Question about APC Back UPS 650 (APWBK650MC) UPS System
Too slow charge
I have regular power black out,that lst up to 3 or 3 hours few times a day.i haveconectd it to 100 Ah battery,and it works fine.the problem is it charges a way too slow how can i speed up the charging
    Problem Solver:
  • 14 Answers
If you wish to speed up the recharge time you will need to aquire a seperate charger for the 100 AH battery..make sure you use a blocking diode..to keep the two chargers seperate...if you need help on a diagram on how to do it let me know
Posted on Dec 31, 2008
HOW MANY WATTS DOES THIS MACHINE HAVE IM TRYING TO USE A 1440 WATTS INVERTER AND 24 V BATTERY ITS FAILING TO INITIALIZE??
With a 1440 watt and 12 volt, the battery must be over a thousand AH. (ampere/ hour) because for the 1440 watt, you need a current of more than 100 ampere. But even with a few hundreds of watt, you need a very powerful battery, because 300 watt, will pull 30 amps from the battery. A car battery with even 100 AH can't deliver that.
Mar 23, 2015 | Ricoh Aficio 2018D All-In-One Laser...
Acer Aspire 4830T battery behaving vaguely.
Are you using the provided charger, or are you using an after market "Universal" charger?
If you're using a universal charger, it could be charging the battery too hot and the computer just doesn't understand why the battery is putting out more than the system is expecting.
It could also be that the battery is wrong type. The voltage may be the correct, however the Ah may be too high. This being the case, the computer doesn't understand what why the it's getting a higher Ah reading than it's expecting. The system can not reason that that if it detects more amp-hours than the it should have that it has that much more charge time. It just sees "ERROR" and since you're dealing with a system function that is designed to prevent loss of data the default action is to shut down to prevent loss of data.
You may be able to fix by resetting the Power Management Options. Unfortunately, with out doing test on the machine, it is impossible to tell. I could be software or hardware. If nothing else works, try replacing the battery again.
Oct 11, 2014 | Acer Aspire Timeline X 4830T 14 Inch...
Can I put higher Ah batteries in my Shoprider Streamer?
Absolutely. Let me explain what "Ah" means. "Ah" stands for Amp Hours. A 32ah battery will run a 1 amp motor for 32 hours...or a 32 amp motor for one hour...a 16 amp motor for two hours etc.. As long as the battery voltage is the same it's absolutely fine. As long as your chargers are the correct voltage, they'll be fine as well. So basically, the higher the "Ah", the longer the battery will last. This is why higher "Ah" batteries are more expensive. Hope this helps : )
Jun 09, 2014 | Shoprider Streamer Sport Power Chair
Hiii , How are you today ? I have phone model is Nokia N86 ,My problem is after charger my battery full , maximum after 3 hours i receive message from my phone ,The message is Power saving mode...
Ifthe cell phone battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
May 18, 2011 | Cell Phones
My battery will not hold a charge for more than a few hours. It shows it is 100% charges and after a few days with the power orr, the charge is gone and I have to plug in to recharge.
Time for a new battery. My Toshiba "ate" batteries every 6 months. They will onyl recharge a number of times and then...that's all, folks. Replacements are on ebay, etc... BE SURE TO GET ONE with more milliamps than the standard one. They will stay charged longer.
Jan 17, 2011 | Toshiba Satellite M115-S3094 Notebook
It has been sitting for a year and I plugged it in for 3 hours now and went to use it and it doesn't turn on but the light on the battery is still green. what's wrong?
Your batteries are shot. If they haven't been charged for a year you won't charge them now or ever. Replace the batteries, charge before use and regularly as you use the chair. The new batteries need to be broke in and must receive use to get them to 100% Use your chair daily and charge daily for at least 20 days. Hope this helps
Nov 12, 2010 | NRS Hoveround MPV 5 - Used Power...
I buy a new power inverter ERP 2300 12v/220Volts
What does the inverter over 600 Watt.
By what type of battery is the inverter supplied? How many Ah? What is its state?
In order to achieve 1000 Watt for 1 hour you need a fully charged 12 V / 100 Ah lead-acid battery.
If your battery is less then 100 Ah and is not very well charged or old (bad) you may not have over 600 W, but not bacause of the inverter, but the battery.
If your inverter stops due to low input voltage (you can see it in the digital display during operation).
If you want to check the real output power of the inverter you should connect it to a big (more than 200 Ah) well charged battery.
Jul 22, 2010 | PowerBright Power Bright ERP2300-12...
My shaver doesn't stay charged very long
The motor is fine, what happens is that the internal battery loses the ability to fully charge and run the motor for a long period of time. While you "could" change the battery out with a newer one using solder, it's unlikely that it would cost less than buying a newer model at the store or from ebay. The average life of good shavers made a few years ago was about 3-5 years due to the type of batteries in it. I used mine with a charging cord for a while but that became an issue once while traveling. I bought a new one.
Nov 09, 2007 | Panasonic Classic ES 7006 N
Slow or fast charge
Yes, the amperage your charging at determines charging time. The higher the amperage, the faster it charges. Your battery is rated in mAh or milliamp hours. One Ah means the electric charge transferred by a steady current of one ampere for one hour. A mAh would be 1/1000th of an amp for one hour. If your battery is a 1500mAh battery it means 1.5 amps for one hour. This charge current should not exceed the rating of the battery. It would cause possible excessive heating and possible a fire or explosion, especially on newer more volatile batteries like lithium polymer batteries. The life of the battery charge when fully charged will be similar no matter how you charged it, but slower, lower amperage charges will maintain your battery better than quicker, higher amperage charges and help extend it's life to its potential.
Dec 11, 2006 | HP iPAQ RX3715 Pocket PC
APC Back UPS 650 (APWBK650MC) UPS System Logo
139 people viewed this question
Top APC Computers & Internet Experts
Alun Cox
ATS dude
Level 1 Expert
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
