Question about Brother HL 1440 Laser Printer
"Groaning" sound; then stops printing
Prints for three or so pages, then makes the groaning sound, then stops printing and the red/green lights blink. Can reset but happens again each time. Checked and no paper jam at all.
  • Anonymous Jan 03, 2009
    Printer will print fine but groans on each sheet that moves through. Just replaced the toner but groaning persists...
Solution: Bought a new printer.
Posted on Dec 28, 2008
GE Spacemaker microwave makes groaning sound when start button is pressed for a second or two then blows the internal fuse. After replacing the fuse everything seemed to work, lights, exhaust fan, cl
Could be a lot of things but most probably a shorted high voltage diode assembly. If not that then the magaetron or capactors. Remember be careful there are high voltages even when the oven is unpluged. The capactors are usually charged and must be discharged. If you don't know what yor doing then time to get a qualfied tech.
Good luck
Feb 14, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Replace transfer roller
Groaning noise on this model is usually down to third party consumables, Has this noise started after recently( within 5000 prints) replacing one of the colour toners cartridges, If so - you should replace the same cartridge with a HP OEM product and see if this cures the fault 99%of the time third party consumables do not replace key components when Re-Manufacturing Toner/Drum units to save on cost - however this causes Major issues with the expected Life of the Printer as A whole. Added stress on the drive systems due to poor toner units will invalidate any warranty/Repar Cover you may have, Despite what the adverts say CHEAPER toner Units Do Not Give You Cheaper Prints. They Just amage the rest of the Machine>>>>...
Sep 13, 2013 | HP CP3525DN Color LaserJet Printer
Amana side by side fridge makes a groaning noise when freezer is shut, no ice buildup nothing, just groans when light button is pushed
When light goes out, fan starts inside. Groaning sounds like the fan is hitting on something or has a dry bearing. Spray with wd40 on the shaft
May 01, 2012 | Amana Refrigerators
How do I repair a Freezer fan not working
mount out the fan and replace it with a new one.
Mar 27, 2012 | Refrigerators
Fridge Freezer makes 'groaning' noises
Sounds like it could be the icemaker . If the icemaker heater is bad , (replace icemaker ) , then it will groan while trying to dump the ice .You can try turning the icemaker off for a day and see if that stops the noise .
Aug 29, 2009 | Refrigerators
96 Grand Am Groaning
Sounds like the power steering pump failing. If it seems to be worse when you turn the wheel at a stop, it is time for a new p/s pump.
Jun 26, 2009 | 1996 Pontiac Grand Am
Loud Abnormal Sounds with each print job
It may be a paper feed issue. If using a duplexer, try removing the duplexing unit and try printing again. It's often attached to the back of a printer.
May 21, 2009 | Dell 3100cn Laser Printer
Groaning noise on GE side by side refrigerator
Usually the groaning noise is from a locked up icemaker. Remove the icemaker and defrost it with hot water. Check to make sure the unit is in good shape and not chipping. Let it dry out and then reinstall.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/robert_e97a69269ae71345
Jan 05, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
1710 Dell Laser Printer
Check the gears on the drum and the toner..it may have worn out...
Aug 01, 2008 | Dell 1710n Laser Printer
Brother HL 1440 Laser Printer Logo
197 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
