I need the capacity for a Maytag Neptune washer Model # MAH4000 AWW
  • 15,935 Answers
3.5cuFt
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
What is the value of R-11 in the maytag ,MAH4000 AWW it's in the door lock wax motor for the hinh speed spin
The R-11 is on the control board, not in the door lock or wax motor. Value is 3.9KOhm, plus you'll need to replace the Q6 triac if R-11 is burnt out, as it's also dead.
Jun 17, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Model MAH4000, will not spin out, door lock will
Check if the "locked"or "door locked" light comes on. If it does not, you need to replace the wax motor in the door lock assembly and the machine control board, which is inside the control panel. The control board is expensive, so instead of buying the whole control board, if you're good in electronic repair and soldering, try checking ebay for the control board repair kit. Search for "MAYTAG NEPTUNE WASHER R11 Q6 REPAIR KIT". It has all instructions how to do the repair. Good luck!
May 12, 2010 | Maytag MAH6700AWW Neptune Front-Load...
MY MAYTAG NEPTUNE MAH4000 WILL NOT DRAIN OUT OR SPIN
Dec 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Mah4000 maytag how to locate remove and clean
if you think your problem is a dirty sump run a good quality appliance cleaner trough it first much easier than stripping down machine give it a go
Nov 04, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Sometimes there is water that fills in my washer after I use it. It does not happen right away but by the next day. I don't know the model but I do know this is an old washer....gold....I have had it for...
Q - My washer seems to keep filling  with water, the water keeps coming in the washer and going out the drain without the washermotor running.
A - This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
  1. Boot change helps
  2. Consumer Display Code Table on the Electronic Display Maytag Neptune Front load washer
  3. Free on-line repair manual for the Neptune washer MAH3000, MAH4000, MAH5500, MAH7500  ( Acrobat reader required )
  4. How to access the console on the mechanical timer models
  5. How to access the workings of the washer
  6. My washer door is locked and it will not open up...HELP
  7. My washer will start when I push the start button, but a few seconds later, it will shut off
  8. My washer will not pump out + pump noise problems
  9. My washer will not spin
  10. Odor complaints from the front load Neptune washer - mildew complaints + a new "freshen up" procedure
  11. Parts breakdowns/exploded of the Maytag Neptune front load washer ( mechanical timer models )
  12. Problem chart for MAH3000 & 4000 Neptune washers
  13. Readers repair tips
  14. Trouble shooting tips from the Neptune manual for MAH3000 and MAH4000 models
  15. Tips from our friendly engineer on changing the boot and re-installing that clamp and spring
  16. Tips on changing the washer belt  ( acrobat reader required ) Belt parts link
  17. Tips that show what components need to be checked/replaced if a certain resistor on machine control board is bad. It is as follows: Burnt resistors in Maytag Neptune washer models MAH4000 and MLE/MLG2000
  18. Washing one item in a front load washer
Apr 01, 2009 | Maytag Washing Machines
We have a Maytag Neptune washer Model # MAH4000 AWW it is leaking from the front at the bottom of door. Water pours out like a water fall when it wants to rinse. Any ideas?
TO ELLIESHIRK, I SEE YOU POSTED YOUR PROBLEM ON MAR. 19, 2009. I HAVE A MATAG NEPTUNE FRONT LOADER WASH MACHINE MODEL #MAH55FLBWW. I AM HAVING THE SAME PROBLEM WITH MY MACHINE LEAKING WATER OUT THE FRONT DOOR. MY WASH MACHINE SEAL LOOKS FINE. IF YOU HAVE FOUND A SOLUTION TO YOUR WASH MACHINE LEAK PROBLEM, PLEASE LET ME KNOW, OK. YOU MAY EMAIL ME AT: CJA931@FRONTIERNET.NET , MY WASH MACINE IS NOT VERY OLD EITHER 4-5 YEARS IM GUESSING, IT WAS LEFT WITH THE HOUSE I PURCHASED. THANK-YOU FOR YOUR HELP AND TIME. CONNIE
Mar 18, 2009 | Maytag Neptune MAH7500A Front Load Washer
What is the drum capacity size on the orig maytag neptune washer?
Drum size or capacity for the Neptune Model Number MAH4000AWW is 3.4
Jan 03, 2009 | Maytag Neptune Washer
Maytag Neptune MAH4000 - Washer won't shut off!
sounds like to me you have a bad board needs to be changed
Sep 16, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Broken Tub Support Arm
ummm yea your int market for a new washer. why cahnce epoxying a tub thats holding water doesntsound like a viable option. ( not worth the chancing the flood )
Mar 16, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Washing Machines Logo
123 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
