
  • 104 Answers
Try pressing and holding the menu button for 15 seconds! That should unlock the controls! Regards, babb
Posted on May 08, 2007
  • Armando  Babb
    Armando Babb May 08, 2007
    FYI....The lock you see indicates that the OSD(On Screen Display) is locked! Which is a feature builtin to the monitor to prevent accidentally changing settings, You can lock and unlock at anytime by holding the menu button for 15secs, if that doesn't work something might be wrong with some internal board on your monitor and you should
    take it to a tech for troubleshooting!
    regards,
    babb
SOURCE:
Main Menu and lock cymbol keep coming on screen. How do I get rid of them?
Wendy ohlsen, I know you really like your E173FP, but it is quite "old" in CCFL back-lit lcd display years. It could be 4 to 6 years old. Retrevo .com lists unit as "time to retire" ,, Please reply back with the "date of manufacture" from rear of unit. Tell me if unit has a "lay on floor" power adapter or just a plain old "line cord" that plugs into the wall. When "strange stuff" starts to appear on screen, problem is most likely inside the unit on the power supply board. Let me know if your husband or boyfriend can assist you with an internal visual investigation of unit's power supply board. See YOUTUBE video clips of repairs being done on typical Dell units first. Pay particular attention to BAD CAPACITORS being replaced with new ones!!! 12fixlouie
Sep 14, 2010 | Dell E173FP 17" LCD Monitor
Large black line at the bottom of the desktop - about one inch wide. Windows opens above the frame of the desktop.
you need to change the aspect ratio or position of the screen using the menu and buttons on the monitor
Oct 30, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
I have a Dell E173FP LCD monitor and everytime I try to access the OSD menu a lock appears on the screen. What is the solution to this problem?
Thanx for your help. That should work too, but I tried pressing the menu for 15 seconds and it unlocked.
Thanx again
Jan 03, 2009 | Dell E173FP 17" LCD Monitor
LCD Main MEnu
hi,
It is possible that menu button on the monitor is stuck. I suggest to call your computer manufacturer where you purchased the monitor, check for the warranty and request for a replacement.
Keep me posted.
Thanks
Dec 03, 2008 | Dell E173FP 17" LCD Monitor
Dell E173FP LCD Monitor
Yes, it does appear as if there is a loose connection somewhere inside, or a faulty IC chip. However, I wouldn't recommend opening it up, as there can be any number of reasons why this can be happening, and if you have no prior experience, there is no point opening it up. I recommend getting it serviced, or purchase a new monitor...whichever works out cheaper for you.
Sep 06, 2008 | Dell E173FP 17" LCD Monitor
Monitor blank
try to start your pc in safemode with vga mode with thjis faulty monitor
hope you know how to do it
start pc (powerr on)
then continuously press F8 key then it will show you boot menu
select safemode with command prompt
then if it show desktop on screen this means your monitor is having problem with resolution try to downgrade your monitor's resolution
rightclik on desktopgo to properties
select settings
here you can find screen resolution make it to 800X 600 just for one time
then restart your pc it will auto select proper screen resolution
Mar 29, 2008 | Dell E173FP (Black) (Dark Gray) 17" LCD...
Dell F1703 17 in. Flat Panel... Problem
There may be problem of heating the inside components. see him to expert.
Mar 03, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
hi, check out the micro switches on the monitor.. let me know..
Nov 17, 2007 | Dell E173FP 17" LCD Monitor
E173FP 17" LCD Monitor Problem
I have the same problem. It seems like a virus to me, but my anti-virus doesn't find anything. I went to the main menu on the moniter and changed the display time to five seconds and locked the OSD display. Now all the appears is a smaller box showing a lock which goes out in five seconds. It is still annoying, but less intrusive then before. Hopefully, some one will determine a permanent fix for this problem.
Oct 26, 2007 | Dell E173FP (Black) (Dark Gray) 17" LCD...
Dell E173FP - After sometime the screen switches off
Sorry not a solution - but I have started experiencing the exact same problem over the last month although sometimes, on switching on again, it will run for 10-15 minutes before the problem re-emerges. Initially I put it down to the v. hot weather in July but it still continues. So I would also appreciate any solutions!
Aug 06, 2006 | Dell E173FP 17" LCD Flat Panel Monitor
Dell E173FP 17" LCD Monitor Logo
216 people viewed this question
Clive
Clive
Alun Cox
