Question about Panasonic DVD-S55 DVD Player
Powers off My DVD player was working just fine last night. When we put a disc in this morning, it indicated it was reading and then the player shut itself off. We turned it back on (it powers on just fine) and put a different DVD in and the same thing happened: it started reading the disc and shut itself off. There's nothing in the troubleshooting guide that deals with this problem. I tried unplugging everything (cables, AC) and plugging it back in but still encountered the same problem. Any ideas?
  • Depfrz Nov 27, 2008
    Check for a 'HO2' error message after powering off then back on. The HO2 error indicates a spindle motor problem. (the actual little motor that spins the disc) Possible temporary fix as follows:
    - insert a disc
    - unplug the unit
    - remove the case
    - spin the disc by hand (you can spin the little motor without the DVD in it if you can reach it, I found spinning it with the disc in it was easier)
    - plug it back in and check if it works (I had to help it spin once more with the power on to "jump start it"
    - unplug and replace the cover
    Genius:
  • 1,074 Answers
Bad microchip have a tech look into your problem and correct it.good luck.
Posted on Apr 24, 2007
Jvc DR-MV5S disc error
Could be drive failure. The non-spinning DVD is an indication.
Nov 10, 2017 | JVC Televison & Video
I load a dvd in the sylvania sdvd 9009 player and it says no disc after loading
If the DVD loads, there should be something on the display that indicates it is being read (maybe a spinning disc icon). If it tries to read, then displays the "no disc" icon it means either that particular DVD can't be read or the drive has failed. If you try another DVD and get the same result, you can be pretty sure the drive has failed
Dec 16, 2012 | Televison & Video
How can I play a disc reading incorrect and error It worked fine this morning
Try some other discs first or try that on another player, usually if cannot read the disc either a dirty of bad Optical Pickup in the player.
Dec 16, 2012 | Toshiba SD-V291 DVD Player/VCR
Dvd player is only a couple of weeks old, brand new when purchased. Worked fine last night, but this a.m. wouldn't read the disc.
take a dry paper towel ......... get the DVD wipe the DVD in a one direction circular motion...
also is type of readable with your player .... note if you used a special software on PC than place into DVD player it might recognize the DVD
Jan 13, 2011 | RCA Televison & Video
Dvd player trys to read disc but stops with a HO7 message, worked fine last night, but we did put a dvd in to watch but something came on the tv we wanted to watch and didn't turn off dvd
HELLO
This is a motor problem. Here is what to do to put it right.
Open the disc tray and switch off the power, then remove the lid off the player. Locate the disc motor and where the spindle goes through the motor put a little WD40 or light oil (but not too much) or it will get messy.
Turn the disc motor a few times yourself and let the lubricant soak in. Leave it for about 30 minutes then try it again - and it should work.
This works in a number of cases, though I can't guarantee it will work for you. TRY IT! (:-)
Oct 14, 2009 | Panasonic DVD-RV32 DVD Player
Cannot read disc
call support from manufacturer on how to reset your player,
For instance, on Samsung players after it is powered on you hold in both channel buttons for 10 sec and the player restarts. essentialy like rebooting a computer.... that fixed mine that had the same problem
Apr 11, 2009 | Sony Televison & Video
Player won't turn on
Loud noise = diode is bad, and the dvd player needs to be repaired/replaced
Jun 16, 2007 | Toshiba SD-K740 DVD Player
Panasonic DVD-S55 DVD Player Logo
697 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
