Question about Saeco Vienna De Luxe Espresso Machine
Saeco Royal water leaks out and now blows wall plug if plugged in
I fill the water tank and at first I would just find water under the machine when wiping up and than i couldnt use it because as soon as i plug it into wall the wall plug blows
  • Anonymous Jan 24, 2009
    The coffee grinder m, I need my coffee
    oves then it stops without any coffee being made and the center red light comes on. Icanto RS SBS model
Clean behind the brew group - pull out the brew group and use a pipe clean in the little water weep hole in the back. then use pipe clean down from above the weep hole - it will be full of very wet coffee grounds.
Posted on Jan 04, 2009
I installed an extenal waterline to my new saeco royal professional coffee bar machine however instead of the water filling the tank it is running inside and leaking out of the side of the machine. the...
Hi
The water line to the back of the machine does not fill the tank. There is a pressure reducer/ isolation valve inside at the water connection that switches between using the tank or outside line. Is it leaking a lot of water or just leaking a little? I have seen them get a crack from shipping. You can still use the water tank until you can get the situation fixed. There is a selection in the menu that you choose for which way you want to go. Direct connection or water tank. If you put water in the tank it will tell you that your tank is empty. You have to go into the menu and change it to direct connection OFF, push the menu button and then exit.
Jan 16, 2011 | Saeco Royal Professional Espresso Machine
Saeco professional. Water tank needs filling, switch OK
Hi
It could be the magnet in the water tank. If it sinks you will get that message. How do you know the switch is OK?
Apr 27, 2009 | Saeco Royal Professional Espresso Machine
Saeco Royal Exclusive 30153... FILL WATERTANK
Hi Marty,
Make sure the magnet in the water tank flow up when you fill the water tank with water.
Aug 07, 2008 | Saeco Royal Exclusive 30153 Espresso...
Saeco Royal Exclusive expresso
hello you say sometime water leak out normally when the water valve seal is defective it will always leak. look under the water tank you got 4 plastic guide moulded in the container make sure no guide broken or missing a little pease of plastic if you got a pease missing add whatever missing inthe hole like a shim check it out cheers
Jan 11, 2008 | Saeco Royal Exclusive 30153 Espresso...
Water tank empty
the sensor is not working.. try to identify the sensor inside the tank and change it..
Dec 29, 2007 | Saeco Royal Professional Espresso Machine
Saeco Vienna De Luxe Espresso Machine Logo
139 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
