Question about Hotpoint WMA50 Front Load Washer
Washer doesn't spin
Hello, My washing machine does not spin. The machine makes a noise as if it is spinning, but the drum does not actually spin. Everything else is normal. Many thanks
    President:
  • 1,294 Answers
Does the machine pump water out? Could be there is some block in the outlet pipe, check by opening machine's rear panel. - Does the motor spin ? - In case your machine uses a belt for drum's movment, check that belt isn't broken or loose. In case motor receives power, check for motor's resistace and free movement while turning it by hand. If it dosen't get power looks like its a timer problem. Caution re electrical connections, unplug before examining rear.
Posted on Apr 24, 2007
Washer does not spin. Makes noise but drum doesn’t move
replace the rubber drive belt, unplug the machine remove the back panel to reach it as they do get worn and will wash but as the load sits at the bottom of the drum in spin mode the drum becomes heavier when the washing is sitting in the bottom its harder to start the rotation eric
Jan 18, 2018 | Washing Machines
When spinning on highest spin make very loud noise like brick inside then heard loud bang and noise stopped washer carried on spinning
Hello that sounds like a broken spider that's blotted to the drum what hold the drum to the bearings if one is broken that will do that the banging is when it pop out on a spin it sounds like a brick hitting the back I would be very carefull as it can try and flip the machine if it catch the drum it's not bearings as you said it stopes and it was ok so it's the spider and most drums are sealed units so you can't do any thing ok hope this has helped you
Nov 13, 2015 | Washing Machines
I have a kenmore 800 series washer that makes a loud slamming noise at the end of the spin cycle. If you lift the lid during the spin cycle the basket slams to a halt immediately. It actually moves the...
Those parts you can check
1/ strings holding the drum were broken causing drum unbalancing when it spins.
2/ Drum bearing also gone. (noise)
3/ 3 slides that located underneath the triangle frame need replaced.
Oct 22, 2013 | Washing Machines
Candy1682d/180 will not spin with clothes in drum, empty drum and will spin what's the matter
Hello - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly, faulty pump, the timer or control board not communicating correctly.
Nov 02, 2012 | Frigidaire ATF6000ES Front Load Washer
How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin Read more: How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin | eHow.com http://www.ehow.com/how_6496482
Hello - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly or the timer and control board not communicating correctly. Contact a professional to move forward accurately.
Oct 21, 2012 | Frigidaire Affinity ATF7000E Front Load...
Fridigaire fwb9200es1 washer making rattling noise when spinning
Hello terilym - From what you have described it sounds like you possibly have foreign objects such as coins or safety pins in the tub or pump. I suggest unplugging the washer and carefully check the tub and to verify that the drum is also not damaged. If noise continues after washer is restarted, objects may be in the actual pump. Contact a professional to accurately diagnose and repair the unit.
Sep 30, 2012 | Frigidaire ATF6000ES Front Load Washer
Noisy on spin cycle
It's very difficult to advise on a noisy washing machine because you can't describe noises accurately enough. People often describe the same noises quite differently.
Generally though, if a washing machine is rumbling, and noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on washing machines due to water getting into them if the drum bearing seal fails. To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings have probably gone.
Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure is a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust.
Other causes of a noisy washing machine are coins and other obstructions inside the water pump. This will cause noise when the washing machine is emptying the water. Coins or other obstructions can get trapped between the outer tub and the inner drum. This would produce a lot of noise on spin as they coins get tossed around inside. Usually, spinning the drum by hand will not reproduce the noise in the case of coins as the coins drop to the bottom of the tub when the washing machine isn't spinning.
A light scraping noise when the drum is turned by hand is usually a bra wire trapped between the tub and drum.
A high pitched squealing or harsh noise can be motor bearing wear. This can also be checked for by taking the belt off and running the motor alone.
A knocking noise can be a loose tub weight. This would be worse with heavy loads and would not be present on spin with no washing in. This is because the knocking noise is caused when the tub (or outer drum) shakes about on spin. Without washing inside the drum the tub doesn't move. Another symptom of a loose tub weight is grey concrete dust under the washing machine.
It's very tempting to ignore noises while the washing machine is still otherwise working. Some noises can be ignored as they will not develop into serious faults. Other noises, if left, will cause extensive damage and can end up costing considerably more than if tackled early or these days writing the washing machine off. Of course the problem is that you can't tell which of the categories a noise falls into - so ignore them at your own risk.
Jul 28, 2012 | Roper Washing Machines
My fridgedaire front loader washing machine has been making weird noises when it spins or washes, making sounds like there is loose metal inside somewhere rubbing and clanking around. As of last night...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 13, 2011 | Frigidaire Washing Machines
Drum appears to be loose and makes a lot of noise when on the spin cycle
With the washer empty, spin the wash tub by hand. The drum should be spin true without any noticeable wobbling and spin without much noise. If it wobbles or makes any kind of rubbing or banging noise as you turn it by hand. The problem is that the spider support arms are broken. It is an expensive repair job since the washer has to be completely torn apart and the wash drum needs to be replaced. Get a few estimates before deciding whether to repair or replace. Sorry.
Mar 08, 2011 | Whirlpool AWM6100 Front Load Washer
Hotpoint WMA50 Front Load Washer Logo
139 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
