Question about Apple iTunes
How to play iTunes tracks continuously
When I plan a track in iTunes, it stops at the end of the track and does not proceed to the next track. This is a new problem which I did not have with earlier versions of iTunes.
  • dgcooper215 Dec 31, 2008
    This was the cause of my problem. Now, is there a way to select all tracks in an album without having to click track-by-track?
  • Apple Master
  • 6,487 Answers
First thing you can try here is to uninstall this Itunes and re download the it again from Apple and install it to your computer because sometimes it can be a problem with the Itunes that you have downloaded...
Posted on Dec 31, 2008
  • Apple Master
  • 13,433 Answers
This is just a start so report back with results
Do You have the songs unchecked? iTunes skips unchecked songs.
  • Ekse Dec 31, 2008
    The select all command is : Hold down CTRL button and press A while you have one song selected.
    it should select them all. also try right clicking on the check box and see if it has a option to select all or check all.
The CD will not advance to the next track. One track is played and then it stops and waits until I program it to play the next track.
try when u turn it on. check all your bottons 2 make sure they r not stuck and than put a cd n and check 2 c if it will read the hole disc. or push play with a cd in there an try 2 skip songs 2 play
May 10, 2011 | Audio Players & Recorders
Format error, and can't view playlists- I am on OSX 10.4.11. When I load mp3s onto the player, that have been imported into itunes (dragged them over via the Finder), I get two files for each song. The...
I don't have a solution -- but I have the same problem and this is the first I've found mention of someone else having it. I'm Mac OS 10.6.5. I thought I could go through and just delete the second copies of everything, but I can't figure out how to do that either. They don't show up when it's plugged into the computer. And as far as I can tell, you have to be playing a song in order to delete it, and it can't play things in the wrong format. Beating my head against the wall and starting to look at buying something else... In case you found a solution elsewhere, please let me know!
Jan 29, 2011 | Freestyle Audio MP3 Player
1-I'm recorded my music 10-track on step 3 on EZ Vinyl Converter. 2-On step 5 export recording to iTunes take tolong to complete. 3-I'm access iTunes Music library. I see only 3 music track. 4-Can you...
The software is not 'seeing' the gap between the tracks, so it does not know the song has ended. Untick 'split recording into tracks' box, then sit with it as it records and click on new track every time a song ends. Tedious, but it works.
Nov 29, 2010 | ION Audio TTUSB10 Turntable
Cd player starts, but stops play by 2nd track
Sounds like tracking motor and/or gear problem!
Check for a small crack on the tracking gear.
Parts not avalible from Bose though, they'll only
fix as a "flat rate"!
Apr 12, 2010 | Bose Acoustic Wave (32022) 5-Disc CD...
Nano Audio Playback Repeatedly Skips Same Section of Song Track
I get this a lot with MP3s and it is because of the chips that Apple used in these iPods. It's only in the very latest ones they have solved this by using a different manufacturer. The best way I found to solve this was convert all the MP3s to AAC.
To do this, in iTunes
  1. go to the preferences and in the General section where it says 'When I insert a CD' or similar there is an ImportSettings button. Click this and in here there is a selector for 'ImportUsing' and change it to AAC - The native codec for the iPod. Save all this
  2. then in the main music library select the song you want to repair and right-click (ctrl-click on a mac) then choose 'Create AAC Version'. This will convert it.
  3. Now right click it and choose 'Show in Explorer' (Finder on a Mac) and delete the MP3 version.
  4. Back in iTunes if it made duplicate listings for the song try to play it. If it plays that's the AAC version if it doesn't thats the old MP3 version and needs deleting.
  5. Transfer the AAC version into any Playlists you had associated with it for the iPod.
  6. Done.
Kind of a pain if you've got loads of them to do but it does work. I tried repairing the mp3s in other software but the ipod still had issues with them so AAC is the way to go. (You can also convert them back to MP3 from the AACs which also fixes it but if you haven't transfered the AACs to the iPod it wont recognise the change of file for the MP3s)
Hope this helps you out.
All the best
Sean
PiDigital
Dec 16, 2008 | Apple iPod nano
Don't know how to actually record
To record you need to first assign your input to a track, then arm the track for recording, and then press play + record at the same time.
1. So you would patch you mixer's output into an input on your DP01 (say input A). You can run some audio to set the level with the input level knob (located next to input A on the front panel).
2. Then to assign that input to a track simply press and hold the 'input A' button and then press the 'rec' button of the track you with to record on. The 'rec' button will flash rapidly to indicate that the input is assigned to the track.
(To assign the input to a different track you have to clear the input assignment from the first track and assign the input to a new track. To clear an assignment press the input assign key, A in this case, and the track it's assigned to will flash its 'rec' button. Hold down the input assign key and then press the flashing 'rec' button. The button will stop flashing and the input can then be assigned to another track by following step 2 again).
3. Next, to arm the track for recording simply press the 'rec' button for that track. The 'rec' button with flash slowly.
4. To begin recording press play + record together in the transport section and the 'rec' light for the armed track will stop flashing and light steadily. Press 'stop' to end recording.
This should get you started. The operation of the DP01 is actually pretty intuitive once you've gone through it a couple of times (which is one of the real strengths of the unit). You'll be multitracking like an expert in no time.
Cheers,
bd.
Nov 20, 2008 | Tascam DP01 All-In-One Recording Package...
Sharp CD-DP2400 3-disc mini component system stops playing in first track
the rails on the laser slead need cleaned..the grease gets hard/dirty and stops it from moving skip it to track 16 to move the dirt off the track..
Oct 26, 2008 | Audio Players & Recorders
IPod plays about 5 tunes then stops
The tracks that the ipod skips would be of certain formats the ipod does not support ..... when you load the tracks with itunes it normally prompts you with a dialogue box and asks whether you want to convert it to the specific format ..... Try reloading this way and it should work .,... if still a problem restore it and reload
Oct 12, 2008 | Apple iPod MA446LL/A MP3 Player
Cant playing full songs.....
when you installed itunes did you check the box where it asked you to automatically eject ipod or manually eject?
Jul 25, 2008 | Apple iPod nano
MP3 playback stops at the last file in folder and does not continue to next folder
Not much you can do.
You could rename all your tracks, and put them in one folder.
EG
ALBUM NAME - 01
ALBUM NAME - 02
ALBUM NAME - 03
ALBUM NAME - 10
ALBUM NAME - 11 ETC.
This way, the tracks will play in order within each album.
Use 2 digit track numbers or they will play 1,10,11,2,3,4, etc
Mar 17, 2008 | Televison & Video
Apple iTunes Logo
32 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
