Question about Vivitar ViviCam 4100 Digital Camera
Camera wil not yurn on
The camera was neither dropped or misused, I attempted to turn on the camera as the sliding on slider was OK. Turning on the camera resulted in no live screen, could not take photos and had no idea if camera was operable or not. Has anyone had this problem? If so I would really like to know how it was corrected.
    Genius:
  • 2,985 Answers
This is the service by replacement age No one is going to professionally repair it So if you have the confidence and jewellery screwdrivers to hand why not have a go your self. It is likely a battery conector has broken or an internal connector has come adrift, The ultimate is to buy the replacement.
Posted on May 07, 2007
Card locked error on samsung es80
Turn off the camera and remove the memory card.Most cards have a lock slider at the side.You have to slide that button downwards/upwards to unlock it.Slide the memory card back into the camera.
Turn on the camera.
Hope this helps.Thanks!
Please rate this answer.
Oct 28, 2011 | Samsung Cameras
Lens wil not open. Turn camera on and it gives you a "lens error"
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended.
1.Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
2.
Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Thank you !!
May 26, 2010 | Nikon Coolpix 2100 Digital Camera
My N73 back camera auto opens at anytime, closes and reopens again without using the slide
if you have tat problem then there is problem in your back panel if you change it your problem wil be solved
Feb 03, 2010 | Nokia N73 Cellular Phone
My camera won't turn on
Well theres yoiur answer. If you have banged it or dropped it you have possibly cracked the motherboard inside. Sometimes these work intermittently with rthis type of misuse. other timjes it just stops. Cheaper to buy a new one than muck around getting it fixed
Jul 31, 2009 | Kodak EasyShare CX7530 Digital Camera
Lens error. Restart camera.
this is very common has the camera been near the ocean??? it does not have to be dropped to give you this error. repair on you lens runs 85.00 for repair. or a new lens for 125.00
Jun 25, 2009 | Canon PowerShot SD1100 IS Digital Camera
I dropped my camera and the lens won't retract. The screen reads lens error restart camera. Even though I have removed the battery to restart the camera, it won't correct its self. The lens stays out.
When you reset the camera you should be able to hear the gears of the camera lens turning. The problem is that the lens is out of alignment so the lens can't slide back in. As the gears are turning, straighten out the lens (you might have to try forcing it in different directions if it's not obvious which way the lens is bent) and it should slide back in. You obviously want to be gentle enough to not break it, but sometimes you have to use a little bit of force based on the severity of the drop. You also might need to try a few times since the gears will only run for so long before stopping. I have fixed a few cameras this way but if the lens is bent too far out of alignment you'll have to get it profesionally fixed.
Apr 27, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Slider on olympus c60 broken
Probably!
The slider is held in its groove by a plastic liner and part of mine wore away with the upshot that when I slid it open, the tiny pin on the slider dropped back a little way. We are only talking a tiny amount here but it was enough to activate the switch to reclose the lens so the thing was sliding in and out of its own accord as I rocked the slider.
I simply superglued in a tiny piece of plastic in where the worn away bit was and it cured it!
Chris, England
Apr 09, 2008 | Olympus Camedia C-60 Zoom Digital Camera
Dropped camera and lens Dstuck , sony cyber shot DSC-W50
There are 3 pins in the camera lens that slide in grooves allowing it to move you have knocked out 1 or more.
only an experienced tech can attempt fix , camera must be totally disassembled.
Jan 29, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Not turning on
Hi -
We have two of these cameras. If it has been dropped, it can affect the way the camera "reads" the case sliding. Please turn the camera over and check on the bottom, and see where the cover is sliding to. If it is off track, it will not read it properly.
Also, rechargable batteries don't really work in this model worth a hoot. It is a power user. We've found only ONE kind of batteries that really make this camera work smoothly - the energizer "e" batteries in the silver and BLUE packaging. I take a LOT of pictures, and have had these last up to a month. (I am always curious about battery life and date them with a sharpie when I put them in.) Even after they no longer power the camera, they have plenty of oomph left for powering other regular items. (Our hair trimmers have been running for two months on AA taken out of the camera.)
Also, please close the slider a couple times and reopen it, making sure it is going all the way over. It doesn't always lock into place, and the camera mis-reads it as still being closed. It is a pain in the rump, and something I hope subsequent models get a modification on!
Also, simple, but double-check your batteries, and be sure they are not inserted backwards. Oftentimes, this is the reason ours won't turn on - in haste, we've put one or both in the wrong direction! Ha!
Hope that is the only problem for you.
Dec 23, 2007 | HP Photosmart M22 Digital Camera
Camera turns itself off
I have the same issue, I've pulled my camera apart, it's a faulty contact in the slider on/off switch assembly. I'm planning to remove the slider ass'y and check the contacts. Ricoh state it's a common problem, new switch ass'y is about $40 AU
Jul 13, 2007 | Ricoh Caplio R2 Digital Camera
Vivitar ViviCam 4100 Digital Camera Logo
29 people viewed this question
Top Vivitar Cameras Experts
Damen Wong
Damen Wong
DMS-UK
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
