Question about EnGenius EOC-3220 (EOC3220)
I cant reset my senao eoc3610
Hi. i cant reset my eoc3610, put the ip adress in my lap 192.168.1.10 but dont hace comunication whit the access point,
how can i do to put in factory default my accesspoint
    Sergeant:
  • 366 Answers
1 ) Check if IP address is the correct address of your Gateway.
Check if you can ping.
Be sure you have your Java enabled
Some router requires a specific Browser (IE6 or IE7) and cannot respond to different browser.
Be sure to remove any Java protection from your Browser.
Check with user manual if IP address requires also a specific port number ( 8080 or other).
Be sure to Connect Router using Lan cable
2) Change your PC IP setting to same subnet as your router
Control Panel / Network settings / properties of TCP/IP define an IP address and a subnet mask compatible with Router as gateway.
3) If you are not sure of Router IP address use reset button on router back to factory default; use this to configure router.
Posted on Dec 28, 2008
HI SENAO 2611CB3 DELUXE REPAIR IP DONT HOW TO RECOVERY IP IP 192.1681.1. DEFAULT NO ANSWER NO CONNECTION THANKS LOST DEFAULT IP SAMMY
192.168.1.1
if you cant open it then reset router by pressing with toothpick the tiny button for 5 seconds while its on power.
if i was helpful please vote ..
Nov 01, 2010 | D-Link Computers & Internet
D-Link 2100 AP is working in Wireless Client mode. It is connected to home network with cat5 cable. The remote ADSL modem is 192.168.1.1 and DHCP on. The first computer in the network obtains IP and...
Check in your router to see if your router is set up to be a DHCP Server. If your router and adsl are both set up to be DHCP servers, sometimes they will fight with each other and some computers seem to have problems getting adresses from this kind of setup. Make sure that only one is set up to give out adresses, then check on your second computer to make sure that it is set to obtain adress automaticaly. If someone has set a manual adress in that computer that is not on the same subnet as the router, they will not comunicate. If this does not solve your problem, try putting in manual adresses into both computers: IE 192.168.1.2, subnet mask 255.255.255.0, Default gateway 192.168.1.1 in the first, and 192.168.1.3 in the second with the same subnet and default gateway,
Nov 24, 2009 | D-Link AirPlus Xtreme G DWL-2100AP...
Noy finding ip address senao wireless AP
Hi. Here is the manual.
http://www.senao.com/images/www.senao.com_English/NL-2611CB3-PlusDelx-Manual-V1-0.pdf?CATNO0=D&CATNO1=D3&CNT=1
Set your PC to use the static IP 192.168.1.10, netmask 255.255.255.0.
To login to the web manager, go to http://192.168.1.1. Leave the username and password blank. You can now configure the device and assign IP address etc.
Jul 18, 2009 | SENAO NL-2611CB5 PLUS (NL2611CB5PLUS)
How do i reset my engenius senao eoc 3220 outdoor radio
back side one reset button is there pull out the power cable then pull in that same time you have to press the reset button for three to five sec then all lied's blink all to gather then your default ip address is came then you again configure at default ip
Apr 15, 2009 | EnGenius EOC-3220 (EOC3220)
Reset password for senao unit
pci adapter don't have password password have in the router or modem or access point device
Apr 07, 2009 | SENAO NMP-8602 (NMP8602) Wireless Adapter
Eoc3220+ ip finder
hi
reset your eoc 3220 and put the default ip address is 192.168.1.254 bridge mode and ad mode ip is 192.168.1.253 and put your pc ip 192.168.1.10,12,14,16 and open the web page and browse the 192.168.1.254 or 192.168.1.253 put user name and password ok!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Oct 07, 2008 | EnGenius EOC-3220 (EOC3220)
Finding of IP for the senao 3320 ext.
repair center, visit : http://www.gblmedia.com
Oct 03, 2008 | SENAO NL-2611CB5 PLUS (NL2611CB5PLUS)
Senao 3220 - access configuration info
I do not know what you have for a DHCP server but some DHCP servers will show you what devices have been given IP addresses which you can use that information to find what address it is at now. Other than that you can use the guess and check method just going through IP addresses until the page comes up, you can use network mapping software to scan your network to find it or you can reset the access point to factory defaults where it will have the default IP address that you can then connect to and re configure it the way you want it.
Jul 06, 2008 | Computers & Internet
SENAO EOC 3220 CONNECTIVITY PROBLEM
hello!
-- try to change wireless channel on your access point
-- try to enable wireless security on your wireless network
-- try to assign static ip address on your wireless computer
Apr 26, 2008 | EnGenius EOC-3220 (EOC3220)
Senao 8610 not working
Are you saving your settings when you exit the setup screen?
Johnlgrn
Dec 29, 2007 | EnGenius / ECB-8610 / 54Mbps / 802.11a/b/g...
EnGenius EOC-3220 (EOC3220) Logo
598 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Tech support
Tech support
john smith
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
