Question about HP iPAQ HX2795 Pocket PC
My PDA won't power down correctly.
I Can't power down, the off button doesn't turn it off and there is a small ghost window within the screen. I have taken the battery out but when i replace it i still have this section of a previous window there. Can anyone help please.
  • 26 Answers
That is a normal so don't worry.old model is will have a ghost on screed even you take out your battery or shut it down.It will disappear after a while.TRY IT
Posted on Dec 28, 2008
HP DC7800 doesn't wake up (and power switch does nothing!)
Bad setting. If you press and hold the power button, the computer will shut off. That will keep you from having to unplug it.
Jan 28, 2013 | HP dc7800 Business Desktop Small Form...
My 3ds xl screen has frozen
Hold down the power button until the screen goes black. Then press the power button to turn it back on. If this doesn't work, you'll have to remove the battery. If it still won't work, send it to Nintendo to fix; your limited warranty should still apply if it's the XL.
Oct 19, 2012 | Nintendo 3DS XL
How to repair red screen on asus eee pc sea shell
Remove any discs in the computer.
Hold the power button down until the computer turns off.
Press the power button to turn the computer on. If this doesn't work, proceed to step four.
Remove the battery and unplug the netbook. Wait 30 seconds.
Reinstall the battery and plug in the netbook.
Press the power button for ten seconds. If this doesn't work, proceed to step 7.
Insert the end of a paperclip into the reset button to reset the netbook.
The reset button is a small hole that usually appears next to the USB and other ports.
Windows 7
Create a new Notepad file.
Type this code:
taskkill /F /IM dwm.exe
Save the file as displayfix.bat in the following location:
C:/ProgramData/Microsoft/Windows/Start Menu/Programs/Startup
Restart your computer.
hope this helps
Sep 25, 2012 | ASUS Eee PC Seashell 1215N-PU17-RD...
Neo Notebook model no. LC89-black screen only.
  1. All Operating Systems
    • 1 Remove any discs in the computer.
    • 2 Hold the power button down until the computer turns off.
    • 3 Press the power button to turn the computer on. If this doesn't work, proceed to step four.
    • 4 Remove the battery and unplug the netbook. Wait 30 seconds.
    • 5 Reinstall the battery and plug in the netbook.
    • 6 Press the power button for ten seconds. If this doesn't work, proceed to step 7.
    • 7 Insert the end of a paperclip into the reset button to reset the netbook. The reset button is a small hole that usually appears next to the USB and other ports.
    Windows 7
    • 1 Create a new Notepad file.
    • 2 Type this code:
    • 3 Save the file as displayfix.bat in the following location: C:/ProgramData/Microsoft/Windows/Start Menu/Programs/Startup
    • 4 Restart your computer.
Sep 20, 2011 | Computers & Internet
My tower will not power "on" I shut-down the
Remove the power cord.
Locate the 120V / 240 V ac selector switch. (within 4 inch from the power inlet)
Move it back and forth few time.
Make use it's set to the correct voltage selection.
Reconnect power cord and power up.
===== This AC selector switch can get shifted and set to different position.
Jul 28, 2011 | Acer Aspire™ T180 PC Desktop
Sharp pda yo-370 will not turn on
okay this is what you gotta do unscrew the back of your PDA and you will see your two batteries and some stickers, in between the batteries there is a rectangle. take your screw driver and push the little bars inside the rectangle back. this will unlock your screen. if it still doesn't work hold the on button and press reset this will delete everything but also turn it on. if it still doesn't work throw PDA at wall, save up money, and get an IPad.
Apr 03, 2010 | Sharp YO-270P
I was trying to move an address list from the computer to my hand held and suddenly it has Please Wait on the screen of the hand held and it will not turn off or do anything
try to hard reset
It is some time very important to Hard reset a PDA for example if you want your PDA to be factory default or or operating system corruption etc the following are the information, how to do a hard reset on every PDA as different PDA manufacturer have different methods.
To hard reset, press and hold the power button and press in on the reset button (reset hole) on the back of the unit for about 2-5 seconds. Release both buttons and you will see a confirmation screen asking you if you would like
Dec 31, 2008 | Computers & Internet
The Screen is back and it won't charge
Hello, it isn't that simple as a broken charger. Try the following thing. Connect battery to the PDA, check that the battery LID is connected FIRMLY to the body (there is a contact there that woun't allow the PDA to start if the lid isn't connected properly, you may want to check it too, look carefully for a small black thing and check that it can be pressed). Then connect the pda for half hour to the charger, even if no light or amber led is flashing. Then make a master reset as showed here and connect the PDA to a usb sync cable with your computer. Press simultaneous the soft reset and the power button, then press only the soft reset button. The PDA should start. If not, there is a problem with a DC converter component on the mainboard or the connector I was talking about before. Even if the charger is broken, your PDA should power on from USB cable. Good luck, feel free to ask further questions and always remember to rate replies received from this site :)
Feb 27, 2007 | HP iPAQ H2210 Pocket PC
PocketPC e570, Is there an opportunity to set it back to factory default?
you could set back the e570 factory default very easily. On the left side of the pda you could find a small button, called RESET button. You have to do these following steps: The pda have to be turned off, then press the power button while pressing and holding the reset switch with the stylus, release the power button and when a screen appears, release the reset switch. But be careful, when you reset your pda all data will be lost and make sure that all storage cards are removed!!!
Sep 11, 2005 | Toshiba Genio e550
HP iPAQ HX2795 Pocket PC Logo
211 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
