Huawei I have forgot my modems username/paswordand can not log in! How to log in without reset the modem becouse i dont know all the settings to set corectly? Huawei echolife hg510
  • kannur Mar 12, 2009
    whart is the default username/password for this f##4+_g device? it's not given
    Brigadier General:
  • 8,619 Answers
Hi1 By default huawei hg510 uses ip as 192.168.1.1. Now open your web browser and enter this address or under run(from start menu) enter this ip address. Now under user settings or advanced settingsthere will be an option of password reset. You will not have to reset the modem but the password. Now it will ask for a key. the key can be found out on the back or on the base of your modem. Hope it resolves your issue
Posted on Dec 31, 2008
I forgot my router password so i want to know what can i do to reset it
You will have to reset the router to factory defaults
BEWARE - this means you will lose all the router settings and will have to set them up again including the ADSL settings which your internet provider should be able to help you with. Then when you setup wi fi security all the computers will need the encryption key and sddi broadcast name changed to match
To reset to default settings, turn off the device first. Hold the Reset button and then turn on the device; wait for 5-8 seconds and then release the button. Reset device's configuration to factory default.
http://setuprouter.com/router/trendchip/hg520/manual-1089.pdf
(the default username/password is admin/admin)
you will need a direct connection ethernet cable between a computer and the router as the wi fi will be not set up after the reset.
Sep 28, 2016 | Huawei HG520 ADSL Wifi Router
Both My Inspiron and linksys will not connect to my ISP. They say both are receiving an invalid IP address! I have used all trouble shooting techniques including trying to release and reset! Even went as...
Step 1: Plug the computer (ethernet wired) directly into the modem. Power cycle the modem and when all the light come on you should have internet. If not call your ISP to trouble shoot.
At this point we should be able to determine if it is a PPPoe connection (needs username and password to connect) or if it logs in automaticly.
Step 2: Plug the router back into the modem and the computer plugged wired (ethernet) to the router. Remove power from both the modem and the router. Plug the modem back in first, once all the lights are on plug in the router. Try to connect.
Step 3: Log in to the router via its IP address (normally 192.168.1.1), if no one has reset the user name password it should admin for both. If it has been reset, you will need to know what the user name and password are to continue.
Step 4: Under setup if in step 1 you found you needed PPPoe, then you need to set that under the setup tab. Make sure you use the user name and password provided to you by your ISP. If you dont need PPPoe then make sure this is set to obtain IP automaticly.
Step 5: save settings. Once the router restarts, try to connect again.
If these step do not work, let me know:
1. who is your ISP?
2. What modem do they use?
3. What is your IP address when plugged directly into the modem?
4. What is your IP address when plugged into the router?
I will be around for about 1 more hour, its 2PM central time now.
Jul 21, 2011 | Computers & Internet
Hi i want to have internet on my PSP but it says type your wpa key and i dont know it.
It's a bit different for each router but I can show you how it would look in a regular setting:
Step 1: First of all, you need to launch an internet browser. Press "Windows + R" keys to open the "Run" prompt and type "iexplore" without quotes to open Internet Explorer. You can also type "firefox" to open Mozilla Firefox. On the address bar at the top, type http://192.168.1.1 (Belkin routers use 192.168.2.1 as the default IP) and press "Enter" key.
This address belongs to your wireless modem or wireless router to which you are connected.
Step 2: A window asking for username and password will appear. In the username field, type "admin" without quotes and in the password field, either type "password" without quotes or leave the password field blank. Press "Enter" key to continue.
If password is correct, you will be redirected to the modem/router's "Settings" page, otherwise, you will have to reset the modem/router. Check beneath the modem/router or check the manual for correct password.
To reset a Linksys modem/router or Belkin one, locate a small hole at the back of the modem/router and insert a pin to press the switch inside it. Keep the switch pressed for about 20-30 seconds after which the modem/router will restore the settings to "factory defaults" and reboot itself.
Repeat the step 2, in order to gain access to "Settings" page.
Step 3: On the modem/router's "Settings" page, find "Wireless" option. Click the "Wireless" link to populate the wireless settings. Now, locate and click the "Security" or "Advanced Security" option.
On the security page, you will find "Network Authentication". Different options available under the Network Authentication menu are open, shared, WEP, WPA, WPA2, WPA-PSK, WPA2-PSK, etc. Select either WPA or WPA2, to find your computer's WPA key and insert this key when asked for.
If in step 2, you had reset the modem/router, you will not find any WPA or WPA2 key, and you will have to manually assign one. Select any of the WPA-PSK or any other authentication and assign a key to it. A key can be 8-63 long.
For minimal security, you can choose 8 characters key, like "iN\/5R92". For maximum security, choose 63 characters key like, "sJ0esmoU2cBD\m+oMp$nrXj5XPVRTvVA5fpwGSGI\RVz4RdQ7V3y\l$P1NrT9Be".
