Question about Canon MX300 Office All-In-One Printer
Canon Pixma MX300 fax vs voice
I'd like the fax machine to receive a fax if nobody is home but return control to my answering machine if it's not a fax. So far I can only make one or the other happen by setting the number of rings on each. The one set to the lowest number of rings takes the call.
If I make the fax (printer) answer before the answering machine and it's not a fax, the call doesn't get passed back to the phone system.
If I let the answering machine answer before the fax, it doesn't pass control back to the fax machine if it is an incoming fax.
Sheff
  • sheff962 Dec 28, 2008
    I tried setting it to Tel Priority mode as described on page 46 of the quick start guide (as seen on your link) but when we don't answer the phone it doesn't take a message.
    It could be the fact that it's not an actual answering machine. It's Bell's "call answer" service that takes a message after 5 rings.
    Might have something to do with the fact that the printer/fax answers the phone to see if it's a fax or not and at that point, Bell assumes the phone was picked up and washes it's hands of the call.
    Sheff
    FY ... for whom it may concern ...
    I went to visit my client today and we set up a real answering machine, as opposed to Bell Call Answer.
    Problem solved.
    So our suspicions appear to be correct. Once the fax/printer grabbed the call to determine it's origin, Bell assumes the phone has been picked up and the call cannot be returned to Bell Call Answer to take a message.
    Sheff
  • 837 Answers
I haven't checked the manual specifically but if you are "manual-less" here's a link
Posted on Dec 27, 2008
  • Jay Glendenning
    Jay Glendenning Dec 28, 2008
    I would agree to that. Bell's "answering" or your "answering" are two seperate things and as you said .. Irregardless of what answers at your end .. Bell only provides the means of communication at that point .. nothing more
Can't send or receive faxes
it's most likely the compression on the phone line or you need to set up your fax machine for proper receive mode.
Contact your phone service provider to see if they support faxes.
(Faxes cannot handle nearly as much compression as standard voice)
Jun 09, 2010 | Canon PIXMA MX300 All-in-One Printer
Canon MP830 has stopped receiving faxes. When the fax phone number is called it rings but the fax does not pick up.
Can you still send fax? if sending and receiving are not working you can try to update or uninstall/reinstall the software for this unit..
Hope that helps.............
Aug 15, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Machine tries to fax while on phone
Hi ...
There are situations when fax interrupts the telephone conversation. The possible cause of this issue is Remote RX feature on MP 780. There are 3 possible solutions to these problems which are listed below:
I) Change Remote RX ID on MP780
  1. Confirm the <Fax> button light is lit. If the light is not lit, press the <Fax> button.
  2. Press <Menu> button. [RECEIVE MODE] will appear on the display.
  3. Press < (left arrow) or > (right arrow) to select [RX SETTINGS].
  4. Press <OK>. [ECM RX] will appear.
  5. Press the < (left arrow) or > (right arrow) to select [REMOTE RX].
  6. Press <OK> twice. The current Remote RX ID number will appear.
  7. Press < or > to select the desired Remote RX ID number. The options are from 00 to 99.
  8. Alternatively, you can press the numeric keypad to select the number.
  9. For example, to select [38], press <3> and then press <8>.
  10. Press <OK>.
  11. Press <Stop/Reset> to return to standby mode (date and receive mode will appear).
II) Turn off Remote RX on MP780
  6. Press <OK>. The current Remote RX option [ON] will appear.
  7. Press < or > to select [OFF].
  8. Press <OK>.
  9. Press <Stop/Reset> to return to standby mode (date and receive mode will appear).
III) Choosing a receive mode MP780
If you want to receive only faxes automatically with your machine, or you have a dedicated telephone line for fax use only:
  • Select [FAX ONLY MODE].
    When you receive a fax call: The machine will receive the fax automatically.
    When you receive a voice call: You will not be able to answer the call.
If you receive mainly voice calls and sometimes faxes, or you want to receive faxes manually:
  • Select [MANUAL MODE].
    When you receive a fax call: The telephone will ring. Pick up the handset and if you hear a beep, press <Black> or <Color> on the machine to receive the fax.
    When you receive a voice call: The telephone will ring. Pick up the handset to answer the call.
    For remote receiving: If you are far from your machine, dial 25 (the remote receiving ID) on your telephone to receive faxes. (Telephone being used, such as a base station for a cordless phone, must be connected through the MP780 for the remote receiving function to work.)
If you want to receive voice messages on your answering machine and receive faxes automatically:
  • Select [ANS.MACHINE MODE].
    When you receive a fax call: First the answering machine connected to your MP780 will respond to an incoming call, and then the MP780 will receive faxes automatically.
    When you receive a voice call: The answering machine connected to your MP780 will respond to an incoming call.
If you want to receive faxes automatically as well as voice calls:
  • Select [FAX/TEL AUTO SW].
    When you receive a voice call: The machine will ring. Pick up the handset to answer the call.
