Question about Empire GWT-25 Wall Mounted Panel Heater
I have a vented wall furnace, when the pilot lights it slowly gets smaller and smaller until it goes out. What can I do? I am in the middle of a lake in an ice shack.
  • 78 Answers
It needs a new thermal coupling. thats the copper tube, one end is in the pilot, the other end is srewed into the valve
Posted on Dec 28, 2008
Williams wall heater 2509622. How do I keep the pilot on? It tends to turn off after it reaches the desired temperature.
WILLIAMS 2509622 OWNER'S MANUAL Pdf Download. > Brands > Williams Manuals > Furnace > 2509622
2509622; 2539622; 2559622; 3509622; 3539622; 3559622; ... WHAT TO DO IF YOU SMELL GAS: ... Williams furnace co. direct-vent wall furnace owner's manual (24 pages) ... Caring for Your Furnace ............24-25 Locating Wall Furnace and Thermostat ........6-7 Learn how to keep your new Williams Furnace operating.
How to light Heater or Furnace Pilot Light Gas Pilot of ...
? 5:01
Oct 25, 2013 - Uploaded by 3p0cHx
How to light a gas pilot for a heater or furnace of the Williamstype. This is a general guide and is not ...
[PDF]Monterey Installation Instruction Manual - Home Depot
Dec 08, 2015 | Williams Heating & Cooling
The pilot goes out when the heater cycles
The thermocouple is not working correctly. sometimes you can clean the soot build up from it and it will work again. sometimes they just need replacing. the thermocouple is what the pilot light flame heats up when you turn on the heater. when the thermocouple gets hot it sends a 20 to 60 millivolt signal to the gas valve to activate the gas flow to the main burner.
Feb 18, 2015 | Williams Wall Heaters: 50,000 BTU/Hr...
Empire wall furnace pushing down the pilot button trying to light the pilot found too much gas flowing
Is the button on the gas valve or a red button in the line to the pilot assembly? If its in the line, there is a regulator upstream of the button. If the gas is coming from the gas valve, there is a small screw covered hole in line with the pilot line in the gas valve. If neither of these apply, you may need to replace the orifice in the pilot assembly. Let me know how it goes.
Nov 19, 2013 | Empire Comfort Systems Direct-Vent Wall...
Gas wall furnace pilot goes out when burner turns off.
When the main burner turns off, does it make a whoosh or pop? If so, this would be the issue causing the pilot to be disturbed. And have you tried to adjust the pilot/thermopile strength, if possible? A stronger pilot may help. Now if the main burner slowly goes out, and the pilot also slowly goes out, and also slow to ignite, and you've replaced about everything else, it may be the gas valve itself that has/is giving up. Gas is impure and causes a sticky residue. And if the main burner is "slow to act", this tells me the piston that's inside the valve is slowly opening or closing, and may be the reason the pilot is acting up. Make sure you check the outlet to your flue pipe also for obstructions. If the unit doesn't vent properly it can have more heat in the flue. That heat can have a downward rush when the burner goes out, kinda like forcing air through a clogged tube. And when you quit forcing the air, some of it comes back at you. Before condemning the valve try to check all else as you have done with the thermopile and such. Please work safe and I hope this helps.
Oct 09, 2017 | Williams Heating & Cooling
Vulcan Gas Heating Furnace Pilot Light Goes Off
Clean pilot may be too small blow out with tube or air line , thermocouple not working try changing it
May 19, 2012 | Heating & Cooling
I have a Vulcan Gas wall furnace that is not working. We cannot work out how to light the pilot light. According to the documents we have it is a 26.4MJ model or the 40MJ model
The Quazar manual says....
-Thermostat control knob to 0
-Then press and hold down * (Star) button
-The press the "ignition" button one or more times until the pilot lights
CONTINUE to hold the * button for at least 15 seconds and release slowly making sure the pilot stays lighted.
-If the pilot goes out.. repeats steps above and hold the * button for much longer than 15 seconds and THEN release the * button slowly.
May 06, 2011 | Heating & Cooling
Wall furnace troubleshooting
A thermocouple is inexpensive.  Replace if in doubt.  Get a professional in to do safety checks.  You may also want that individual to replace the thermocouple.
Nov 26, 2008 | Heating & Cooling
Pilot lights fine, furnace fires up, when it turns off the pilot goes out
need to have at least 3 feet of vent out of the roof, if it is to low the coll air will cold soak down to the pilot and shut it down.
Nov 08, 2008 | Cozy (W352E) Heater
Williams wall furnace, top vent.
I've replaced a Williams wall gas heater non-electric. The thermostat is connected right and mounted on the wall. But, there's a thick black copper wire on the side of the furnace tagged thermostat. I don't know what to do with it? Where do you connect this wire? When it touches the top screw of the three screws running vertically(where the other wires are connected). The burner lights up and stays on, even if you play with the wall thermostat. Touching the other two screws doesn't do anything. Now, the manual talks about connecting it to the venting wires? Extra wires coming from the top or maybe somewhere else in the wall? I've left it connected to the first screw, ran the heater. But, it never turns off? Any suggestions? Thanks
Dec 13, 2007 | Heating & Cooling
Unable To Keep Pilot Light Lit!
I have a Williams top vent gravity wall furnace (model 5009622) and I had the same problem. I had to take the cover off the furnace -- screw on top and two at the bottom (open the access door and there is one screw on each side) to get to the reset button for the vent safety shutoff system. On my furnace it's on the left side toward the top of the unit. I pressed the little red reset button and it's been working ever since. If your furnace is properly installed and doesn't have bird's nest in the chimney, it should work fine. Good luck!
Mar 04, 2007 | Williams 2509612 Ceramic Mid-Size Heater
Open Questions:
Heating & Cooling Logo
176 people viewed this question
Top Empire Heating & Cooling Experts
Paul Carew
vance jones
Dan Webster
Dan Webster
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
