Question about Brother IntelliFAX 2800 Laser Fax
Print Report for Specific Date
How do I print a transmission report for a specific date?
  • Anonymous Mar 21, 2014
    I need to pull a transmission report from a past date
  • 163 Answers
I haven't found a way to print a TX report for a specific date. However there is a way to set the machine to generate an activity report at a certain time each day. Press "MENU" , 2-4-2, and you should be able to select the interval for your report by pressing the "OR" key (24 HOURS in this case). Hit "MENU" again and then enter the time you wish the report to print (24 hr format). "MENU", "STOP" and that should give you a report you can use each day.
Posted on Apr 24, 2007
Hi could you tell me how to print the report for sending please to keep as proof to a number it was sent
Customizing the Transmission Verification Report You can use the Transmission Report as proof that you sent a fax. This report lists the time and date of transmission and whether the transmission was successful (OK). If you select On or On+Image, the report will print for every fax you send. If you send a lot of faxes to the same place, you may need more than the job numbers to know which faxes you must send again. Selecting On+Image or Off+Image will print a section of the fax's first page on the report to help you remember. NOTE:When the Verification Report is turned Off or Off+Image, the Report will only print if there is a transmission error, with NG in the RESULT column. 1 Press Menu/Set, 2, 4, 1. 2 Press ? or ? to select Off+Image, On, On+Image or Off. Press Menu/Set. 3 Press Stop/Exit.
Jul 21, 2011 | Brother MFC-620CN All-In-One InkJet...
HOW TO PRINT FAX CONFIRMATIN PAGE MFC440CN
To print fax send confirmation report:
You can use the Transmission Verification Report as proof that you sent a fax. This
(OK). If you choose On or On+Image, the report will print for every fax you send.
Choosing On+Image or Off+Image will print a section of the fax's first page on the report
When the Transmission Verification Report is turned Off or Off+Image, the Report will
Apr 12, 2011 | Brother MultiFunction Center MFC-440CN...
HOW TO PRINT CONFIRMATION PAGE
Apr 12, 2011 | Brother MFC 420CN All-In-One InkJet...
How to print a fax confirmation?
USER MANUAL Page 3-34
Press STATUS key 3 times. Press YES. Press UP and DOWN keys to select the report you wish to print.
TX Result Report The document number, recipient name, date sent, starting time of transmission, number of document pages, time required, mode.
RX Result Report The document number, caller name, date received, starting time of reception, number of pages received, time required, mode, and reception result are printed.
The machine can also be set to print this report automatically after every 60 transmissions/receptions.
Jan 26, 2011 | Konica Minolta Minolta FAX3900 Digital...
Brother IntelliFax-2820 Plain Paper Laser Fax does not automatically print a transmission report each time we send a fax. Is there a way to automatically have that happen. We can't find it.
You need to set up the Transmission Verification Report and Journal Period in the menu table.
-OR-
Press Menu/Set, 2, 4, 2.
Note
is a transmission error, with ERROR in the
RESULT column.
2 Press ? or ? to select On, On+Image,
Off or Off+Image.
Press Menu/Set.
3 Press Stop/Exit.
Printing reports
1.XMIT Report
2.Journal Period
Nov 15, 2010 | Brother IntelliFax-2820 Laser Fax
Fax will not print the right report
You must to reset this one at first/ Then to try a litl to switch on/ If it one will not be no well? make it off/ Then//press the buttom Programm and to find the menu date and make some changes
Mar 14, 2010 | Brother IntelliFAX 560 Plain Paper Fax
How do I get a faxed printed report of all letters faxed from a specific date?
You can only print out a JOURNAL or activity sheet that shows the last 50 numbers sent to or received from.
Oct 15, 2009 | Samsung SF-560 Plain Paper Laser Fax
How can I print a fax confirmation on a specific outgoing fax
Checking a report for the transmission result (?TX Report? function) A report containing the transmission results can be printed. The machine can be set to either print or not print the transmission report or to print it according to the machine setting or only when a transmission fails. To print the transmission report 1 Press the [Fax/Scan] key to display the Fax mode screen. 2 Touch [FAX Menu]. 3 Touch [TX Report] on the Set 1 tab. 4 Select how to output the report, and then touch [Enter]. ? Default: The transmission report is printed according to the previously specified method. For details, refer to ?Specifying report output settings (Report Settings)? on page 10-48. ? ON: The transmission report is printed with each transmission. ? If TX Fails: The transmission report is printed only if the fax could not be sent. ? OFF: The transmission report is not printed, regardless of the transmission result.
Aug 10, 2009 | Minolta bizhub 200 Copier
Print fax journal from previous date on Brother MFC-3820CN
although it may have a time retreival function it will not store 2mo of faxes !! most likely only a few days depending on the amount of fax you receive
Dec 06, 2007 | Office Equipment & Supplies
Confirmation print out
Your wanting what Brother calls a Transmission Verification
Report:
RESULT column.
a Press Menu, 2, 4, 1.
b Press a or b to choose Off+Image,
Press OK.
c Press Stop/Exit.
Nov 11, 2007 | Brother MFC 240C All-In-One InkJet Printer
Brother IntelliFAX 2800 Laser Fax Logo
384 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
