Question about Cobra 29 LTD CB Radio
Transmission only in close range when mic needle goes to far rt
New radio
    Problem Solver:
  • 6 Answers
Make sure your Antenna SWR reading is 1:2 or better, also have your antenna as hish as possible with a sufficient groundplane and remember that indoor antennas will not be anywhere as efficient as an outdoor one. If you have lots of surrounding buildings or trees this can effect your TX and RX.
Posted on Sep 05, 2009
How do I cast on in knitting
Hi I am not a great knitter but I do know how to cast on stitches.
OK here goes, Get your two knitting needles and wrap the wool around both loosely and tie a knot, holding one needle in your Lt. hand and one in your Rt. hand (Rt. needle point is under the Lt. needle point and loop of wool is around both needles)
**take the loose end of wool in right hand and put it around the point of the Rt. needle towards you while holding every thing firmly, with your Lt. middle finger push the point of the Rt. needle back towards you and at the same time twist the Rt. needle up with your Rt. hand, catching the wool you just looped around the point of the Rt. needle, return Rt. needle back behind Lt. (you now have 1 loop on both the Rt. & Lt. needle) Still holding both needles bring the Lt. needle to the front of the loop on the Rt. needle and slip the loop over onto the Lt. needle
YOU HAVE JUST CAST ON 1 STITCH.
Insert the Rt. needle into the stitch you just made and positioned under the Lt. needle***.
Repeat from ** to *** until you have enough stitches.
NOTE to make a firmer row after the first stitch put the Rt. needle behind the complete loop not just the front of the loop.
**taking loose end of the the wool in your Rt. hand , loop it around the point of the Rt. needle towards you while holding every thing firmly, with your Lt. middle finger push the point of the Rt. needle back towards you and at the same time twist the Rt. needle up with your Rt. hand, catching the wool you just looped around the point of the Rt. needle, return Rt. needle back behind Lt. (you now have 1 loop on both the Rt. & Lt. needle) Still holding both needles bring the Lt. needle to the front of the loop on the Rt. needle and slip the loop over onto the Lt. needle ***
Same as previous instructions and keep repeating until you have enough stitches.
Jan 03, 2016 | Crafts & Hobbies
My galaxy 98vhp radio cb don't keyed?
One of the wires in the mic plug is probably broken off. Probably the wire on pin 3. Pin 3 should be transmit. Could also be the wire(s) on pin 1 depending on what mic you have.
Feb 10, 2014 | Radio Communications
TRC-466
if you post on this site the wiring for your mic I'll tell you how to get more modulation. there are a number of people looking for this wiring and I don't do wiring unless I really have to. Now if you open the radio and look at the components side you will look for a transformer with a variable real close to it. Thats the modulation transformer .now you will need a modulation meter for this part. look at the needle and turn the variable to the left as you talk on it. If the modulation goes down then crank it the other way and watch the needle go up . Simple??
Jan 22, 2012 | Radio Shack Radio Communications
Looking to buy connex4300hp for 150.00.think its a good deal but dont know that much about it.gonna run 18ft coax to wilson 2000 w/astatic 636L.how do i set-up for best performance?=bands,knobs on...
A new unit goes for $280 range
then conversion to run cb freqency $30.
Tune-up $50 you should get 70 watts older units 90 watts newer units
As far as the knobs go
Band D with channel 19 selected this is 27.185 citizen band if you radio has had the channel expansion done other wise it is not accessible.
Select AM
10 khz switch should be off
mic gain know depends on the tuning of your radio and mic choice.
rf gain full clockwise best reception you will just have to play with this knob and the squelch to your liking
Make sure the thing is working properly before you buy capacitors dry out and the connex radios are know for problems with their pcboards. good luck
Aug 29, 2011 | Connex CX-4300HP CB Radio
My bluetooth h700c is fine on my end but the other person can barely hear me.
There is a problem with the mic of your device.
It is quite normal for your mic to experience certain problems like poor transmission of sound and it is also a normal happening if the mic gets covered or blocked by tiny particles like dust.
The following steps should be taken, if the problem persists after doing them, then you may have to send it for repairs.
1. Use a sharp pointed object like a needle to clear the opening of the mic. Be sure to do this carefully and not to push the needle all the way in as doing this could permanently damage the mic.
2. Also, check your phone or mic settings if the mic volume has been set to a very low level that it is affecting your audibility.
3. Lastly, make sure that the mic is not close to any source of noise and is not to far from the phone while you are making the call. In other words, ensure perfect connection between the phone and the headset.
If the problem persists after doing this, then you have to send it for repairs.
Hope this was helpful?
Feb 14, 2011 | Cell Phones
My galaxy 959 sqeals and does not receive or
mike has wiring problems. Check for breaks in cord and where the plug goes into the unit. If not original mike then has incorrect wiring for the radio and will need to be changed for config
May 01, 2010 | Galaxy Radios DX-959 40-Channels Base CB...
Cobra 29 ltd classic needle doesn't work correctly
Don't worry about the meter in the radio. They are only close to actual reading any way. Just get an external meter. you are better off in the long run, and you don't have to mess with anything inside the radio if you don't know what your doing.
If you must have the meter working correctly, then take it to a truck stop CB shop, or any other cb shop and have it aligned. It should cost about $30. There is equipment needed to align a radio properly and the cost for it far exceeds what an external meter, or having a cb shop align the radio.
Mar 10, 2009 | Cobra 29 LTD CB Radio
I can hear people talking, but they can't hear me, or they say I sound like an alien
Check to see if the meter needle is swinging backwards when you key up. If it does your final may be bad. If the needle goes forward and others say they see your keying up but no sound your audio chip may be bad; especially if you have tried so many mics and antennas. If your radio has a swr warning light and it comes on this could extremely limit your range and others may not hear you and contiued use will damage your radio. Good luck!!!
Jul 26, 2008 | Cobra 29 LTD CB Radio
The whip on my antenna came loose.
ok you have probly bernt your finals my friend because if your swr is jumping about then the radio is putting out diffrent power all the time check it with a power meter and get bk to us hope this helps my friend:):):)
Feb 05, 2007 | Uniden PC78ELITE 40-Channels Base CB Radio
Cobra 29 LTD CB Radio Logo
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
