Question about Panasonic TH-50PX60U 50 in. Plasma HDTV
Problem connecting computer to tv
We have a G4 mac in the studio with a dvi connector, bought a dvi to hdmi cable and all was working fine, however, after about 6 minutes tv shuts off completely. Can't turn it back on for about 15 minutes. Any ideas what could be causing this?
    President:
  • 1,284 Answers
Make sure on the back of the unit there is no accumulation of dust near the vents and or fan openings.
Posted on Apr 26, 2007
    Problem Solver:
  • 7 Answers
From my experience of Studios it's also a possibility that the TV is overheating. Check that any vents are not covered and that there is enough airflow around the TV. Sounds like a thermal cutout is triggering.
How can I connect computer to tv
Most newer TVs have a VGA connector on the back with the rest of the connectors. This is generally the easiest connector to use. You can get a VGA cable from a local computer store to connect between your computer video connection and the TV. If you have an old VGA monitor you are no longer using, you may find that the old VGA cable is removable - as they are on some monitors.
Alternatively, you can connect to an HDMI connector on your laptop / PC to the TV's HDMI connector (they should be labeled) using a standard HDMI cable if you have such a connection available. This is the preferred method if you have this connector available on both devices.
Third alternative option is if your computer (or TV) have a DVI connector. This connector can be adapted to HDMI. As an example, if your computer uses a DVI connector, and your TV has an HDMI connector on the back you could buy a DVI -> HDMI cable, or just use a HDMI cable with a HDMI -> DVI adapter on one end.
Once you have connected to the TV in one of the above methods, you then have to use the TV remote and change the 'input source' until you see your computer.
Side note: If you are using a laptop, make sure that your external connector is enabled - for Windows users, right click on the desktop and choose properties then Display. (Windows 8 users, choose screen resolution in the same location).
Feb 24, 2015 | Netflix
Tip
Connect you HDTV to your Mac.
One of the first things you may notice about your new big-screen HDTV is that it has more connections for video than your old TV ever dreamed about. It probably has two or three HDMI connections, maybe a DVI connector, a VGA connector, and at least one component video connection. And those are just the connections most commonly used for high definition.
It’s shame to let all those connections go to waste. Your Mac just happens to be sitting nearby; why not hook it up to your new HDTV? It's actually a pretty easy task. A few lucky souls won't even need an adapter; for the rest of us, at least one adapter will be necessary.
Pick the Right HDTV Port For best quality, your HDTV's HDMI or DVI ports are the preferred connection method. Both are capable of the same digital quality. The only practical differences are the style of the connector and the fact that HDMI supports video and audio in a single connection. If it has one, another option is to use your HDTV’s VGA port. The VGA connection isn't as good as the HDMI or DVI method, but as long as your TV supports full resolution via the VGA port, you'll be hard pressed to notice the difference. Mac Pro, MacBook Pro, Mac Mini Mac Pros, MacBook Pros, and Mac Minis have standard DVI connectors. Mac Minis and MacBook Pros have a single DVI port; Mac Pros have at least two DVI ports. If your HDTV has a free DVI port, then all you need is a standard DVD cable; no adapter is necessary. But in all likelihood, you'll need to connect your Mac to your HDTV using either an HDMI or VGA connection; both options require an adapter. If you choose VGA, you can use the adapter that came with your Mac. If you choose HDMI, you'll need a simple adapter, which is available from multiple sources. The adapter may be a cable with a DVI connector on one end and an HDMI connector on the other, or it may be a small adapter that has both types of connectors, but no cable. Either type will work fine. iMac, MacBook iMacs and MacBooks have a mini DVI connector for hooking up external monitors or TVs. You'll need at least one adapter, maybe even two. At a minimum, you'll need a mini DVI-to-DVI adapter. You may also need a DVI-to-HDMI or DVI-to-VGA adapter, depending on which port on the HDTV you choose for the connection. Make the Connection Once you determine which, if any, adapters you need, and have the necessary cable to reach from your Mac to the HDTV, turn off both the HDTV and the Mac. Connect the cable between the Mac and the HDTV. Turn the HDTV back on first. It doesn't need to be set to the connection the Mac is on, but it must be powered up first, so that when it boots, your Mac can recognize the TV and the resolution it needs. Once the HDTV is powered up, turn on the Mac. Your Mac should recognize the format and resolution of the TV, and automatically select the native resolution of the TV for running the video. In a few seconds, you should see the Mac desktop on the HDTV. Over or Underscan You may notice that the Mac's desktop appears to be slightly larger than the HDTV's screen (its edges are cut off); this is called overscan. Or, you may notice that the desktop doesn't occupy all of the HDTV's screen real estate (there are dark areas around the edges); this is called underscan. You can usually correct either issue by making adjustments on the HDTV. Check the HDTV's manual for information on making scan-related adjustments. They may be called overscan, underscan, dot-by-dot, or pixel-by-pixel. If your HDTV has a dot-by-dot or pixel-by-pixel capability, give this a try; it should eliminate any over or underscan issues. Some HDTVs only offer these special scan controls on specific inputs, so be sure to connect to the corresponding input on your HDTV. Time to Watch a Movie Once you have your Mac and HDTV working together, it's time to kick back and watch a video from your Mac. Be sure to check out the QuickTime HD trailers for a sense of what HD and your Mac is capable of. Enjoy!
