Question about Marantz DV-9500 DVD Player
LG LHT874 5 disc started skipping on all discs
Have had this "home theater system" for a couple of months. Everything's been fine and then yesterday, it started skipping, both sound and picture. Then when a different disc was inserted, it was fine. Now it does it with every disc. Discs are clean and play in other players fine. Is there a cleaning system or some other home remedy to solve this problem? Thanks!
  • Anonymous Feb 27, 2009
    Return it. That's what we are doing. Already exchanged the unit once.
2 Suggested Answers
  • 2976 Answers
SOURCE: 5 disc cd changer CC4000 will not read
All players need cleaned from time totime. Do NOT try to clean it with anything other than a CD / DVD lens cleaner. They are available almost everywhere that sellsBlank media. It will clean the lens without scratching or smearing it.
Posted on Dec 06, 2009
My LG home theater can't read then reject the disc and write disc error. What can I do?
If the problem only affects a few discs, you can try cleaning and polishing the discs. If it won't read any disc, you'll need to have the optical assembly in the player replaced. It will probably be cheaper to replace the player.
Sep 13, 2016 | LG Audio Players & Recorders
Does not read dvds correctly. It stops and pauses without playing correctly, as if it were skipping, but all of the discs are fine.
Make sure the unit isn't overheating. They have processors in them to decode the digital video. If there are any fans make sure they aren't clogged up with lint. Th unit shouldn't have and thing sitting on top of it or sitting on anything hot. If all that looks good try getting a lens cleaner one for CD players should work. Its just a disc that plays that has little brushes on it. Best of luck!
Apr 04, 2012 | LG LHT854 Theater System
Some dvds play on this system but others skip. I have tried using a laser lens cleaner, but it does not fix the problem. Any suggestions?
Clean the disc. A drop of dish soap, wipe in a circuler motion. Let dry for a minute or two. Wipe fro center out on the disc. Not the player, but the disc is dirty.
Apr 19, 2011 | LG LHT764 Theater System
Hi,i have a samsung ht-txq120 home cinema system,dvd films freeze sometimes when playing,can you help
Hi I had this problem.
Aent it back to supplier had something replaced and it worked ok for a month and started doing the same thing so i went onto Samsungs website and downloaded the firmware onto a USB memory stick and loaded it onto the system, has been working fine for the last 6 months here is the link
http://www.samsung.com/us/consumer/tv-video/home-theater/home-theater-systems/HT-TXQ120T/XAA/index.idx?pagetype=prd_detail&tab=support
Oct 15, 2009 | Samsung HT-TXQ120 Home Theater System...
LG Blu Ray Player Disc Error for most Normal DVDs
Perhaps you may need to use a lazer cleaner in your blue ray player
Sep 18, 2009 | LG LXD5230 System
My LG LHB977 home theatre Displays NO DISC whenever I insert any disc.What could be the problem???
It may be a dirty "laser lens". It is possible to clean this lens w/rubbing alchohol and a Q-tip.
Disconnect all power b4 disassembly.
Aug 20, 2009 | LG LHB977 Theater System
"No Disc" message when trying to play DVD or music CD.
Try a "Laser Lens Cleaner" preferably one that uses fluid, run that thru the machine a couple times. You can find them at just about any retail store that sells CD's/DVD's or electronics. Next, if you have any liquid car polish, take a couple drops and spread on the surface of the disc. Use a microfiber towel to clean off. This helps clean off smudges and protects the disc from scratches. And it works great on damaged discs too! If your discs still do not play, then the unit needs to be repaired or replaced. Hope this helps
Jun 14, 2009 | Sony DAV-DZ720 Theater System
Samsung HT-XQ100
Does it happen with all discs? Maybe clean the discs because I notice the player is pretty sensitive
Jan 14, 2008 | Samsung HT-HDP40 - 800 Watts 5 Disc HDMI...
Sound skips alot while playing dvd
skipping audio or video on a cd or dvd is generally caused by a dirty lens or a bad disc. . Try a lens cleaner disc and get back to us ?? Thanks Good Luck
Jun 28, 2006 | LGDVT418 System
Marantz DV-9500 DVD Player Logo
130 people viewed this question
Top Marantz Televison & Video Experts
Are you a Marantz Televison and Video Expert? Answer questions, earn points and help others
