Question about Magic Chef 9512 Electric Single Oven
My magic chef oven will not heat in the oven or on the stove top after the electricity was shut off for a few hours. what could be the problem?
  • Magic Chef Master
  • 3,463 Answers
If it has a timer, make sure it is set to manual,and not flashing auto.
In the auto mode the oven will not work.
Plz rate this solutioin.
Thanks.
Posted on Jan 01, 2009
  • jeanette Sep 06, 2013
    my thermofanbaking is not working after our power went off. The fan comes on but the oved does not warm up at all!! the conventional baking works.
Oven Won't Heat To Desired Temp / Burner Quits Working Sometimes
The temperature sensor in the oven needs to be replaced. Here is the part to order. As far as the top element, lift the top up and look for lose or broken wires on the element. Keep me posted.
Nov 20, 2012 | Magic Chef Ovens
The bake function on my stove is not working. The oven is an electric Magic Chef Model 59FN-5TVW, serial 27C14791790. It starts to heat for approx 30 seconds, then stops.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 15, 2011 | Ovens
I have a magic chef gas stove witch has electric pilots.when i turn on oven it seems the electric pilot lights up but the burner doesn't come on.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Jan 06, 2011 | Magic Chef Ovens
I have a magic chef S68-3cxw electric stove/oven. It is flashing f2 can anyone advise what F 2 stands for
Hi, the F2 code on the Magic Chef Oven implies that the Oven temperature is too hot.
The solution is to replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness...
Oct 09, 2010 | Magic Chef Ovens
We have a Magic Chef glass top electric oven and the past few nights it has been beeping and showing a F-1 on stove top area
Hi
Thanks for using FixYa. F1 error indicates that the touchpad membrane is defective. To resolve this issue you’ll have to disconnect the ribbon strip: after disconnecting if there is no fault code then the membrane should be replaced, if the fault code still appears then the control board should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 08, 2010 | Magic Chef Ovens
Stove top hot when oven on
There is a vent tube that generally goes up to a back burner where you can use it for keeping something warm. There may be a problem with that tube falling out??? and all the heat is venting to under the stove top. Look fer it
Jun 26, 2009 | Magic Chef 9815 Electric Single Oven
Stove top gas burners are making my pots black with sut
the flames seem to be to high
try adjusting the air shutters underneath the cook top
May 27, 2009 | Magic Chef 9122 Gas Single Oven
MAGIC CHEF TIME SAVOR GLASS TOP
Hi - Please post the model number of you appliance, it will look something like CEC1536.
Thanks.
Jul 02, 2008 | Magic Chef 9512 Electric Single Oven
Magic chef stove and oven installed 1978
Yes this is normal. you can use that burner to keep things warm without turning it on, saves energy.
Dec 14, 2007 | Magic Chef 9512 Electric Single Oven
Magic Chef 9512 Electric Single Oven Logo
501 people viewed this question
Top Magic Chef Ovens Experts
Sal De
Oloyede Monsuru
Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
