Question about Sony PS-LX250H Turntable
Direct drive turntable will not rotate
Its old but i dont know how to fix it cuz i dont know anything about turntables
Turntable push start will not turn on
Posted on Jan 24, 2009
  • 515 Answers
If it does not rotate, more than likely the belt has either come off, or is broken. Lift up the turntable platter, and you'll see what the issue could be. The platter just lifts right up.
- OPTiC
Turntable Technician
Posted on Jan 12, 2009
PS-FL7 direct drive. When I push the start button, why doesn't the turntable rotate?
The start button could be defective but there also could be some arrangement that prevents the turntable from rotating unless there is a disc in place.
Dec 22, 2015 | Sony Audio Players & Recorders
My turntable dont have a belt and is spining to fast on 33/45 can you please help me.
It's a direct drive turntable. That means the platter is actually mounted directly to the motor spindle, and electronics control the speed of the motor -- no belt needed. Most likely the electronic speed regulator has failed or is out of adjustment. Take it to a repair shop and get an estimate on how much it will cost to fix it. Sometimes it's cheaper to buy a new one than it is to repair an old one.
Sep 30, 2014 | Audio Players & Recorders
Denon auto lp turntable -model dp=29f
Lift the rubber cover off- there should be an opening or two in the metal or plastic turntable platter. Rotate it slowly until you see the motor pulley sticking-up; use a nail file to gently pull the belt from the bottom of the turntable over the pulley. rotate slowly to verify and then put the rubber cover back on. Let me know how it goes. Thanks.
Aug 01, 2014 | Audio Players & Recorders
Turntable runs far too fast
Post model number and make of the turntable.
Feb 28, 2013 | Audio Players & Recorders
Aiwa AP-2600 Direct Drive Turntable - platter not rotating
if the platter is removable by you and easily, might need just a little cleaning and lube at the center . the platter is the top rotating plate that you were pushing to get started.simply pulls out around a center key. check with local service shops how much they would charge for this kind of cleaning and lubing. $25.00 might be a good price to allow a decision, whether to buy a new.
Mar 05, 2010 | Aiwa PX-E860 Turntable
The rubber band under the record player has come off
I am not familiar with your particular model of turntable, but typically the belt is easily accessible under the platter (rotating metal disc). Remove the platter (it often just lifts off, but don't force anything) and then you will be free to reattach the belt. Good luck!
Aug 25, 2009 | Panasonic Technics SL-DZ1200 Turntable
Repairing
Try putting 1 only,drop of sewing machine oil on motor at shaft and let it soak in while manually rotating shaft being careful not to get oil on anything else and see if this helps.
Jul 01, 2009 | Pioneer PL-990 Turntable
Turntable does not rotate when switched 'on'.
Throw it from a second story window then smash it with a sledgehammer. That's what I plan to do with mine.
Feb 08, 2009 | RCA ION-ITTUSB05 Turntable
Technics sl-1610 mk 2 turntable
Unfortunately, it does sound like a drive issue. Just so you know, these units are direct drive, so there is no physical motor. It's just a bunch of various circuits which drive the unit, and if any one of them go bad, it will affect your turntable speed. You will need to have this looked at by a service technician to determine which circuit is faulty.
- TWEAK AV LAB
Nov 26, 2007 | Technics SL-1200MK2 Turntable
Sony PS-LX250H Turntable Logo
767 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