on Feb 22, 2010 | Computers & Internet
How do i connect my lcd tv to dell optiplex gx620 computor using hdmi to vga cable
You need to match the connectors, very likely your TV has HDMI or DVI, so use the external video port in the computer, DVI or HDMI, you can buy a cable with a match to the video connector you have in both devices.
May 14, 2014 | Dell Studio Slim-Tower Desktop Computer
Projector NEC V260X cannot detect Mac iBook G4
Hi Helen,
Connecting projectors is normally pretty sytaightforward, but every once in a while things don't work as they should (or have in the past).
I've seen this same problem with all brands of projectors and it can be hair-tearing at times.
Try this - make sure everything is turned off - the turn on the Mac.
Wait until it is competely started (don't do anything else) then when you have your desktop and all your folders turn on the projector and wait. Any good?
If not do it the other way round. Turn the projector on first and then the Mac - I've had that work (but then again I've had the other way work!)
If neither work, make sure they are both switchedx on and then on the Mac go to the Displays control panel in system prefences and select the button that says 'Detect Displays'. I can't remember where it as I don't have a projector at the moment but it appears when there is more than one display connected. Sometimes that causes the system to work - it it dosn't show more than one displ;ay then there isn't a good connection between the mac and the projector.I've been reading just lately of some problems that some people have been having with various apple connectors to projectoras but I guessing that your G4 has a standard DVI connector - so you either connect diresly with the DVI-DVI cable or with a DVI-HDMI cable.
It would seem that those going DVI-HDMI are having the most problems.
Please post back and lets us know what happens.
Mar 08, 2013 | Computers & Internet
Connect 26pf5520d to a mac mini
Try to connect your Mac Mini to another DVI-capable monitor. May be your DVI out on Mini doesn't function at all
Aug 29, 2017 | Computers & Internet
I would like to know what adapter (DVI to VGA Cable Adapter) I need to connect to a Macintosh G4. Thanks
Without knowing what Model Number of MAC G4 you're referring to, I can only give you generic information.
If your MAC G4 has a DVI port it is generally the female style.
The DVI connector on the adapter will need to be a male DVI style.
The VGA end of the adapter will be either male, or female. Most VGA connectors on a monitor cable have a male VGA end.
(The DVI end will have the pins sticking out on the adapter. The VGA end will have the socket holes)
Also stated as the monitor cable end will be a DVI male. The port {Connection} on the computer is a VGA female)
Example of a DVI male to VGA female adapter,
http://sewelldirect.com/dviaftovgam.asp
Barring that you need the other style of DVI to VGA adapter, (DVI female on the monitor cable, VGA male on the computer), this is an example,
[ Note* The newer VGA connectors are also known as an HD-15 connector.
More information on the Video Graphics Array connector,
http://en.wikipedia.org/wiki/VGA_connector
More information on the DVI connector styles, and the Digital Visual Interface technology,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
If you should find all of this confusing, simply state in a Comment as to what connector is on the end of the monitor cable, and what connector is at the computer.
State whether the connectors are Male (Pins sticking out), or Female (Socket holes)
Regards,
joecoolvette
Jul 16, 2011 | Computers & Internet
Hi, I have bought LG LCD ld310 . Can I connect my computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable Thanks Jatinder Kumar
Hi Jatinder Kumar ,
Yes you can connect your computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable.