If you have subscribed to a Distinctive Ring Pattern Detection (DRPD) Service with your telephone company (US only):
  • Select [DRPD].
    When you receive a fax call: The machine will ring according to the ring pattern you have chosen and receive the fax automatically.
    When you receive a voice call: The machine will ring according to the ring pattern you have chosen. Pick up the handset to answer the call.
Dont' forget to vote if this helps .... Cheers :)
Jul 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
CANON MX300
Here's the page where you can download the drivers and manual:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=15601
Just scroll through them and find the proper manual for your operating system, and download.
Please rate if this helps :)
Mar 05, 2009 | Canon Office Equipment & Supplies
Incoming fax vs voice
Contact your telephone provider and see if they can offer you a second number for the line and "destinctive ring".
If your fax unit supports this feature, the fax number can do a double-ring where the normal number does a normal ring. The fax unit would then pick up double-ring calls.
Dec 27, 2008 | Canon MX300 Office All-In-One Printer
Need to find printer part
From http://www.canon-europe.com/Support/Consumer_Products/services_locator/index.aspx
Electroversal
Photo Printers, Inkjet Fax, Scanner, InkJet Printer, Laser Printer, InkJet MFP
Electroversal provides a return to base service for A4 Bubble Jet Printers, PIXMA iP90/iP90V, Selphy, CP, DS & PIXMA Mini Printers, the Fax B820 & B840, JX200/500, PIXMA MP110, MP130, MP140, MP150, MP160, MP170, MP180, MP210, MP220, MP450, MP460, MP470, MP510, MP520, MX300 & MX310, the LBP2900, LBP3000 and Scanners (except the dedicated 35mm Slide Film Scanners 2700F, FS2710& the FS4000US – Canon UK RCC).
Unit 2
Sedgwick Road
Luton
LU4 9DT
Tel: 01582 582023
Fax: 01582 582 087
Web: www.electroversal.com
To obtain a repair quote for products serviced by Electroversal, please call Electroversal Customer Service department on 01582 582023 or email sales@electroversal.com
CRC (Tasktron Ltd)
Photo Printers, Inkjet Fax, Calculator, Scanner, InkJet Printer, Laser Printer, InkJet MFP
CRC Tasktron Ltd provides a return to base service for Calculators, A4 Bubble Jet Printers, PIXMA iP90/iP90V, Selphy, CP, DS & PIXMA Mini Printers, the Fax B820 & B840, JX200/500, PIXMA MP110, MP130, MP140, MP150, MP160, MP170, MP180, MP210, MP220, MP450, MP460, MP470, MP510, MP520, MX300 & MX310 the LBP2900, LBP3000 and Scanners (except the dedicated 35mm Slide Film Scanners 2700F, FS2710& the FS4000US – Canon UK RCC)..
Unit 3 Wintonlea
Monument Way West
Woking
Surrey
GU21 5EN
Tel: 01483 776 060
Fax: 01483 721 389
Web: http://www.crc-tasktron.co.uk
Cura Technical
Personal Copiers, Laser Fax, Inkjet Fax, InkJet Printer, Laser Printer, InkJet MFP, Laser MFP
CURA Technical provides on-site service for A3 and PIXMA iP90/iP90V, laser Beam Printers, PC/FC Copiers, Multifunctional Printers and Fax machines. On-site service can be arranged by dialing 0844 369 0100.
Please note that Cura Technical do not service the following products: Selphy, CP, DS & PIXMA Mini Printers, Fax B820, B840, JX200/500, PIXMA MP110, MP130, MP140, MP150, MP160, MP170, MP180, MP210, MP220, MP450, MP460, MP470, MP510, MP520, MX300 & MX310 and the LBP2900 & LBP3000. These units are repaired at our Return to Base Agents, Electroversal or CRC Tasktron Ltd.
Cura Technical
Uniter House
3 Radford Way
Billericay
Essex
CM12 0DX
Tel: 0870 400 2080
Web: http://www.curatechnical.co.uk
Dec 17, 2008 | Canon PIXMA MP610 InkJet Printer
Canon pixma mx 300 won't send or receive fax
Dear friend,
it's very important to connect your MX 300 with the telephone line the right way! Please read once more the part "Preparing the machine for fax" in the chapter "Faxing" of the MX 300 User's Guide and mind the hint "Important: Do not connect the machine and external devices in parallel to the same telephone line using a splitter (A). The machine may not operate properly."
Greetings from Cologne (Germany) to the UK!
Dec 02, 2008 | Canon MX300 Office All-In-One Printer
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon pixma mx300 drivers for vista
hi i am a certified Canon4.gif repair tech for this printer. if you follow the link below this will take you to Canons support site where you can download the software for your printer. hope this helps
http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Dec 28, 2007 | Canon MX300 Office All-In-One Printer
Canon MX300 Office All-In-One Printer Logo
113 people viewed this question
old marine
old marine
