Question about Brother BRTPT65 PT-65 Label Maker Printer
I have a Brothers home and hobby PT110 labelmaker. It has new batteries. I can type the words but the tape won't feed even though the labelmaker is making a sound as if it is about to print.
  • Anonymous Mar 14, 2014
    I cannot reload the tape
You have to make sure the new tape is snapped in and then put the back back on it. After its reassembled press CODE SPACE. This will feed through the tape. If the back of the P-touch is not on it will not work... Crazy but true :)
Posted on Dec 29, 2008
  • 3 Answers
Code space! fixed it right away. thanks.
Posted on Dec 31, 2008
P-Touch Model PT-65 Home and Hobby Label Maker - Loaded a new cartridge and it will not feed through
Sir/Madam
Its Very Easy To Fix This Issue,Just Follow Few Simple Step and You Solve Your Problem By Your Own,
Read Below Instruction,
1Turn off the label maker before installing the tape.
2Press the part marked as "<<" and lift the cassette cover.
3 Position the tape into the slot. Make sure to feed the end of the tape under the tape guides.
4Check that the lever is up before closing the cover; the cover will not close if the lever is pressed down.
5Close the cassette cover.
6 Press the power key to turn on the device. If using an AC adapter, plug the adapter into the wall then press the power key.
7Type a sample to test if your installation was successful.
Read more: http://www.ehow.com/how_7526530_install-tape-ptouch-label-maker.html#ixzz2pMqUU0oU
Jan 02, 2014 | Brother BRTPT65 PT-65 Label Maker Printer
My Dymo 210D will not feed the tape. The little dealy thing goes around, but the tape doesn't feed.
My works Dymo LabelMANAGER 210D broke down because of a weak construction. The tape cartridge door pulls via a spring the print head towards the roller. Its plastic lever couldn't handle the strain. I repaired it with a peace of locking wire, as you can see on the picture. Greetzzzzz Arno
Aug 29, 2013 | Dymo LabelMANAGER 210D - Labelmaker - B/W...
Dymo letra tag print is unreadable
Solution 1:
Replace the existing batteries with a new/fresh set of alkaline batteries. The print head requires a significant amount of battery power to ensure proper printing on the label. Light print on the label may be an indication that the batteries need to be replaced.
Solution 2:
Replace the existing tape cassette with a new tape cassette. Light printing may be an indication of bad label stock.
Solution 3:
Using the special brush supplied with your labelmaker (located on the inside cover of the cassette compartment) or a cotton swab with a soft solvent (e.g. rubbing alcohol), carefully clean the transporter roller and print head. Dust, dirt, or glue may accumulate on the rubber transport roller or print head inside the cassette compartment and adversely affect print quality.
May 17, 2011 | Office Equipment & Supplies
When typing the print is faded
Dymo LetraTAGs are thermal printers, so they don't use ink - just batteries and LetraTAG tapes.
When the print starts to fade it's time to put new batteries in. When the batteries are running out the text fades first even when the motor is still feeding tape.
Jan 31, 2011 | Dymo LetraTAG Thermal Label Printer
Need instuctions for dymo label point 250
LBrown18062@hotmail.com. My manual is 12 pages long. Please put DYMO Manual as the subject and I will email it to you right away. Waiting for your response.
About Your New Labelmaker. With your new DYMO LabelPOINT™ 250
labelmaker, you can create a wide variety of high quality, self-adhesive labels. You can choose to
print your labels in many different sizes and styles. The labelmaker uses DYMO D1 tape cassettes in
widths of 6 mm (1/4"), 9 mm (3/8"), and 12 mm (1/2"). Tape cassettes are also available in a wide
range of colors.
Getting Started
Follow the instructions in this section to print your first label.
Connecting the Power
The labelmaker is powered by standard batteries or an AC power adapter. To save power, the
labelmaker will automatically turn off after two minutes of inactivity.
Inserting the Batteries
The labelmaker uses six 1,5V AA batteries.
To insert the batteries
1. Remove the battery compartment cover. See
Figure 2.
Jan 20, 2011 | Office Equipment & Supplies
Problem feeding 9m tape in Dymo 1895
I have one of these and there is a white sliding button on one of the broad sides of the labelmaker. It slides from 3/8 inch to 1/4 inch. It is located toward the top right. It's NOT the side with the letter wheel but the opposite side. If yours doesn't have t his button, it probably won't take two sizes of tape. (But I'd be surprised if it didn't have the button.) Hope you find it.
Apr 24, 2010 | Dymo Hobbyist Labelmaker Printer
P-touch Model PT-100 not working
You could send it back to the Manufacturer but you will find that the cost of doing so would be not far less than buying a new one
Dec 03, 2009 | Brother P-Touch 1180 Label Printer
How and where do I feed new labels
press and hold the code button and press the "space button" this will feed the tape
Feb 18, 2009 | Brother BRTPT65 PT-65 Label Maker Printer
LOADING TAPE INTO A BROTHERS P-TOUCH
I'm on my second machine since December. Neither P-Touch would feed the white tape, the other layers bunch up inside the machine. Called Brother, and they were no help (indeed not much interested in my problem), except to suggest I clean the rollers with alcohol/q-tip. This action did result in the tape feeding, but not properly as I now get an unusable label strip with all three layers, and printing on the clear layer backed by black layer. POS if you ask me; it is going back to the store.
Nov 17, 2008 | Brother P-Touch 1180 Label Printer
Won't print
Here is the Dymo site for this issue:
https://global.dymo.com/enUS/RNW/RNW.html?pg=std_alp.php?p_li=&p_accessibility=0&p_page=1&p_cv=&p_pv=2.22&p_prods=21%2C22&p_cats=&p_hidden_prods=&prod_lvl1=21&prod_lvl2=22&p_search_text=&p_new_search=1&p_search_type=answers.search_nl
Type "light print" into the search box and the first result is the link you are looking for.
Here is the text of the link:
Poor Print Quality from Electronic Labelmaker trnsp.gif Question I have an electronic labelmaker that is printing poorly. The print on the label is either very light, incomplete, or striped. How can I resolve this?
trnsp.gif Answer Proceed with the solutions listed below if you have an electronic labelmaker. If you have a LabelWriter printer that is printing poorly, click here.
Solution 1:
Solution 2:
Solution 3:
If the solutions listed above do not resolve the problem, please contact DYMO Technical Support to obtain a Return Material Authorization (RMA) Number.
Obtaining a Return Material Authorization (RMA) Number:
  1. Click the Ask a Question tab at the top of this FAQ.
  2. Fill out the email form completely and include the following information in the Problem Description field:
  • Full Name
  • Full Shipping Address (No PO boxes)
  • Phone Number
  • Date of Purchase
  • Model Name/Number
-hope this helps.
Mar 05, 2008 | Dymo LetraTAG Thermal Label Printer
Brother BRTPT65 PT-65 Label Maker Printer Logo
350 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