After you have assigned a key, save/apply the changes and reboot the modem/router.
Jan 01, 2011 | Sony PSPgo White Console
I tried to change the security settings from WEP to WPA-PSK manually, but my vista laptop was unable connect using the wireless log on key. I then tried to reset the router back to default settings using...
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Jun 29, 2010 | NetGear DG834G Router
I forgot the username and password and can't log in.
Reboot router.Power off for a min.find reset button, hold in with a paper clip or pentip for a min, power up router.
username=admin
password=admin or password
Jan 16, 2010 | Arris SURFboard SBG900 (49402201900) Modem
I hv a netgear wireless adsl modem and i m using bsnl broadband connection can send me the settings to configure the modem at my email id mehtaankur3@gmail.com
TYPE-I Modem Configuration - Huawei SmartAX MT880 Modem / SmartAx MT882 ADSL Modem Configuration
SmartAx MT880 ADSL Modem has One ethernet Port.
SmartAx MT882 ADSL Modem has One ethernet Port and one USB Port.
Set your computer IP address as 192.168.1.2
( If you are using USB port, install USB driver first)
Open Internet Explorer in the Address bar type the URL http://192.168.1.1
You will be propted for Username and Password.
Username: admin
Password: admin
Click on Home
Click on WAN setting
Your WAN Setting should be as follows:
PVC No.: PVC0
Wan type: PPP
Connection Type : PPPoE
VPI / VCI : 0/35
Default Route : Enabled
Username: yourusername@dataone
Password: yourpassword
Use DNS : Enabled
Click on Apply.
You will be asked to save and reboot.
Select Yes
Once your modem is rebooted , the summary page will be displayed .
The "Green" status of PVC0 status indicated that you are now connected. (in Summary page)
SmartAx MT882 ADSL Modem ADSL LED will turn 'Orange' from 'green' when succesfully connected
Sep 15, 2009 | NetGear WGR614 Wireless Router
Forgotten pw
There is no way to access the router without resetting it. You must reset the router, and make a new username or password. Sorry!
If you want, the only setting you need to set is to change your local IP address to 192.168.2.1 (IF you have DSL.)
Dec 27, 2008 | Computers & Internet
How do i configure my dlink 302g modem to my new ISP's settings?
Hi Nitangel
Before proceeding with modem installation you need to gather your connection details from your Internet Provider. You will need to know or find out the following information about your new ADSL connection from your Internet Service Provider:
Connection Type:
PPPoE
PPPoA
Bridge RFC1483
Default IP address: 10.1.1.1 (USB 10.1.1.2)
Username: admin
Password: admin
· Username / password (PPP connections only)
· IP address / Subnet Mask / Default Gateway (Bridge connections only)
· DNS IP Addresses (optional)
To set up, log into the modem using your WEB browser: type http://10.1.1.1 in the address bar and press Enter.
Enter username 'admin' and
password 'admin' (default setting).
Go to Quick Configuration page.
Set Refresh Rate to "No Refresh".
If it is a PPPoE or PPPoA CONNECTION:
Select Operation Mode: PPP.
In the Connection Type drop-down menu select PPPoE or PPPoA profile.
Enter username and your password.
Select CHAP under Authentication Type (check with your ISP if not sure).
If it is a BRIDGED RFC1483 CONNECTION:
Select Operation Mode: Bridge. If you do not see "Bridge" options please update your modem's firmware at http://www.dlink.com.au/tech/
Select LLC or VC Mux as suggested by your provider.
Make sure your VPI/VCI is set according to your ISP requirements:
Click on "Save & Reboot" to save settings.
Then give modem a minute or two to reboot and reconnect. Restart your computer and you should be able to access the Internet.
You do not have to run any login client on your computer or router because your modem logs to your ISP automatically.
Hope this information helps if I can help further let me know.
Jun 17, 2008 | Computers & Internet
Disabling firewall?
by default, you can get to the surfboard configuration page by http://192.168.100.1. username: admin / password: motorola
username and password are case sensitive.
if you dont know the password better get it from your roommate to avoid resetting the modem back to factory defaults. if there's no other way to retreive it you can reset it by pressing the reset button on the back of it for 5-10sec.
after resetting, according to the manual, the modem might need 5min to 30min to sync again with your ISP.
Jun 05, 2008 | Arris SURFboard SBG900 Wireless Router...
Forgotten password on login page
Try looking on the modem itself, sometimes they have their default username and password written on them. Try combinations of "user" or "admin". eg username: "admin" password "admin"
if these don't work and you don't know why you can't log into your modem, try resetting your modem using the reset button on it (or holding the power button for 10-20sec) and then try the above suggestion again.
If you still can't login, write back with your modem make and model number.
Jan 09, 2008 | Computers & Internet
Computers & Internet Logo
646 people viewed this question
Alun Cox
David Payne
David Payne