1. Connect to HDMI (DVI) : just plug in HDMI (DVI) out of PC or laptop to HDMI or DVI TV. Than select source from HDMI.
2. Connect to PC : Plug D sub to TV, select PC in.
I hope that will help you.
thanks.
Mar 21, 2011 | LG Televison & Video
Trouble connecting Insignia HDTV 19" to my macbook pro
Pick the Right HDTV PortFor best quality, your HDTV's HDMI or DVI ports are the preferred connection method. Both are capable of the same digital quality. The only practical differences are the style of the connector and the fact that HDMI supports video and audio in a single connection.If it has one, another option is to use your HDTV’s VGA port. The VGA connection isn't as good as the HDMI or DVI method, but as long as your TV supports full resolution via the VGA port, you'll be hard pressed to notice the difference.Mac Pro, MacBook Pro, Mac MiniMac Pros, MacBook Pros, and Mac Minis have standard DVI connectors. Mac Minis and MacBook Pros have a single DVI port; Mac Pros have at least two DVI ports.If your HDTV has a free DVI port, then all you need is a standard DVD cable; no adapter is necessary. But in all likelihood, you'll need to connect your Mac to your HDTV using either an HDMI or VGA connection; both options require an adapter. If you choose VGA, you can use the adapter that came with your Mac.If you choose HDMI, you'll need a simple adapter, which is available from multiple sources. The adapter may be a cable with a DVI connector on one end and an HDMI connector on the other, or it may be a small adapter that has both types of connectors, but no cable. Either type will work fine.iMac, MacBookiMacs and MacBooks have a mini DVI connector for hooking up external monitors or TVs. You'll need at least one adapter, maybe even two. At a minimum, you'll need a mini DVI-to-DVI adapter. You may also need a DVI-to-HDMI or DVI-to-VGA adapter, depending on which port on the HDTV you choose for the connection.Make the ConnectionOnce you determine which, if any, adapters you need, and have the necessary cable to reach from your Mac to the HDTV, turn off both the HDTV and the Mac. Connect the cable between the Mac and the HDTV.Turn the HDTV back on first. It doesn't need to be set to the connection the Mac is on, but it must be powered up first, so that when it boots, your Mac can recognize the TV and the resolution it needs. Once the HDTV is powered up, turn on the Mac.Your Mac should recognize the format and resolution of the TV, and automatically select the native resolution of the TV for running the video. In a few seconds, you should see the Mac desktop on the HDTV.Over or UnderscanYou may notice that the Mac's desktop appears to be slightly larger than the HDTV's screen (its edges are cut off); this is called overscan. Or, you may notice that the desktop doesn't occupy all of the HDTV's screen real estate (there are dark areas around the edges); this is called underscan.You can usually correct either issue by making adjustments on the HDTV. Check the HDTV's manual for information on making scan-related adjustments. They may be called overscan, underscan, dot-by-dot, or pixel-by-pixel. If your HDTV has a dot-by-dot or pixel-by-pixel capability, give this a try; it should eliminate any over or underscan issues. Some HDTVs only offer these special scan controls on specific inputs, so be sure to connect to the corresponding input on your HDTV.Time to Watch a MovieOnce you have your Mac and HDTV working together, it's time to kick back and watch a video from your Mac. Be sure to check out the QuickTime HD trailers for a sense of what HD and your Mac is capable of. Enjoy!
Feb 22, 2010 | Insignia 19 in. Widescreen Flat-Panel LCD...
HDMI->DVI cable won't work
Are you using a HDMI to DVI cable or are you using a HDMI to DVI adapter? Sometimes, though not on all products you have to go into the menu and select which out put your using for each source and whats going through it. You might need to go into your dvd player menu and tell it not to try to run audio through the cable. That way it's not trying to force a signal through the cable that cant be accepted by the TV. That might possible solve your problem for the DVD player. Let me know if it works
Have a Great day
Aug 11, 2008 | Televison & Video
Get another cable box, the scientific atlanta are notorios for these type of problems
Mar 26, 2007 | iLO 2600 Television
Panasonic TH-50PX60U 50 in. Plasma HDTV Logo
96 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
