Question about Canon imageRUNNER 3300i Printer
Error E602-001 Right when we turn on the IR3300i the error E602-001 comes up on the display. We looked the error code up and it says that the hard drive is bad or not being read. We reseated the hard drive and still we get the error. We took out the hard drive, which is a 20Gig, and hooked it up via external usb to a pc. The PC does not recognize the hard drive either externally or internally and the drive gets really hot, really quick. Our question: do we need to install software on the hard drive or can we just replace the hard drive itself and be fine? If we do have to install software where can we get it and do we need a service tool? Thank you for any and all help avaliable.
  • vikingkeith Dec 28, 2007
    I have the same problem and would love a solution.
  • Anonymous Nov 09, 2008
    can we buy this Hard disk with necessary software preferably with more space for storing more user id's with more space for each user. where is it available for purchase
  • 35 Answers
The hard drive does need to be replaced and must be done by an authorized Canon service tech (like me) who has access to the system software. The system software ( or firmware) is installed on the new hard drive using Canon's Service Support Tool. Check here to find your local authorized Canon dealer.
http://www.usa.canon.com/opd/controller?act=OPDSupportDetailAct&fcategoryid=2275&modelid=889
Posted on Nov 09, 2008
  • Don Botha
    Don Botha Jun 13, 2016
    what if the harddrive is used, soft ware should be good right? how many wires connects to the harddrive - 2 or 3?
SOURCE:
Error code 602-603
hi that error indicates there is a problem with the hard drive unit
maybe corrupted software of damaged HDD
Apr 25, 2016 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
When the Canon IR 3300 switchs on it displays the Error code E000602-0003 please help me what to do
This error belongs to the Hard disk of the copier. Please re-install the system software in HDD or replace the HDD with new one.
Oct 08, 2015 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
How can i solve ir33oo error e000007-0000
Hi . The fixing film is damaged and need to be replaced to fix that error
Jun 24, 2015 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
How do i solv error 100 code in canon ir3300
Hi Raj
please follow link it will give you all the error codes and also will tell you what your one is..hope this helps
Dec 23, 2014 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
My Canon ImageRunner 3300 displays an error code of E000002-0000
Hi, go onto google and type in e000000-00002 and you will find that you need to change the format for the printer.
Dec 21, 2014 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
Hard disc error
the error refers to PDL board mounting error- suggest if the machine has been moved or if any parts have been removed or replaced you check ALL pwb board connections this could take some time to complete try to start where you have been working in the machine first.
Jan 16, 2014 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
Canon ir 3300 e000585-0000 error
Please reset your machine:
Do this:
1. Press * 28 * on your machine in a quick move.
2. Select copier
3. Select Err.
4. Select Clear then press O.K
5. Turn your machine off for 1 minute and turn it on again.
The error code should be gone, and the printer/copier should work again.
Jun 04, 2012 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
Canon imageRUNNER 3300i Printer Logo
1,041 people viewed this question
Clive
Clive
old marine
old marine
