Question about Kenmore 74810 / 74813 Top Freezer Refrigerator
Ice catch bin
I can not find the ice-catch bin for my Kenmore Freezer model 74810. Can you tell me where I can order one for this model on line
    President:
  • 878 Answers
JK, if your model number starts with 253. this is your ice-bin. Part number 240385201. You can order it at http://www.repairclinic.com/0081.asp?RccPartID=891419 If your model does not start with 253, you'll need to post the complete model number...Catriver..post back.
Posted on Apr 23, 2007
I get crushed ice when its set for cubes
pull out the ice bin, and loook in back
there may be an ice build up around the lifter solenoid
Jul 19, 2011 | Kenmore Refrigerators
I have a Kenmore Coldspot ref, model # 78862898. The freezer literally has icicles hanging from the roof of the freezer, frost on food items. The ref isn't as cold as it should be with water...
Sound allot like there is a serious air leak....Is the door sealed good? You also have a defrost drain line plugged up behind the freezer panel you will need to clear that out with hot water after removing all the ice. watch this video to see how to replace the defrost thermosthttp://www.youtube.com/watch?v=z-h541_14ZE
May 26, 2011 | Kenmore Top Freezer Refrigerator
I have a Kenmore Model 795 refrigerator with an ice maker in the bottom drawer. We purchased the refrigerator in August of 2008 (currently November of 2010) and finally hooked up the ice maker last week. ...
The 795 model you make reference to only tells me that this is and LG bottom mount Refrigerator. There are several numbers missing from the model number. This is and example of a good part number: 79577253602 The filter for bottom mount LG units is usually in the upper RH side of the fresh food compartment. See this link: http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fK0810366-00001.png (item 611E)
The weak chlorine taste should fade unless the source is from your house water supply. Let the ice catch bin fill completely once and then dump everything in it. After that your ice should be normal. I think you may be noticing the taste you get from unused plastic tubing / water carrying parts. Just so you know if anyone used bleach to clean the freezer compartment the ice maker will catch any bleach water drips and pass that immediately into the ice. (Have very long customer warranty story with repeated in home visits about how I learned about people using bleach to clean freezer compartments!)
I digressed... just dump the ice collection bin after it is full one time and then check the ice taste on any ice after that. If you think maybe the taste is originating from the freezer compartment get a box of Arm & Hammer Baking Soda, cut off the top of the box and leave it in your refrigerator freezer for 6 weeks then toss it in the trash.
Another note no manufacturer will tell you is if you install a cheap in line water filter before the refrigerator water connection you can make the EXPENSIVE ONE on inside of the fresh food compartment last a very very long time.
Thanks for choosing FixYa,
Kelly
Nov 15, 2010 | Refrigerators
Kenmore 795-75202400 icemaker problem.
Good day,
Either the water valve opens to fill the ice maker cavity, and doesn't shut off soon enough, causing the ice maker to overflow.
Normal file time is approx. 7 seconds.
This is the most common problem.
As well, it is possible the micro switch in the ice-maker that tells the valve to open and close has malfunctioned.
This is all based on the fact that the freezer maintains a normal temperature.
To test the freezer for consistency, place a plastic glass in the freezer half full of water.
Check it in 8 hours. It should be frozen solid. Then place the glass in a plastic bowl, and lay the glass on it's side. Recheck in 24 hours. The ice should remain in the glass.
If not, there is a problem with the refrigeration system.
Nov 29, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
I have a one-year-old Kenmore Elite Trio 25 with an automatic ice cube maker in the bottom freezer. The unit makes ice just fine, but appears to fill the bin too full. When I pull the bin out to retrieve...
this particular model comes with an adjustable swing arm for ice prduction
pu the swing arm on the 2nd to last click
in the down direction
all the way down is off
Oct 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker is not working.
ice maker probably needs changed take a volt meter across the white and black wires to check for voltage if so change the ice maker,
for the compressor clicking on and off i recommend buying a universal 3n1 relay and trying it ... www.whirlpoolpartssurplus.com
May 07, 2009 | Kenmore 74810 / 74813 Top Freezer...
Kenmore 74810 / 74813 Top Freezer Refrigerator Logo
301 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Bill
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
