Question about Freezers
Proline Freezer upright /not freezing down very well
Model number FF959 Ice forming at the back of Freezer/outside top right hand side corner, where pipe enters. Motor running and appears okay. Feel possible fan fault.
  • Anonymous Mar 13, 2014
    Proline small freezer model number PFZ115WA motor working but not freezing
  • 78 Answers
Defrost it and see if you have lost the insulation aroundthe pipe. If you have you can use expanding spray fome insulation on it. like you use on your house.
Posted on Dec 28, 2008
My upright frost free freezer is leaking water onto the floor.
Hello;
My name is Peter. I am a retired field service refrigeration technician.
You did not provide a model number so I can only be general. Your model number is on a label on the upper side wall.
You have one of three problems.
1.) A bad defrost timer.
2.) A bad defrost Heater.
3.) A frozen drain.
4.) A obstruction/leak - Large block of ice in the upper right hand corner of your cool coil.
Mar 12, 2015 | Frigidaire Freezers
Not freezing
Hello Jim;
If you are getting cooling and not freezing your problem is not your overload relay or capacitor, otherwise you would get no cooling at all.
You have one of 4 potential problems.
1.) Frozen Drain - This is a common problem. Your unit goes through a defrost cycle every 8-10 hours, everything shuts down for about 20-30 minutes. This is when your defrost heater turns on and defrost your cooling (evaporator) coil. If your drain is frozen, a wall of ice builds up behind your lower back wall. This prevents the cooling fan from running and air flow through the cooling coils.
You need to remove the lower back cover to see what is going on. there are several screws holding it on. First remove the rubber seals on both sides. They just pull out.
If it is a block of ice, use a hair dryer to melt the ice and clear the drain. Do not try to chip away, you will damage the coils.
2.) If you observe the cooling coil fan not running and vibrating, then you need to replace the fan.
not-freezing-q5gyx04vmzg44gwribm3t5si-2-0.jpg Part Number: Substitution: 3-60336-001 Cost from Sears: $115.00. You can search the internet and get this part for about $80.00.
3.) Defrost Heater - You may have a bad defrost heater. Observe, is the glass tube black or is the wire inside broken?
not-freezing-q5gyx04vmzg44gwribm3t5si-2-2.jpg Part Number: Substitution: 3-80405-003 Cost: $40.00
4.) Refrigerant leak or obstruction - If you observe a block of ice in the upper right hand corner of your cooling coil, then you either have a leak or an obstruction. A repair of this nature with a service company is about $500.00.
5.) Bad Bi-Metl (Thermostat) - In the upper right corner is your cooling coil thermostat.
not-freezing-q5gyx04vmzg44gwribm3t5si-2-5.jpg Part Number: Substitution: 1-81801-001 Cost: $30.00
If you observe the flat back has popped open, then replace.
Sep 12, 2013 | Whirlpool EV181NZTQ Upright Freezer
Upright freezer not freezing food and ice forming on back wall
is the top of the freezer full where it can breathe remove something to help it breathe
Sep 10, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
I have a Whirlpool Model EV 200N Upright Freezer which is having ice freeze on the bottom of the freezer. What can I do?
If there is frost forming at the bottom to the door, your door gasket is leaking at that location. You may be able to relax gasket back in place with hair dryer, be carefull you can melt gasket. If it is sheets of ice, your defrost drain may be frozen
Aug 28, 2010 | Whirlpool 19.6 cu. ft. / 555 liter Upright...
Upright freezer problem
Hi, I don't know if it were I that helped with you're solution or someone else as we have many, many, techs. Please let me know by my user name.
Shastalaker7
Thank You
Mar 21, 2010 | Frigidaire 11.6 cu. ft. / 328 liter...
Ice in bottom of upright freezer -- problem with tube position?
Hello, get a short piece of electrical wire and strip the insulation off. put a bend in one end and then hang it over the heater directly above the drain making sure the wire runs into the drain about an inch. the heat from the heater will make sure the drain stays clear. Hope this helps. Mike
Nov 19, 2009 | Whirlpool 19.6 cu. ft. Upright Freezer...
Upright freezer door inside developing ice
The door seal is at fault. Regardless of the small tear it is not sealing well.
Take a dollar bill and close it in the door. Then pull on the bill to feel resistance.
You will find it pulls easily in some place. That is where your air leak is that is causing the condensation.
Do this about every 6 inches all the way around the seal.
Mar 27, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Ice build-up on the inside top of of freezer door
yea def , not normal, nor an acceptable amount of ice forming there( good pic). heres what i have been told to try and with good results
first make sure the door gasket is sealing all the way,(small gaps in ht emagnets at extreme corners) is common but with a little amount of "mortite"or "permagum can sometimes be insterted behind the corner of gasket to assist filling the void.
second a small amound of a white/clear silicone be applied to the outer perimtere of gasket, to minmize air movemnt from between gasket and door panel.
lastley in oyour second pic i see "frost free" written on a plastic air deflector. you can remove that with 3-4 screws on backside of it, and then reinstall with a small spacer so as the baffle now with sit with a 3/8in. gap between it and the top of the freezer liner.( a brass ferrel from the compression fitting of a plumbing fitting is just the right size)..... the theory behind this is to prevent the air from gatting "trapped" in the void created when the door closes-- air can now pass back and forth freely.
I hope this gives you some satisfaction if not I would advise another tech be sent who is willing to call for factore tech support( ths is where i got my info from)
Jan 14, 2009 | Frigidaire 13.7 cu. ft. Upright Freezer...
Upright Freezer not freezing,
looks like low on freon. that causes freeze up. oddly enough they freeze up when charge is low , just the opposite of what you think they would do. you have a freon leak unfortunately. probably not accessible, and therefore not repairable. i would suggest, cut your losses and buy new. unfortunately for me and all other srevice techs, the days of affordable repair are over, you can now replace cheaper than i can fix and have a warranty and its new... good luck
Nov 22, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Ice build up in my frost free upright freezer
I looked at the BACK at the bottom underneath of my Sears Kenmore frost free upright freezer and what was causing the ice buildup was very simple. At the factory, the assembler looped the little hose too high and when the water went into the hose it could not get out due to being too high in one spot! An ice dam will form, blocking ALL water coming through
and freezing up any more water coming down giving you a HUGE wad of ice that is scary!!! I just removed the screw holding the loop that holds the hose and put a bit of warm water down the little hole on the INSIDE (Behind the grate) to melt the remaining ice in the tube.You need to take out 4 screws and remove the grate to see this. I could not believe that this was the problem! I haven't had any ice build up since.Now don't tear your freezer apart before you try this trying to fix the compressor, thermostat etc. It may be the only thing wrong with it!
Nov 11, 2006 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Freezers Logo
338 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
