Question about Magellan Maestro 4000 Handheld GPS Receiver
Magellan Maestro 4000 will not hold a charge longer than 30 min
I need to purchase a replacement battery. I can install it myself. Where can I purchace a replacement battery, even a generic one would be fine if it will fit inside and is rechargable.
Replacement battery at http://www.xtreamgadgets.com/product.php?productid=132797&cat=10001980&bestseller
must remove external card from slot before removing 4 screws at rear of unit. cover snaps off, unplug speaker wire, unplug battery, new battery plugs in, reassemble.
Posted on Jun 13, 2009
    Problem Solver:
  • 12 Answers
Here is a good source for replacement battery for Maestro 4000:
http://www.newpower99.com/Battery_for_Magellan_Maestro_4000_GPS_p/magellan%20maestro%204000.htm
I recommend NewPower99.com because the battery comes with tools and instructions.
Posted on Nov 22, 2010
My Magellan Maestro 3210 constantly says low battery while on trip and shutoff, I have it plugged into the astray why would the battery be low, how do I get it off battery power setting, or why is it doing...
Usually when you see low battery like that it means the battery itself needs to be replaced at it can't hold a charge or enough of a charge to be usefull. If you unit is over 18-24 months old then th e battery is most likely the problem. This will happen even if you have always used external power as the battery doesn;t get properlly cycled enough.
It is possible that it is the power source you are using is too low but sounds more like the battery is the problem.
If you have warrenty the battery should be replaced by Magellan. If not a replacement battery is about $30 and is something you may be able to do. You need to remove the back cover and unplug the old battery and plug in the new one and put it all back together.
Here is one link for a battery but there are other just search for Maestro 3210 battery with google or bing and you should find a few places that offer them.
http://www.batterymart.com/c-magellan-maestro-3220-gps.html
Mar 30, 2010 | Magellan Maestro 3210 GPS Receiver
Battery will not hold charge
make sure its charging by going in to the options tab, then system, then power options and look at the battery meter and see if its moving left to right while plugged in to the charger.
if its not,
This is very common problem with this and many model of magellans.
Try the car charger.
Make sure
green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
The following Magellan 2000, 2200t, 2500, 3000, 3100, 3140, 3000, 3050, 4000, 4040, 4050, 5310 and the 6000 are known to have faulty dc connectors...if your Magellan
gps is not charging or will not power up, its most likely the dc power port...
You can
buy the port or get it repaired, HERE
if the links dont work or If you need further help, just let me know.
Jan 06, 2010 | Magellan Maestro 4000 GPS
Magellan maestro 3100 will not hold a charge
this is very common problem with this and many model magellans.
try the car charger.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
the following magellan 2000, 2200t, 2500, 3000, 3100, 3140, 4000, 4040, 4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get it repaired, here
or buy the port here
if you need further help, just let me know.
Dec 02, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Battery does not keep a charge. Can the battery
yes, the batter can be re placed, but i would verify its charging before buying a battery.
make sure green light is on the car charger (or a known good charger0 and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..
after its started, go to the system setting. the battery meter should be moving left to right. if its all green and turns off when unplugged, the battery needs replaced.
your part # for your battery should be 37-00030-001you can get a battery HERE but verify your unit with the seller.
if it only has a few bars and is not moving while plugged it, it is not charging.
this is a very common problem for the models listed below.
you can get help to repaired it, here
Nov 14, 2009 | Magellan Maestro 3140 GPS Devices
I'm looking to purchase replacement power jack (the power jack mounted on system board) for magellan maestro 4040. where can i purchase only the jack.
Nov 11, 2009 | Magellan Maestro 4040 GPS Receiver
I can't tell if my magellan maestro 4000 gps is charging.
this could be happening for a few reasons but the most common is that its probably not charging.
before checking anything else, plug your 4000 in to a known good charger, then press and hold the power button for up to ten seconds till it starts.
if that fails, its likely not charging
Nov 09, 2009 | Magellan Maestro 4000 GPS
My Magellan Maestro 3100 GPS unit won't charge anymore. I've seen 2 possible explanations for this problem. #1: The DC power port is broken #2: The battery won't hold a charge any longer How do I determine...
if it starts, you can verifiy if its charging by going to the system settings then power options. the green indicator should be moving left to right. this indicates its charging.
if you disconnect the battery, your magellan should still work while plugged in if the power port is ok.
Oct 15, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Power cord is not charging unit. There seems to be a loose fit in the socket of the Magellan Maestro 4000. Is the problem with the charger cord or the Maestro 4000 socket?
its probably not charging...very common problem with this and many others.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (upto ten seconds) until it starts..if that fails
the following magellan 2000,2200t,2500,3000,3100,3140,4000,4040,4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
Oct 09, 2009 | Magellan Maestro 4000 GPS
Magellan maestro 4000, 4040, 4050 vs mio c220,c230,
Don't buy a Magellan. There is little to no support, and their web based support redirects to no where useful for upgrades. I'd sell you my 4040, but can't in good conscience sell it to anyone.
Nov 13, 2007 | Magellan Maestro 4040 GPS Receiver
Magellan Maestro 4000 Handheld GPS Receiver Logo
458 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
