Question about Clarion DXZ945MP CD Player
Receiver won't play music!!
I installed two subs and an amp on saturday, and had to take out the receiver to plug in the rca wire. Everything worked fine(and i've had the receiver for a little more than two months) till sunday. All of a sudden the music stopped playing while I was driving steadily on the highway. I turned off the receiver and waited five minutes and afterwards it worked again normally. A little later it cut again, and came back by itself a few minutes later. This has occured 5 times within two days. The receiver itself does not shut off, it looks perfectly fine even the track time keeps going, but no sound can be heard, not from a cd or from the tuner. My speakers are still plugged directly to the radio(no amp) and my subs have the amp which is connected by rca. So, it can't be a that all speaker wires come loose, even so the rca would keep pumping the subs. And, it can't be a ground or power wire problem either because the radio doesn't turn off, it stays lit normally the track keeps rolling.(When taken out of the dash I can see through the casing the cd is still turning) I am completely clueless as to what the problem is, I'm beginning to think it might be an internal problem with the receiver, the chip modulator or amplifier circuit inside...(Dont' know too much about electronics...) So, if anyone has any idea please help me!!
  • Jonathan Santos Apr 24, 2007
    I installed a kicker zr240 with two jl audio 10w08. I bridged the amp and plugged the subs in parallel. I used 4 gauge wire for power and ground, an 80a fuse as well as a 2.5 farad cap. The amp is sitting in the bottom of my trunk.
    I doubt it is a lack of power because last time it cut, I checked my voltage and it was fine. And, I also doubt that the radio over heats, cause yesterday morning the radio cut after two minutes of riding in the car, the volume was low and my engine temp hadn't even started going up. So, everything was still cold.
    I'd be most happy if you could identify my problem without it being the receiver itself!
  • Jonathan Santos Apr 27, 2007
    I fixed the problem. I had temporarily installed 2 speakers in the back and had just twisted the connecting wires by hand and covered them with electrical tape. One of the twists got loose and was creating too big of a resistance at times, which would trigger the protection of the receivers' amp, cutting it off. I spliced the wires properly using tubes and the sound hasn't cut off in 3 days....I assume it was the problem.
    New Friend:
  • 83 Answers
Do you have your subs in paralell and the amp bridged? is your impedance too low causing a thermal overload due to not providing the minimal impedance? could you give amp and model number along with sub , how many voice coils on each, and where youy have the amp physically located so I may better diagnose and help you fix your problem?
Posted on Apr 24, 2007
    Scholar:
  • 94 Answers
Assuming that you have no sound from any speaker (hardwired and amplified from the phono/RCA output) I think it could be a fault introduced by your sub install. Have you tried unplugging the phono lead to the sub? If the phono lead has a short in it, it may effect the entire system. It could also be down to heat or lack of power. Have you got adequate thickness of cable and a high enough rating of fuse?
I conected my sub wrong and the unit shut down , I reconected my sub and everything seems to work fine , should I send it in for servicing?
If i'm right, the system powers down as a safety precaution. It prevented itself that it will breakdown. It's your choice but I recon you can just enjoy and listen to your favourite music.
Apr 26, 2014 | Harman Kardon AVR 7000
Alpine CDE 141 will not output to sub
Your description is not very clear but my guess is that the output from the RCA connector on the head unit (receiver) is low level and intended to be connected to an amplifier input. Apparently the 3.5 mm "jack" (plug) connects something to the RCA input of the amp and that works.
Nov 24, 2013 | Alpine Car Audio & Video
My powered subwoofer no longer works through the receiver
if you have your front and centers set to 'small' you want your Bass out to be subwoofer only, and the rca jack labeled 'sub out' is the only place to connect your sub to if you want to control the frequencies with your reciever. I dont know the brand of your sub, or the inputs on the back of it to advise you where to connect, but it sounds like it worked for you at one time, but suddenly it does not
Mar 05, 2013 | Audio Players & Recorders
Problems with JBL PSW D110
The speaker level input option is designed for receivers that don't have digital output for the sub, used this way when you set to digital the speaker outputs only get the higher range outputs so won't reproduce much bass. To get the sub to work in digital mode you need to use the digital output (single RCA) from the amp to the sub
Mar 06, 2012 | Audio Players & Recorders
I've got a vsx-920-k Pioneer receiver with s-11 Pioneer speakers and a s-21w Pioneer subwoofer. All of a sudden my sub stopped working and it seems like it's stuck in standby mode (blue light...
The manual is here...
http://www.pioneerprodj.eu/eur/products/42/99/S-21W/media.html
Flashing Blue is not defined in the manual.
Have you tried changing the Auto Standby switch to ON?
You can prove if the sub amp will respond to a known good input by TURNING ITS VOLUME DOWN tp start and just feeding it ANY RCA output from the receiver while playing, say, FM (to keep it simple). That way you would known in which direction the problem actually lies (internal or external).
Jul 05, 2011 | Pioneer VSX-C300 Receiver
My celestion s20 subwoofer won't play if i hook it up to sub out on receiver.but will play if i run a regular speaker wire to it. I know sub out is working on receiver.
Tell your source (receiver???) that it has a sub and set it up to feed LFE out of that RCA jack.
Prove your sub pre-out works. Or send something like FM on Tape Out to the sub and see how that works out.
How did you hook a speaker wire to this model of powered sub? What was on the other end of that speaker wire? It's not designed for speaker level input.
Jan 28, 2011 | Celestion S20 Subwoofer
Receiver cannot recognize subwoofer
As I implied earlier, take a clue from the physical style of connectors for both parts of the subwoofer function in the old and new receivers:
RCA connections are for Line Level signal between components only.
The input (bare wire) at the speaker is for AMPLIFIED signal.
You can't just modify one to fit the other and expect magic to happen. Be glad you didn't do it the other way around and modify an amplified (speaker level) outout into a Line Level input. You likely would have smoked that component.
Your subwoofer is a passive speaker, that is, like any other speaker it needs an amplifier. Many subs are self-powered (amp built-in) and they would mate well with the RCA sub output of the receiver.
Get yourself an Active (self-amplified) Subwoofer and run UN-MODIFIED RCA cables to it, according to its instructions, from the Sub Out of the receiver. Or get an amplifier between your receiver and the sub you have.
Feb 21, 2010 | Pioneer VSX-D607S Receiver
Sub does not work when i plug the cord into the Receiver
Does your subwoofer have a fault or amplifier? Try listening to the sub for a hum when the RCA input jacks are touched by your fingers. If it is your amp, check the bass management to see if you have activated the sub output. If it seems to be the amp and you have checked everything. Take it for repairs to a Yamaha service center.
Jun 05, 2009 | Yamaha HTR-5860 Receiver
About technice sa-dx930
The one plug on the back of the receiver is an rca-type plug and is designed to be connected to a powered sub, which would also have an rca-type input. Even if you connected it, this output carries a line level signal and is not powerful enough to drive a speaker. If your sub has 2 connectors (same as a normal speaker) then you have an unpowered or passive subwoofer. You would either need a powered sub, or to use an external amplifier of some sort...then the sub output from your current receiver would go into the external amp...and the amp connected to the passive sub.
Hope this helps.
Mar 30, 2008 | Technics SA-DX930 Receiver
Clarion DXZ945MP CD Player Logo
133 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
